Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: I have boat questions...
    Re: I have boat questions...
    Turbo not required. Supercharger and/or N2O... a solid MAYBE.
    JATO! JATO! JATO! JATO!
    Dec 2020
    Virginia, USA
    LOL. You ever see Mythbusters trying to get JATOs? They ended up settling for giant "model" rocket engines.
  3. Likes whtbaron liked this post
  4. #28
    Dec 2020
    Virginia, USA
    What. Great minds think alike. I added the YouTube like BEFORE I went to the site you linked.
  5. #29
    But where's the end to the video??
    Cut 50 Plasma
    Dec 2020
    Virginia, USA
    Apparently YouTube started getting real bad about copyrights and whatever and I don't wanna link to any sketchy websites. That was from Mythbusters episode 197, though.
    They did 3 episodes on the JATO Impala, by the way. I ain't gonna spoil it if you haven't seen them. Start with the first one. They revisited a few years later. Then again few years after that. I think 197 was the last one.
  7. Likes whtbaron liked this post
  8. #31
    Dec 2020
    Virginia, USA
    A tiny little update (I'll start a new thread when I make actual progress):
    So, I THINK I'm going to make the "plumbing" for the jet drive out of stainless steel exhaust tubing. The only "precision fit" I need is around the impeller, and that just needs to fit a plastic sleeve - a wear ring - that the impeller rides in. So it isn't like it's a super precise fit. If it's out by a little bit it'll wear in fast. If it doesn't, I'm sure the first time I suck sand through the jet drive it'll have PLENTY of clearance.
    I figure the tube is thin enough that weight won't be an issue.
    I'm going to choose the wear ring/impeller combo based on whatever is cheapest.
    Heck, some Sea Doo's you can get now push 300HP. I'm making 12HP. Given, I have power/weight ratio on my side, but I think I won't see ANY sort of performance out of it till I swap out to a bigger, way higher output engine.
    I think I'm going to run an electric clutch, since I have an extra one that aughtta be the perfect size. Uncouple at less than maybe 5% throttle, couple after that. Not sure about reversing, yet. I'd have a paddle with me, anyway, so might not worry about it.
  9. Likes Kelvin liked this post
Page generated in 1,664,382,052.62871 seconds with 12 queries
