Re: any good knockoff welders
I decided to give the little $300 Hit box welder my Kid bought a chance.
Welding up a stand for my 1/2 mill
Even bought a new tank argon/ CO2 mix (Stargon 9?) and New roll of SuperArc 56 Lincoln wire.
At first everything was great
nice welds. But all of a sudden the weld goes cold like the Voltage is dropping off. Literally jamming the wire into the steel.
Small change in Voltage seems OK again then the wire feed starts slipping Ahrrg.
Checked work lead all Good
readjusted - Wow weld looks great and then out of Nowhere stuttering WTH
I finished welding the cart together by short spot welds.
But that is IT.
I am not going to buy any bottom dollar MIG welder.
The ad is still up for the used Lincoln 216 with a CO2 bottle and some extras for $1500.
I can still get a new Hobart Ironman 240 but I am just a little nervous because of some questions about whether it actually welds as nice as the previous 230 model. Also a question on it needing more Input amps than the previous model for the same output.
I have the big Lincoln TIG 300's to stick or TIG weld anything really thick so maybe don't need all 250 amps.?
Lots of welding to do converting some tractor FEL stuff to Skid steer Quick attach and rebuilding a Gannon Box blade. Also Lots of muscle car panel replacement rust repair to be welded in.
I do want to have a spool gun or at least be set up to MIG Aluminum. Which makes a good case for the Ironman,
But have actually been eying the HTP MTS 220. I am a believer that MIG is a Constant Voltage process and therefore does not need feedback or other fixes but... Man this unit looks Very Slick.
Thoughts?
HTP Pro Pulse 220 MTS (Anniversary Edition)
1962 Idealarc TIG 300 300
1974 Idealarc TIG 300 300
1988 HF Power MIG 150
2015 Lotos Ltpdc2000d plasma/Stick/TIG
