Results 1 to 3 of 3
Thread: air arc gouging
    Feb 2016
    S. WI
    air arc gouging
    I have the 350 ext what would be the maximum size rod I could use? I believe that it will not put out 350 amps in Stick mode correct?
    thanks
    Brethren, Mi
    Re: air arc gouging
    I would like to see this.
    Nov 2008
    Re: air arc gouging
    Correct. IIRC the stick output is 270A. It is not made to air arc gouge. It will blow up the unit. It is not designed for this type of long arc, high voltage output. It will also void the warranty. So please do not do this if you have one already. You will need the PowerMTS 400 since it is designed for this operation.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
Page generated in 1,713,299,829.07145 seconds with 18 queries
