Results 1 to 24 of 24
Thread: Oxy-Acetylene Cart build using the HTP Inverarc 160 Plus
    Laredo, Tx
    Apr 2016
    CA
    Re: Oxy-Acetylene Cart build using the HTP Inverarc 160 Plus
    Looks good. If you uh, are going to uh, be making uh a YouTube channel uh for teaching and etc to gather a crowd and uh to earn subscribers uh then you might want to uh not use the word uh so much. Personal opinion, it might not bother some people but I know there are others that it will. Sharing is caring
    Southern California
    Nice video and nice build, having everything on wheels really helps in a smaller shop. It takes alot of work to make decent videos, so I can imagine it probably tripled your project time.
    The arc shots were great. Looks like a real smooth little welder. Handy is right on the money. It's always so satisfying when the slag comes off whole like that.
    I agree about watching the "uh"s a bit but it wasn't that huge of a deal to me.
    One hard learned lesson for me about 45 deg. diagonals was to square up the 90's first, and then use the project itself to mark/transfer the 45deg diagonals.
    May 2010
    ct.
    Any particular reason why the tanks are closed in on
    four sides as opposed to the traditional “ three sides
    and chains” design? I realize the tanks are smaller
    than many, but rolling/sliding them in seems much
    easier than lifting them and lowering them in.
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
    Nice vid. Thanks for sharing. Did not notice the uh.
    As far as design? If foot print of tank changes, they may not fit. Lifting tanks can get old, consider a strap or removable bar?
    How does it tilt? May need an extension or bent handle?
    Laredo, Tx
    Uh Not gonna be using it for teaching what so ever I don't care if anyone subscribes really. It's just something to do.
    Quote Originally Posted by jpump5 View Post
    Just personal preference.
    If and when the lifting becomes a problem, I'll change the design for sure. It tilts just fine; the wheels have the back end 1" off the floor, so just with my foot on the 5/8" rod and pulling back the pipe handle up top give just the right amount of leverage to tilt.
    Yea I got tired of not being able to sweep/clean around stuff easily, so almost everything is on wheels/casters now, even the Smithy 1220LTD lathe/mill/drill. I used the suggestion someone made a while back about using the $12 harbor freight wooden mover's dolly. It has four 250 lb casters (that I remove, and throw away the wood) that actually work pretty good! Cheaper than four of their 275lb casters @ $6 each! I even used them for the Smithy, albeit I used 6; four on the headstock side, and two on the tailstock end. Time will tell, but seems to be working out nice. Now I just need to build carts to get my welders off the floor. The design is in the works
  7. Likes N2 Welding, whtbaron liked this post
  8. #7
    A couple years ago several different jobs required diagonals in rectangle. I found it easiest to easiest to mount a temporary clamping system parallel to my horizontal bandsaw blade. Set parallel when the blade is cutting 0 degrees. Then with the saw head set appropriate angle, I could make the second cut in the temporary clamp for its complementary angle.
    Somebody shared that idea many years ago on this forum. I could not understand what they were describing, then. I thought I had come up with great idea, then realizes that is what was described many years ago
  9. Likes Oscar liked this post
  10. #8
    I don't see the diameter of the Acetylene tanks varying, but the O2 tanks can vary somewhat. I notice this on the tanks I exchange regularly.
    One thing.........if your LWS has been using 125cf O2 tanks, and switches to 150cf tanks, the diameter can really change.
  11. #9
    Mar 2005
    Under a Rock
    Nice job on the video.
    Clear arc shots and to the point commentary.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  12. Likes Oscar liked this post
  13. #10
    Laredo, Tx
    Thanks. I have another cart build coming up, but it will be much more intricate since it will hold a few welders on it.
    They literally carry all sizes. From the teeny tiny 20 ft³ to the big ol' 300 ft³ tanks. I'm not worried about it at all.
  14. #11
    Feb 2012
    Thanks for sharing the video arc shots and commentary OSCAR
    Already mentioned by J T
    Constructive critisizm is welcome in my book, hope your not offended however, as mentioned; grammar is important to weldors as they are smart people also, or too? I learned better typing on WELDINGWEB by Roadscholarer Weldors here.
    Ok Oscar , critique and dont take it offensive but just why manifold 3 acety tanks wit only one Oxy?
    I really think its supposed to be the other way. One acety source/manifold with multiple users. Your setup needs more Oxy. Im no expert but I think its wrong if its wrong. No offense and nice cart but also, it should hould mor Oxy than Acety, no?
    Say, Im thinking of a cart build for rough terrain and like the whhells you used. Wher you get them?
  15. #12
    May 2010
    ct.
    More acetylene for running a larger tip without going over max withdrawal rate of tanks?
    Millermatic 180
    Purox O/A
  16. Likes Insaneride liked this post
  17. #13
    Oscar,
    Do you find the acetylene tank pressures self adjust to the same pressure?
    ---Meltedmetal
  18. #14
    Laredo, Tx
    thanks for the feedback. I disagree with your assessment of needing more oxygen. Although I can't say I understand why from the way you've worded it. Perhaps throw in some math/flowrate calculations and we can begin speaking the same language You mentioned "multiple users"; I'm perplexed where this came from.
    Yep.
    The wheels are nothing special. Harbor Freight inflatable 10" wheels, ~400lb load rating each; plenty for the task at hand.
    Oscar,
    They should; that is what I was told by OA Doctor when I asked the same question.
  19. Likes Insaneride liked this post
  20. #15
    Apr 2016
    CA
    How does the manifold make sure the acetylene tanks have the same draw as to prevent one from drawing more or all of the gas while the others are just chilling and have a good laugh. Just being facetious.
  21. #16
    Mar 2005
    Under a Rock
    Tank(s) Pressure.
    Hypertherm PM 45
    HTP 221
  22. #17
    Laredo, Tx
    Tank(s) Pressure.
    Yes I would agree. They are under pressure, so it's not like the torch is sipping from the first tank it sees like drinking a liquid out of straw. All three tanks are "fighting" to release pressure so internally it should equalize.
    I found the email from Jim Billingsley aka OA Doctor:
    There are indeed check valves with a directional arrow on each tank fitting. I'll take his word for it.
  23. #18
    Feb 2012
    I couldnt find the picture showing an acety generator with manifold used with multiple torches but to give you an idea heres some pics with manifolds for a single supply and 5 or so outlets. Top pic is an oxy manifold. Second pic is oxy/acety for three torches and looks like it could support six torches. I did see for huge amounts welding/cutting your setup would be handy but, I still believe you need more Oxy than Acety. A union iron worker told me a easy to remember rule of thumb is 40psi oxy to 6psi acety is good for cutting iron/steel up to 2 inches. I have to purchase my own gas so I look up what pressures I need and tip size for thickness being cut.
    For example: VICTOR charts show 1/2" steel requires 0 tip with 30-35psi Oxy and 3-5psi Acety. Thats approx nine times more pressure from Oxy.
    For welding 1/2" use tip 5 with 6-12psi Oxy and 5-8psi Acety so you see even welding uses more oxy than acety.
    For rosebud use tip 4 with 6-10psi acety and 8-12 psi oxy. Even heating uses more oxy. The chart I used showed acety pressure first for heating nozzle. It also showed flow rates using more oxy. I thought withdraw rates were concern for heating only and thats why they include flow rates for heating but as jpump5 pointed out, withdraw rate when using a large tip can also be a concern.
  24. #19
    At least for cutting the O2 tank is always larger than the c2h2 tank on order to consume both tanks at a close rate. I still use o2 faster.
  25. #20
    Laredo, Tx
    What you're pointing out is a completely different type of manifold. Yours splits the outputs after the regulator assuming the tank(s) can already provide the necessary flowrate for the multiple-user scenario that you are conjuring up that does not apply to me. In my system, I'm using small tanks and combine them before the regulator in order to achieve a higher acetylene capability in the first place. Yes one does have to use more oxygen pressure for pretty much any OA scenario, but also keep in mind that the oxygen tank is filled to 2000psi, so it contains a lot more gas than the acetylene tank that is filled to 250psi, or whatever it is. So basically what you're seeing in your head simply does not apply to my set-up; yours serves a completely different purpose than mine.
  26. #21
    Sep 2009
    ocala Fl.
    Oscar, thanks for posting this video. I have been thinking about getting the HTP 160.
    Miller 252
    Lincoln Square Wave Tig 200
    MM 211
    Red face AC/DC 225 Buzz Box
    Power Max 30
  27. #22
    Oct 2019
    Australia
    Hey Oscar,
    Carts tend to stay in one spot for a days/weeks between moves. Pump up tyres (under load) tend to get a flat spot during this time so you get the old flaboom flaboom when you move it. Ask me how I know!
    Be prepared to change them out for solid wheels...
    Don't forget to update us
  28. Likes N2 Welding liked this post
  29. #23
    Laredo, Tx
    Yea could be. Right now there's a lot of action in the garage since I'm gearing up to hopefully do some small production runs, so I need to be cleaning constantly and hopefully that way I keep them rolling around. The good thing is since the rear bottom tube of the cart is 1" above the floor, a lot of the weight shifts to the front edge, so it will hopefully keep the tires lasting longer like that when it does sit.
    Quote Originally Posted by Thats Hot View Post
    You're welcome. It's a nice little convenient machine to have, especially with that case where you can squeeze in a grinder (maybe even two if it's not too large) and wheels/accessories. Load it up, throw (ie: place) it in the back seat and off you go for small mobile jobs. The duty cycle is pretty good on both 120V and 240V.
  30. #24
    We had a truck mounted camper years ago that used multiple 20 lb propane bottles to fuel the stove and fridge. There was nothing fancy about the setup, just T's plumbed in with on/off valves so you could run one tank or 3 depending on demands and length of time needed. I don't recall having any issues with it, and would frequently fill 2 good bottles to keep the stale dated one functioning.
    Cut 50 Plasma
Page generated in 1,664,161,896.48219 seconds with 13 queries
