Results 1 to 15 of 15
Thread: Welding
    Jan 2022
    Welding
    Can welding with a flux core and a stick welder at the same time on the same piece of metal be done without hurting the machines or the welders using them
    Re: Welding
    Why would you do that?
    Quote Originally Posted by chertzog62 View Post
    Jan 2022
    Re: Welding
    Because I need two people welding and those are they only two welding machines i have
    May 2021
    Landrum, SC
    Re: Welding
    Yes..
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
    Re: Welding
    I agree with Freebirdwelds
    yes
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
    Re: Welding
    Heck yes, I've been on pipeline work with 8 machines at one time hooked up to the pipe.
    Jan 2022
    Re: Welding
    I have metal girders that I am wilding reinforcements on that are all connected by a metal roof so if I connect the ground clamp to one girder I can weld on any one of them. If I have a smaw and a fcaw i have two different polarities. I don't want to use both of them if it's going to hurt my machines, who's helping me or myself
    Jan 2022
    Re: Welding
    Ok thanks I appreciate the info
    Sep 2012
    Wheatland, Wyoming
    Re: Welding
    It is done all the time in shipyards, fabrications shops and large construction projects.
    Chris
    Auction Addict
  10. Likes wb4rt liked this post
  11. #10
    Sep 2016
    Detroit, Michigan
    Re: Welding
    You're trying to use one work clamp for two machines set for different polarity?
    http://mivise.com
    Everlast PowerTig 210EXT
  12. #11
    Jan 2022
    Re: Welding
    Yes that's correct
  13. #12
    Re: Welding
    It depends on the machines. Some machines cannot have the work ground connected to the panel ground. Some of the three phase ARC welders do not like to have their ground clamp connected to panel ground. It causes an internal element to glow. I would check it out just to make sure.
    Some welders will cause the ground wire in power tools to glow red so always check out each machine. Some older ARC welders as well do not play nice with panel ground and other welders.
    Sincerely,
    William McCormick
  14. #13
    Brethren, Mi
    Re: Welding
    Chris. Come to think of it I never did see the actual welding machines at Midland. Did you see them? Isnt it neat now that can do a lot of that work with a machine cost less than that resistor remote had to have 4/0 cable going to. Now could do all that with small wire bout the size those little rod ovens hooked to.
    I was a sprout when we were there, wish I would have paid a bit more attn to some stuff than I did but its a little its own world for sure.
  15. #14
    Brethren, Mi
    Re: Welding
    I am not exact sure what William is trying to say but there are occasions equipment grounding conductors have become pathways for welding current.
  16. #15
    Sep 2012
    Wheatland, Wyoming
    Re: Welding
    They had Lincoln and Miller for stick when I was there. The TIG machines I do not remember the brand. I spent most of my time there running an inspection crew doing weld inspections on pipe hangers. Did a couple trips hiring weld inspectors at east coast and down south. Made my own questionnaire for interviews. !st questions was to describe the sound of a SMAW welding arc. Failed 50% of them with the first question. Did hire about 15 on each trip. Mardi Gras was on and spent a couple days there.
    Chris
    Auction Addict
Page generated in 1,713,305,187.23149 seconds with 21 queries
