Results 1 to 14 of 14
Thread: Help with welding trailer layout
    Feb 2004
    I bought a ready built welding trailer. I am trying to understand the logic of the bottle rack.
    This is what it looks like in what I presume is the intended usage position.
    If you pull a pin it folds flat like this. I presume this it to make loading and unloading the bottles easier?
    Finally it can stand vertical like this but there is no way to secure it in this position.
    I am thinking of welding the rack permanently in the vertical position. It doesn’t seem like it would be too hard to load that way, and it frees up a ton of space on the trailer.
    I know the acetylene can’t lay flat but aside from that what am I missing on this setup? The manufacturer obviously put a lot of time, effort, and expense into making this rack pivot every which way but I can’t see what benefit it has over just being perfectly vertical.
    Oct 2021
    Re: Help with welding trailer layout
    That is an odd design.. If your bottles are completely vertical, you have so much more usable space on the trailer.
    Pensacola , Fla
    Maybe it to ease the loading of cylinders from the side sliding them in the raise them for storage/transport in the trailer???
    Hypertherm 65
    Everlast PowerTig 255 EXT
    Miler 180 Mig
    13" metal lathe
    Mill/ Drill
    ECT, ECT,
    Feb 2004
    I think that is why it lays flat but I’m not sure why they have it pin in the angled position vs vertical. This apparatus takes up half the trailer. I just like to think about things before I go and seriously modify them.
    If I was going to permanently mount them upright (which makes more sense than on an angle), I would look seriously at mounting them along the outside perimeter on an electric jack. Just move them up and down like an elevator when you want to change them out. You're available real estate seems to be at the front beside the toolbox, but if you mount them there they should have some protection from flying stones.
    Cut 50 Plasma
    Jul 2021
    With bottles mounted in the rack do they stick out any?
    If they do not stick out then maybe they intend for the bottles to be laying down when in transportation? To keep stray rocks from whacking them?
    Have you tried simply calling the guys who built it?
    Airco Auto-Pak 130
    Forney 235AC/DC
    I don't see any real advantage to having the bottles horizontal. Look like the same effort to manage them. However, you have to elevate both bottle vertical at once if on the rack. Not easy if you cannot access the opposite or middle of the trailer.
    Feb 2004
    Quote Originally Posted by Roert42 View Post
    I did try calling them they are still closed for the holidays or something.
    They don't stick out any when vertical.
    I can't remember the details but I know if you lay an acetylene bottle flat you need to stand it up for a certain amount of time before you use it. I don't think it would be good to drive to a job site with them flat, flip them up, and go right to work.
    Feb 2004
    I am with you. Standing two bottles up at once will be heavy.
    Dec 2007
    Los Angeles
    Looks like they off a trailer with the Rack fixed in the upright position too.
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
    May 2011
    Seems like a good idea to the original owner, but in reality, not so useful.
    Huge waste of space
    Feb 2021
    Oklahoma
    I was approached today with a fuel tank/ skid/ welder project, on a trailer. I couldn't for the life of me remember why the bottles for the oxy/acet couldn't be layed flat, but should be at an angle. I thought acet had a diptube. Can someone explain? Is oxy ok flat? I need to be able to back it up with this customer, thanks.
    Being poor is the most expensive thing there is
    Dec 2011
    Tampa FL
    The danger using an acetylene cylinder laying on it side is that the acetone that the acetylene is dissolved in will come out with the gas. The tank is constructed with a porous filler in the tank and after the tank is on its side the acetone will migrate through the porous filler. I have nothing in writing to back this up but I am sure a google search will produce documentation.
    https://ehs.princeton.edu/chemical-s...cols/acetylene
    Mike
  14. Likes snoopdogg, 12V71 liked this post
  15. #14
    May 2007
    [QUOTE=bdog;8842871]I boug
    i wouldnt even consider having them things standing up on the outer traffic side of a trailer/chintsy set-up, like that. if i had to use it, id strap them down flat during trans., and swivel at angle to use.
Page generated in 1,656,134,434.29707 seconds with 15 queries
