Results 1 to 11 of 11
Thread: TIG Filler rod scrap
    Aug 2021
    Not sure if this is just a problem I have or what, but I have noticed a collection of about 20, 3 inch pieces of tig filler wire piling up and I was wondering what most of you do with them. They are too short to be used and fed as they don't fit my hand and also bring my hand very close to the arc. So far I have used them to do tacks but I was wondering if there is a more economical solutions as I probably have roughly 5 feet of them end to end. What do you guys do with the last bit of the rod (I'd assume not everyone throws them out).
    Century FC-90
    Primeweld TIG 200D
    Fredericksburg, VA
    Re: TIG Filler rod scrap
    If you are bored, lay them end to end and do a quick tack to join the ends together.
    Or put the small ends in a set of vise grips and feed the rod that way.
    I would bet most on here are like me and throw them away when they get to 2 to 3 inches in length. My time is not worth it dealing with a 2 inch stub of tig wire.
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
    Dec 2008
    Back in the dark ages I had the same issue with brazing rod.
    I would fuse all the bits end to end.
    Somewhere along the line I got over it...mostly!
    Big Lake/Monticello MN
    What he said
    Syncro 350
    Sep 2015
    West coast of Florida
    Use a pin vise to hold them, also good if you ever use filler diameters smaller then .030". Choose one that has a thru hole if possible.
    Richard
    Website
  6. Likes rhunt liked this post
  7. #6
    Nov 2012
    North Port Florida
    back in '96 at Hobart institute of Welding Technology, I was in the Oxygen and Acetylene Pipe welding class. The instructor told us to weld all the stubs to gether. If it were some thick TIG rods I probably would.
    We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
  8. #7
    Soda springs,Id
    When torch welding and it gets too short I stick the stub in the puddle and tack the new rod to it. Never have any short ones accumulating.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  9. #8
    May 2009
    Lancaster, Ohio
    Waste not, want not. I had to pay for all of the rod, so in the puddle it goes. I just wish it would not drag the tungsten in with it.
  10. #9
    Dec 2020
    Mo
    I was taking all of mine and laying them end to end and welding them together, but it became tedious and a waste of argon so I started pitching them. Will try one of the suggestions and use some needle nose vice grips and use a little more of them up.
  11. #10
    Feb 2008
    At first I thought “you’ve got to be kidding”, but then I thought back to when I was very young, 8 maybe.
    My dad taught me how to pull framing nails out and then straighten them so we could reuse them. This was a guy that lived through the Depression. I still feel guilty to this day whenever I pitch a 16d nail instead of reusing them.
    I don’t feel so bad about the tig rod shorts as it goes to the scrap yard where I buy my steel.
  12. #11
    Mar 2005
    Under a Rock
    I throw them into the forest.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  13. Likes Oscar liked this post
Page generated in 1,713,277,271.39899 seconds with 20 queries
