Page 3 of 10 FirstFirst 12345 ... LastLast
Results 51 to 75 of 228
Thread: Shootr's 2 x 48 Belt Grinder Build
  1. #51
    Pensacola , Fla
    Re: Shootr's 2 x 48 Belt Grinder Build
    Well Three Rivers that is a neat idea of the Radius platens to simulate larger wheels, 8" is as large as I can go. Looks like a great way to Hollow grind blades.
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  2. Likes VaughnT liked this post
  3. #52
    He originally designed them exactly for hollow-grinding knives. Before him, everyone was just using wheels. I even saw a guy get one of the drive wheels off an Abrams tank and use it. Beautiful bit of engineering in that, but it made for one really heavy wheel!
    I'm thinking you could get the same idea if you simply bent some bar around something of the diameter you were wanting to mimic. It wouldn't be as easy as turning a chunk on the lathe, but it would get you there in the end. And no need for a big lathe.
  4. #53
    Pensacola , Fla
    that was my though, a plate roller would do just great to form a platen add on.
    Hypertherm 65
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
  5. Likes VaughnT, Shootr liked this post
  6. #54
    You lost me on this one... why a curved platen rather than a flat one? Wouldn't that be much the same as holding the object against the curved part of the wheel?
    That's exactly the point. Sometimes, that curve is exactly what you need for the task at hand.
    Knowing the exact size of the radius means you can fit the design of your work to incorporate it much like when you have a small-wheel adapter for your grinder.
  8. Likes whtbaron, N2 Welding liked this post
  9. #56
    Arizona
    Little bit of progress today. Took forever to make the hole by the "wheel" - plasma cutter is absolutely next on the list!
    Just taking my time. Got the buffer mounted to the base plate. Could not get the vertical frame plumb - wound up shimming the buffer, now it's level and plumb. Put three feet on the bottom, nice and stable.
    Tomorrow will be cutting the frame to accommodate the platen assembly, the buffer bolt access (thanks Vaughn), and getting the platen assembly mounted.
    Yeswelder MIG-205DS
  10. Likes LtBadd, VaughnT, whtbaron liked this post
  11. #57
    Got my shot glass out if Shootr needs a shooter... you know, to wash that taste out of your mouth...
  12. Likes N2 Welding, 12V71 liked this post
  13. #58
    The big chem vendors gave me squat.
    I had to use topless metal quart oil cans for measuring liquid pesticides.
    Yeah yeh I know. I prob lost you at "topless". LOL
  14. Likes N2 Welding, whtbaron, 12V71 liked this post
  15. #59
    Arizona
    A dram or three of Glenlivet was a perfect accompaniment!
    Slainte Mhath!
    Yeswelder MIG-205DS
  16. Likes Lis2323 liked this post
  17. #60
    Around here your choices would be Jamieson's Irish Whiskey, Crown Royal, Bacardi white rum, some disgusting Scotch somebody left here... probably some Smirnoff Vodka for the girls... I gave up on the panty remover years ago.... personally I drink more beer to stay out of trouble... might be a few bottles of wine kicking around too. Time to make my homemade Irish Cream for Xmas.... goes great in the coffee in the morning...
  18. Likes Shootr liked this post
  19. #61
    You guys would be out of luck as I'm out of celery.
    I'm hoping my neighbor's wife is going to Costco today....
  20. #62
    Maybe we could mix that 50/50 with rum for the topless girls...
  21. Likes Lis2323 liked this post
  22. #63
    20+ years late. That ship has sailed....
  23. Likes whtbaron liked this post
  24. #64
    Not really... we just need older girls...and poorer eyesight. lol... maybe that was part of the plan...
  25. Likes 12V71 liked this post
  26. #65
    Check and check.
    Nope still doesn't work for me.
  27. Likes whtbaron liked this post
  28. #66
    Arizona
    Them first two will work just fine...
    Yeswelder MIG-205DS
  29. #67
    Slainte Mhath!
    You know... when you first started using that nik, I thought you were into guns... I see what it's for now...
    Ha. Me too
  31. Likes whtbaron liked this post
  32. #69
    Arizona
    You could say it covers both
    Yeswelder MIG-205DS
  33. Likes whtbaron liked this post
  34. #70
    Arizona
    Meanwhile, back to our original programming...
    Good progress - I think this thing just might work.
    Work rest and tension/tracking wheel still to do. Very pleased.
    Yeswelder MIG-205DS
  35. #71
    Arizona
    Having fits trying to come up with a tension/guide wheel assembly. Best that would seem to work with my design is this:
    Rough sketch - everything above the yellow line would be removed. The red is the arm and a spring. A pivot halfway along the arm.
    A cleaner version would be OK, but I'm hoping something more stylish (and within my skill set) will pop into my head...
    Yeswelder MIG-205DS
  36. Likes whtbaron, VaughnT liked this post
  37. #72
    The yellow line should go from the top wheel down to the bottom wheel. You don't need the platen assembly surrounded by steel plate as that'll get in the way and doesn't serve any purpose.
    Think of it like the Eiffel Tower rising up from the base plate. A glorious design of simplicity and elegance, with naught more than is absolutely needed.
  38. #73
    Arizona
    Early on in the thread, it was inferred that the 1/4" plate would be barely adequate (unless braced) to support the other pieces.
    The first sketch took that to heart to maintain as much mass as possible. I was kinda looking at it as a more brutish angular form than curvy.
    Maybe something like this:
    Yeswelder MIG-205DS
  39. Likes whtbaron liked this post
  40. #74
    Arizona
    Looks like a good place for springs. Any thoughts on how much tension is appropriate?
    Name:  Screenshot_20211219-183210_Amazon Shopping.jpg
    Yeswelder MIG-205DS
  41. #75
    If in doubt, I would attach it to something like a threaded rod so you can adjust the tension when you get using it.
  42. Likes Shootr liked this post
Page generated in 1,713,290,404.47745 seconds with 20 queries
