Page 14 of 18 FirstFirst ... 41213141516 ... LastLast
Results 326 to 350 of 438
Thread: 40Ton Hydraulic Press Brake
  1. #326
    Re: 40Ton Hydraulic Press Brake
    Fair enough.
    So how about I use 1/4” wall DOM and sleeve it as suggested?
    Which then leaves the question do I do a single 1” pin on each side (not gonna use bolt) or do I do a pair of 3/4 pins?
    If I do a pair I’m worried I will have alignment issues trying to get 4 holes to line up at different locations.
    I anticipate the bed will weigh around 100-150 lbs if I make it 6” tall. So moving it will be a 2 person operation for sure.
    I'd just use single pins as it's extremely difficult to get full bearing equally on a pair. I wouldn't bother with sleeves, just adding an extra reinforcement doubler to increase the bearing surface.
  2. #327
    Oct 2013
    Long Island, NY
    I’m torn if I even want to make it adjustable.
    It adds a different issue to the bed as well for constructing it. Might just ditch that idea the more I think about it.
    It’s hard to pick a set height though before I buy tooling.
    www.FirehouseFabricators.com
    Zach
    Millermatic 255
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  3. #328
    On the press brake I built( much simpler design,) I just made sure I had enough headspace for the lower die. I figured I could always space it up if need be. Unless your using a lower die with a really large opening, not much travel is needed.
  4. #329
    Jan 2012
    Same for me. 6foot tall.
    36" horizontals on the base
    I love that press design. Did you build it? I built a nice press but had the pin holes drilled in a shop by someone and some of the holes are slightly off. I am going to modify my press with this type of design and solve that problem that has annoyed me for years.
    Millermatic 211
    Lincoln Precision TIG 225
    Century 250 MIG
    Lincoln 225 AC Box (sold)
    I support my local welding store (Amazon, McMasterCarr, Cyberweld, EBay).
  5. #330
    Quote Originally Posted by Fab54 View Post
    Yes. Almost 40 years ago.
  6. #331
    Oct 2013
    Long Island, NY
    The UPS guy probably wasn’t thrilled about this one
    Get it cut to size tomorrow, pin holes drilled and maybe run a chamfer tool around the exposed edges.
Size:  204.0 KBName:  C0C2234F-29BF-4FC5-8F80-1BE33A4C5F47.jpg
    Zach
    Millermatic 255
    Lincoln SW200
  7. #332
    Jun 2008
    New Plymouth ID
    i tried to use double pins on each side on my press I drilled them all on a mill and they still didn't line up right so Im 1 pin per side I like that stacked plate set up. trying to adjust a table with a couple of comealongs or a forklift or whatever other means that are used is always fun
  8. #333
    Mar 2021
    Near Roanoke, VA
    That 1/2X12 steel looks familiar,,
    If you read about the blades that are available, only some "X" number of teeth should be "in the cut" at one time.
    That is because the teeth gullets will fill with chips, and further cutting has no place to "store" chips waiting to be dumped.
    The blade will keep cutting, and simply jam the cut full of chips.,, then you notice the saw really pulling hard.
    On chainsaws, for big cuts, the chain has a "skip-tooth" design,, that ends up being 1/2 as many teeth.
    If you need to cut a 36 to 60" tree, you need a chain with a single tooth every 2 or 3 inches.
    To properly cut 12" with your saw, you would probably need a one or two tooth per inch blade,, there is very little need for such a blade, and it would be fragile.
    Here is how I defeat the problem of too many teeth on my 5 to 8 teeth per inch blade (variable pitch blade),,
    I put a clamp on the rear jaw of the vise,, then the 12" plate is put in the saw, with the rear elevated.
    It is sort of like cutting with the saw vertical,, where the thickness is only 1/2",, but, even my 9X16 saw will not take 12" standing up.
    With the part in the saw like this, I only have at a maximum, about 1/4 of the width being cut at any one time. (about 3" when close to the end of the cut)
    my saw has zero problems cutting 3",, here is a pic of four parts being cut at a time, each is 3/4" thick.
    My saw has enough power to pull a Lennox 1" wide blade in half at the weld if I cut 12" laying down in the saw.
    When I first got the saw, I broke several blades like that.
    Lifting the blade about every 5 to 15 seconds will allow the chips to clear,, but, why risk destroying a blade??
  9. #334
    Oct 2013
    Long Island, NY
    Got the ram? I guess Ill call it done. Not sure the technical name here.
    Had to change my bandsaw setup to cut the cut the 12 plate so I had to make test cuts for like 40 min to get it dead square again.
    I opted to cut it on the flat because I find it ultimately results in a nicer cut.
Size:  161.9 KBName:  CE30F329-FDAF-421B-847E-F9A8CC9BE8FC.jpg
Size:  170.3 KBName:  48D0DCD4-459E-4682-A51A-1C4875197DF6.jpg
    Zach
    Millermatic 255
    Lincoln SW200
  10. #335
    Oct 2013
    Long Island, NY
    Cut the holes and used an air chamfer tool to break the edges all around.
    Everything moves awesome by hand. I’m concerned if it will scrape the walls of the tube frame when it’s under real force but I guess we shall see.
    Worst case I cut the piece back and maybe add a replaceable wear strip. I’d say over 85% of the force is vertical though given the travel of the links.
Size:  177.8 KBName:  AB9D77B3-20EB-449A-8336-66E09549E635.jpg
Size:  179.5 KBName:  502A84A0-7937-4783-B7D4-50560971F657.jpg
Size:  165.3 KBName:  F990540A-4452-4314-A241-86D7CA6CBECC.jpg
    Zach
    Millermatic 255
    Lincoln SW200
  11. Likes arcflash liked this post
  12. #336
    Mar 2009
    MN
    I know you are doing guide bars for the punch holder. You may want do leave room between the punch holder and the uprights for a wear strip as well so it doesn't wear into your tube.
    My name's not Jim....
  13. #337
    Oct 2013
    Long Island, NY
    Quote Originally Posted by Boostinjdm View Post
    I was thinking if that was worth it, I wasn’t sure what to do there. It’s not a big deal to cut the piece down 1/4” or whatever per side.
    Would you just use a steel strip? Or brass maybe? 1" Wide brass flat bar isn't too pricey. Oilite Bronze is.
    Zach
    Millermatic 255
    Lincoln SW200
  14. #338
    Mar 2009
    MN
    Anything easily replaceable will do. Even if it's just a piece of steel. If you're planning on bolting the guides, just sandwich the wear piece between them and the upright.
  15. #339
    Oct 2013
    Long Island, NY
    Something like this? Thats 1/8" x 1" in the blue. I guess I would have to throw a couple screws in it but that thin will probably not sit flat? Or attach it with VHB tape which is surely easier for future replacements.
    Name:  Hydraulic Press Wide v40.jpg
    Zach
    Millermatic 255
    Lincoln SW200
  16. #340
    Oct 2013
    Long Island, NY
    Think im gonna run with the 1" bronze wear strip taped on with VHB. Just have to cut the holder back 3/16" on each side.
    Im thinking if I use brass it wont wear out the holder from being mild steel on mild steel.
    Zach
    Millermatic 255
    Lincoln SW200
  17. #341
    Cumbria, UK
    Should have a good lifespan as long as the punch is centred.
  18. #342
    Oct 2013
    Long Island, NY
    It should honestly be a pretty even distribution I think but I always strive to work in the center regardless.
    Just cut the ram/holder down 3/16” per side. .125” wear strips and .045” VHB. Rounded up to 3/16.
    Question now, do I put the wear strip on the frame or can I make it even easier and put it taped to the ends of the ram? I’m guessing that is less effective though even if it’s brass since the tube still sees a moving face.
    Zach
    Millermatic 255
    Lincoln SW200
  19. #343
    Cumbria, UK
    definitely on the frame. You need that punch holder to be absolutely stable through its travel even before contacting the material.
  20. #344
    Sep 2008
    Dalton, GA
    Could you use delrin for wear strips? Won’t be that much pressure will there?
    Burt
    _____________________
    Miller Syncrowave 250
    Millermatic 211
    Miller 375 Plasma Cutter
    Hobart Handler 120
    www.10FtDrillBit.com
  21. #345
    Oct 2013
    Long Island, NY
    I could use anything I guess. There could be pressure.
    Would there be a benefit to delrin over brass?
    Zach
    Millermatic 255
    Lincoln SW200
  22. #346
    Less friction. UHMW would work and much cheaper.
  23. #347
    Mar 2009
    MN
    Just cut the ram/holder down 3/16 per side. .125 wear strips and .045 VHB. Rounded up to 3/16.
    Question now, do I put the wear strip on the frame or can I make it even easier and put it taped to the ends of the ram? Im guessing that is less effective though even if its brass since the tube still sees a moving face.
    On the frame. Goal is to confine any wear to replaceable parts. The frame isn't really replaceable. The ends of the punch holder can always be built back up if needed.
  24. #348
    Plus two on the UHMW.
    Various thicknesses available right down to a few mm self adhesive tape.
  25. #349
    Mar 2009
    MN
    If you bolt on your guides, you can just sandwich the wear strip behind them.
  26. #350
    I agree with the umhw cheap easy to replace
Page generated in 1,652,843,297.05107 seconds with 15 queries
