Results 1 to 8 of 8
Thread: Jackson W40 Welding Helmet, Do I Need New Batteries??
    Mar 2021
    Near Roanoke, VA
    My Jackson W40 helmet has worked perfectly, for 2.5 years.
    What I ran into yesterday, may be a characteristic of the helmet,, or perhaps the batteries are dead,,
    (NOTE, I have not used the "GRIND" mode before,,)
    When using the helmet as a "welding" helmet, the auto-darken works perfectly.
    but,,,, when using the helmet in "GRIND" mode, where the shade stays at "4", if the solar cell is not directed at a light source, the helmet reverts back to "WELD".
    The helmet reverts back to "WELD" in under 2 minutes,,.
    If I place the helmet under a significant light source, the helmet will stay in "GRIND" mode.
    Possibly, the helmet is "going to sleep" when it does not see a significant light source??
    It is sort of a pain having to keep resetting the helmet to "GRIND",, so I always have to "PARK" the helmet so that it is pointed at a bigger shop light.
    Do you think this is normal, or could it be that the batteries need to be replaced??
    Jun 2011
    Re: Jackson W40 Welding Helmet, Do I Need New Batteries??
    I'd get out the owners manual.
    Retired - Refrigeration Pipefitter - Master Electrician- Iowa
    Lots of Hobbys
  3. Likes SweetMK liked this post
    CT
    I have that helmet but I can't say I ever observed that issue. With mine, when I needed new batteries it just stopped working. Batteries are cheap enough, give it a try. Even with solar cells they don't last forever.
    Miller Multimatic 255
  5. Likes SweetMK liked this post
  6. #4
    Interesting to see what the answer is.
    I've never used grind mode on any helmets so am of no help.
  7. Likes SweetMK liked this post
  8. #5
    Mar 2021
    Near Roanoke, VA
    My Miller auto darkening helmet lasted 18 years,, I am sure I expected the Jackson to last more than 2.5 years,, so, I doubt the manual is to be found,,,,,,,,,,
    I do not know if the change from Grind back to Weld is a problem, other than the "reset", the helmet works as it should, in "Weld".
    The Miller did not have a "Grind" mode,,
  9. #6
    If I'm not actually welding I want the hood off my head.
    Plus isn't it difficult to switch modes with gloves on?? Maybe a voice actuated Bluetooth option would be nice.
  10. Likes SweetMK liked this post
  11. #7
    Mar 2021
    Near Roanoke, VA
    I was using the helmet with the plasma cutter, "GRIND" is perfect
  12. Likes Lis2323 liked this post
  13. #8
    Mar 2021
    Near Roanoke, VA
    OK, as a follow up, I forgot the helmet had a battery condition displayed inside the helmet.
    The helmet has been in the dark for 2 days, and I looked at it this evening, the battery condition shows "FULL',
    So, my guess is that "GRIND" only stays on as a solar powered function.
    The display is LCD, but when the helmet is switched to "GRIND" , a bright amber light is displayed.
    I would think the helmet only displays that amber light with solar power,, the light may draw too much current for the little coin battery.
Page generated in 1,653,258,104.73592 seconds with 12 queries
