Love my 9 year old POWERARC 200 but seeing a need for MIG
I bought a POWERARC 200 9 years ago for use on my hobby farm. Comparing it to the POWERARC 200STi it seems the price has remained constant since then! It is incredibly lightweight and I drag it all over the place. I have welded bush hogs, plow supports, rebar, trailer parts, axle mounts, cultipackers, etc. Has always done everything I needed it to and I have gone through over 50lb of 7018 with zero problems even though I store the welder in my shop which is not climate controlled. Thank you for producing such a reliable, easy-to-use welder!
However, to weld thinner pieces of sheet metal I am now considering a MIG device even though 90% of my welding will still be 7018 stick. Will probably pass the stick welder on to someone else so I need a dual SMAW/GMAW. Will the POWER I-MIG 200 do all the stick welding that my previous POWERARC 200 did?
Re: Love my 9 year old POWERARC 200 but seeing a need for MIG
Or, it may be better to keep this stick welder as I really like it and am familiar with it and add your CYCLONE 140E.
Look at the 200E for more power range options.
Esab Migmaster 250
Lincoln SA 200
Lincoln Ranger 8
Smith Oxy Fuel setup
Everlast PowerPlasma 80
Everlast Power iMIG 160
Everlast Power iMIG 205
Everlast Power iMIG 140E
Everlast PowerARC 300
Everlast PowerARC 140ST
Everlast PowerTIG 255EXT
Just go with it! That's what I did -- own both -- and it was the best decision I ever made, because of the options. I love my Power I-MIG 200 (have had it for ~6 years now), particularly for stick welding 8-gauge to 14-gauge metal, spool gun aluminum welding, and due to its dual-voltage feature with the capabilities to mig thin mild carbon steel like down to 18 or 20 gauge using a 120 volt 15 amp outlet! Lots of options with the I-MIG 200 machine, including an excellent duty cycle. I would get that (I also have the dedicated PowerArc 200amp stick welder for thicker steel). I previously had the 140, which I sold to a friend once I got the I-MIG 200. My .02
Agape Guy
Everlast Power I-MIG 200 (dual voltage)
Everlast SM200N Spool Gun (aluminum mig welding)
Everlast PowerArc 200 stick
Harbor Freight Titanium 125 Easy Flux
Hypertherm Powermax 30 plasma cutter
Way too many power tools
