Results 1 to 25 of 37
Thread: Needle scaler any good?
    Aug 2012
    AR
    I need an inexpensive needle scaler for light work. Are these Powermate needle scalers any good? The price is low, but is the quality low as well?
    Powermate model: 024-0299CT
    Re: Needle scaler any good?
    I use a electric wire brush aka 4 ½" grinder.
    If weld is running just right removing slag is easy too.
    Aug 2012
    AR
    I've got brushes, chisels, grinders and hammers...I need an inexpensive scaler.
    May 2021
    Landrum, SC
    At that price it will be hard to say. But I've had expensive ones end up being a POS too. You never know you may get lucky, unless you plan on hitting hardened steel all day.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
    From what I've found the online ones hit harder. I have an ingersal rand that I've used for years. I think it's on its 4th or 5th set of needles. Buy once cry once.
    Aug 2012
    AR
    Good info. I would prefer an inline one to get in tight places.
    It is like using flux core wire if everything is just right it will peal off.
    I have found this with most stick welding too one hit with a chipping hammer the slag is off.
    I still use a wire brush for construction work as maybe Xray years after welding in California.
    FYI In California they like cert welder as one more to though the book for earthquakes
    Big Lake/Monticello MN
    I use the Harbor freight inline one. It works pretty good, broke part of the striking anvil behind the needles, but still works fine.
    Syncro 350
  9. Likes CAVEMANN liked this post
  10. #9
    Looks great and a good price too.
    https://www.harborfreight.com/compac...ler-96997.html
    Now they need to make a electric one.
  11. #10
    Pretty sure I have this one:
    https://www.harborfreight.com/air-ne...aler-1108.html
    Syncro 350
  12. #11
    Typical harbor freight. They no longer make that one and now it's a more expensive one. The harbor freight one is pretty much a spot on copy of the ingersal rand. Someone I used to work with had the hf one, thrashed about 3-4 of them while the IR is going strong. Definitely a tool that loves air tool oil
  13. Likes MinnesotaDave liked this post
  14. #12
    That is air most of electric are $1,500.00 and is very heavy to climbing scaffolds too.
  15. #13
    Aug 2019
    I have this exact model. 29$ as I recall. It works very nicely and it is light on air. My only complaint is that the barrel doesn’t secure to the gun tightly. It tends to unscrew itself. Pictured here in the swapable high dielectric (wood) holders.
  16. Likes whtbaron liked this post
  17. #14
    May 2007
    reason i like straight ones/inline, is when i yank on the hose, it slides right into my hand positioned to go. also, when its tangled amongst a bunch of grinder cords on a lift/basket, i can pull the hose, and it usually slithers out of the tangled cords. odds of a pistol grip one doing either isnt good. i spent a hundred bucks on a generic one and its held up well, 2-3 sets of needles, but there falling out now. probabaly what helped its life is, i always kept it oiled, and kept pressure only as high as to make it work satisfactory, which is about 60 -45 psi
  18. Likes CAVEMANN liked this post
  19. #15
    Nov 2013
    A needle scaler is Such a great tool to have, I use it for all sorts of things. They absolutely Eat cement and mortar
  20. Likes MinnesotaDave liked this post
  21. #16
    Oct 2016
    Delavan WI
    I have the Ingersoll air hammer and they may a scaler for it as an attachment.
    I’ve read here Popeye The Old Miner uses Harbor freight scalers. Buys the warranty and gets a two for one deal.
  22. #17
    Quote Originally Posted by Continuum View Post
    I've had that issue with a few Chinese tools.... air hammers, die grinders.... I've tried blue Loctite and it didn't work. Might try red some day, but only on things I never need to open up, the needle scaler might not be one of them. I have an inline needle scaler that's staying together so far... it was a little higher up the scale of cheap Chinesium at around $70 CDN on sale, but it seems to be doing well.
    Luck of the draw.
    A American made chipping hammer works all time. Does not need air or electricity but the leaver is hard to swing all day long.
  24. #19
    May 2007
    Luck of the draw.
    might be a lil hard to be watched while trying to charge 100+ per hr, and be tinkering w/ a hammer sometimes also, i havent seen a new slag hammer i like and worth a darn in yrs, let alone american made. i have a handful of slag hammers off the alaskan pipeline from an old surplus dealer. the heads are a hard stainless, and i only need to sharpen it once/twice a yr.
  25. #20
    Most time I use 4½" grinder with a wire brush. The leaver on the chipping hammer gets tiring to swing all day.
    When I was doing welding it QUOTE they did not care what used.
    might be a lil hard to be watched while trying to charge 100+ per hr, and be tinkering w/ a hammer on a stiffener in a ibeam/etc. also, i havent seen a new slag hammer i like and worth a darn in yrs, let alone american made. i have a handful of slag hammers off the alaskan pipeline from an old surplus dealer. the heads are a hard stainless, and i only need to sharpen them once/twice a yr.
  26. #21
    Apr 2021
    Alabama
    Just saw a video on the torque test channel on youtube where they showed how the long barrel air hammer is literally the exact same model, put out by the same factory in taiwan, with the same exploded parts numbers and diagram as the expensive matco version.
    Maybe there's a similar needle scaler?
    I prefer to use a wire wheel, but a needle scaler fits in places a 5" wheel doesn't.
    Where I work, all the air tools are sioux pneumatic tools, but they are rather expensive. They're used every day, all day, so there's something to be said for that. I guess your price point will depend on how often you plan on using it.
    Another brand to look at would be Chicago Pneumatic. Sometimes you can snag a used one for cheap. (probably because the seller confuses it with the cheap HF Chicago electric brand.)
    Andy
    ESAB 350 MPI
    ESAB 330I CVCC
    Lincoln Idealarc 250
    Eastwood TIG 200
    Hobart Ironman 240
    Hobart Plasma Cutter
    Lincoln 110v MIG
    CH 110v MIG
    MK Industries Cobramatic with Prince XL
    Miller XR Wire Feeder
  27. #22
    Jun 2017
    AJO, ARIZONA
    I've got the cheapie Harbor Freight model, the onl complaint I had was the needles weren't swaged enough on the end in the gun body which was a fairly simple fix. I made a jig to hold them, heated with a torch & swaged the a little more. I think I paid 15 bucks for it, they're about 23 now.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
  28. #23
    I like the atlas tomahawk.
    Bought one for my sweetie and I use it
    Syncro 350
  29. #24
    Oh my.... she likes it rough, huh? lol... Happy Holidays Dave!
  30. Likes Lis2323 liked this post
  31. #25
    I like Tomahawk chipping hammer
    The only problem I had is they ran away
    Works great too.
    Do not turn your back or they wonder off in side someone pocket.
Page generated in 1,713,310,745.27042 seconds with 20 queries
