Results 1 to 4 of 4
Thread: Superultra 206si with AG60 plasma torch.
    Jul 2014
    Are there consumables available to convert this torch to a drag tip ( to use with templates) and if so will this harm the welder?
    Nov 2008
    Re: Superultra 206si with AG60 plasma torch.
    This is an old panasonic design torch. It is a high frequency torch. They never made any shielded or specific drag consumables with it. However, you can drag cut up to 30 amps with the stock ones.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Jul 2014
    Is there an alternate torch that I can use that has drag tip capability that will not damage my welder?
    Nov 2008
    Not that I know of. It won't damage your welder, just wear out your consumables a lot faster, unless you literally weld it to the metal and keep trying to cut.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
Page generated in 1,713,267,799.45530 seconds with 18 queries
