Re: When the Cat's Away........
Originally Posted by
John T
You continually prove you serve no useful purpose here and apparently need to act like the class clown to get attention. I shall try to just ignore you, henceforth.
Oldiron2
You should have done that from the beginning.
My comments to Sam had nothing to do with you.
So take your self righteous BS and head down the road.
Thank you.
Hypertherm PM 45
1961 Lincoln Idealarc 250
HTP 221
John T
And Samm's comments had nothing to do with you. [Unless you identify with the rats he was berating]
You, the one preaching about the internet, again showing your uselessness and that you can't take the criticism...
I thought I got away lucky. But, while I was installing the battery........................................... .....
I guess it could have been worse. The only chewed wires I could find, on a close examination, were the ones coming from the low oil pressure shutoff switch on the block.
Thank God Lincoln puts a complete wiring diagram on one of the shrouds(whew!!)
One wire goes to the hour meter, and two got the connector block IIRC. Only glanced at the diagram for now.
The wire that goes up to the hour meter is inside a loom that has about maybe 8-10 wires in it..............AND THEY'RE ALL WHITE
Which means I have to completely strip the loom, and trace the wire to the other end. And the damn loom has a fork in it..........geez.
Ohm meter is your friend. 9 volt duracell is also useful for tracing wires. Miller wire harness has white wires with numbers....
cwby
That's too easy!!!!!!!!!!!!!!!!!!! As usual
I wound up doing it the hard way
Now.......there's two ways of lookin' at this...........
One...............Lincoln feels that usin' all sorts of silly colored wires would just confuse folks.
Two.................Lincoln gets a killer deal on WHITE wire.
One final splice to go, and it's a done deal. Figured, since it's about 82* here, I'd stop for a glass of iced tea. Actually, I'm worried about what's gonna happen when I fire it up
Hypertherm PM 45
HTP 221
John T
Maybe if you showed up more
You would realize samm brings this all on himself.
Nobody is ganging up on samm
It just so happens that their are a lot of people in this thread with common sense.
So take your millennial bellyaches down the street.
Thank you.
I guess calling me a millennial is supposed to be an insult. I have no interest in an internet squabble. Won't comment further, I said my piece. Have a nice day.
Hypertherm PM 45
HTP 221
daddy
You as well my friend.
Hypertherm PM 45
HTP 221
https://vancouversun.com/life/style-...nstrual-equity
Guys might want to read this - PMS is a tough struggle for some. My brother used to call it “pack my suitcase.”
My friend’s Lexus threw a “main battery” code and the repair bill was going to be 8-10,000 Loonies and when they got it apart, it was rodent-chewed wires; with a little gum and glue it was repaired. She drives this car every day and the culprit is soy-based insulation. Another wonderful idea from the same gang that brought us the coiled mercury-filled lightbulb that our moronic governments mandated that we use.
Get a grip.
Mice are a constant battle although I seem to be able to keep the rats under control. Having food flavored wiring won't help. My fuel truck sat in the shed most of last summer in between spraying and swathing. When I went to use it, the vents were plugged with interior fuzz, the defrost fan wouldn't turn and the entire air cleaner outside of the filter had been packed full of canola seed. It happens...
Cut 50 Plasma
The motor will start when you put gas directly in the carb, but won't run for any period beyond that little bit of gas. It won't start on its own. When cranking, it puts out a mist/vapor cloud from the exhaust.
I believe,, although I can't exactly remember, that the motor would start on its own yesterday. This was after repeated priming to make the fuel pump eventually draw gas from the tank.
So anyway.............. Acts like not getting gas.
Having owned the welder for about 14yrs, I'm used to this possible issue, and know where to look. If you look, you can see beaded water on the air cleaner plate(circled), and inside the bore of the carb on top of the choke plate. The gasoline is full of water.
Gas from the gas can on left..........gas from the tank on right. The welder isn't level, and the water probably was on the down side yesterday. Add clean fuel, and only the clean fuel draws. Let it sit a day, and the water emulsifies in the clean fuel. Now you have water saturated fuel.
Luckily, there's only a couple of gallons in the tank. I'll tilt it so that I can get most of it out with a siphon, then refill it with clean gas. It's not surprising that the tank has water in it. It's been sitting empty for a very long time.
An added note: Had the LWS check on PC boards for this machine (it has 2). The main board is $300 . It's nice to have an old machine
He thinks that I shouldn't need any boards. I guess I'll find out when I solve the fuel issue.
Hypertherm PM 45
HTP 221
John T
Subtle hint.
Filled 3 partial buckets draining the tank. Look carefully at the bucket sitting in full sun, you can see the water separating out of the gas. You can see the darker band on the bottom of the bucket.
Used the Uranus TD211 for the task.
A very long length of brake tubing attached to a small hose. Made it up years ago. Mostly use it to siphon water off the bottom of my diesel nurse tank, but it's handy for any tank that needs draining..........provided the filler neck allows for its insertion.
A midstream sample as the draining process started. A bit o' water.
Another midstream sample near the end of the process. A very tiny bit of water at this point.
I run 100% gas in my power equipment. You can see here, that it's beneficial. The water will stratify to some degree, instead of emulsifying. But sometimes it does emulsify if there's enough water in the tank for a long period of time. I probably could have quit draining the tank at the time I took the second sample.
Looks like we gots liftoff
Runs good with the choke out…..
Hypertherm PM 45
HTP 221
And it won't shut down unless you put your hand over the carburetor intake
IIRC..................sometime a while back, if ya took the time to read it.............the shutoff solenoid is bad. Tain't done with it yet. Need to find the damn thing before I can replace it. Got it years ago, and it's floatin' around somewhere in the shop, or the house.
farmersammm
Yeah I read that.
Iffin it were me….
I would take that carburetor off and give it a good cleaning.
And I would also replace that gas filter even though you obviously have some kind of emotional attachment to it.
I’ll probably forget about the shut off solenoid also.
Just put a quarter turn gate valve in the gas line
When you want to shut it off just turn the gate valve
It will run itself out of gas.
That will eliminate SOME Of the gas in the carburetor… for the next time you let it sit for two or three years.
Hypertherm PM 45
HTP 221
Brother had a Miller with a Kohler & bad solenoid. He used to pull a spark plug wire to kill it. Had to be pretty tough to do that.
cwby
That makes no sense, if the ignition is "off" there should be no spark. The "shutoff" solenoid on the Kohler was only intended to keep the engine from filling the exhaust system with gas fumes as the engine spun down and creating a backfire in the muffler. Had nothing to do with stopping the engine.
12V71
Interesting.
I can see that.
Hypertherm PM 45
HTP 221
John T
Interesting.
I can see that.
I'm sure you do
Now, I could explain it to the two of you, but it would be a waste. Y'all don't know what you're talking about.
A fuel shutoff solenoid is exactly what the name says. It shuts off fuel to the carburetor. It has nothing to do with shutting off fumes. IT SHUTS OFF GASOLINE THAT CAN BE DRAWN INTO THE CYLINDERS WHEN THE MOTOR IS SHUT OFF. The welder will go into high idle at the same time the engine is shut down, and fuel shutoff solenoid activated. I assume there is spark during this high idle, because the engine does not backfire. The little bit of remaining fuel, sucked into the cylinders, is burned before it reaches the exhaust. Probably controlled by the control board, but I'm not sure about this.
A common no-start on these engines can be caused by the fuel shutoff solenoid sticking closed, or a bad coil in the solenoid preventing the needle from coming off the seat. Another problem is run-on if the solenoid doesn't allow the needle to seat.
My welder has had the problem for quite a while before I put it up. It would not start,, or would run lousy after starting...............bang on the solenoid,, and it would start and run. Also..........................the engine would not shut off without me closing the choke all the way. High idle, but fuel still getting to the cylinders. It just runs on at high speed. Turning the switch off does not make the motor shut down (this goes to my theory that the board supplies spark at shutdown). Again, banging on the solenoid would make it stop running.
Because I told ya what you need to know, which ya won't believe, I found ya a video or two. I really hate to see people labor through life with lack of knowledge, let alone spread it as Gospel.
Watch the moving pictures boys
