Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Mm252 feed issue
    Apr 2011
    minnesota
    Re: Mm252 feed issue
    I can slide the wire back and forth through the entire gun. I am going to get a replacement liner and try that. The problem is worse if the gun isn’t straight. I have no tension on the spool. This isn’t a complicated system it shouldn’t be hard to figure it out
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
    Jul 2018
    Cumbria, UK
    It's not complicated Your rolls aren't clamping the wire. So either you have the wrong size wire (measure it with some calipers), wrong rolls, or worn out rolls.
    Usually the problem ISNT too little clamping force on the wire, it's usually too much. Its dead easy to clamp solid steel wire with V rolls of the right size.
Page generated in 1,713,252,751.56842 seconds with 18 queries
