Page 1 of 8 123 ... LastLast
Results 1 to 25 of 188
Thread: When the Cat's Away........
    Decided it was time to get the engine drive going again. I can't remember the last time I used it. It's been literally YEARS. I did fire it up last Summer, but the shutoff solenoid doesn't work right. SO I KNOW THIS WASN'T THE SITUATION LAST SUMMER.
    The entire damn machine is packed with rat sht, and twigs/leaves. All of the windings are completely full of rat sht. All of the transformers are packed with rat sht.
    I'm at a loss as to where to begin.
    None of the wiring seems to have been eaten, so far........................ I don't believe an air gun is the answer. It would probably drive the sht into areas I'll never be able to access. My first thought is to shop vac the entire thing.
    I'm worried I'm gonna have to entirely disassemble the ENTIRE F'N MACHINE to get to all the crap. I have the sides completely off, and the only thing left is the base......which I'm afraid means removing the motor, and bigazz alternator (or whatever it is)........the generator I guess.
    I have absolutely no idea what's safe to touch. I've no idea whether this thing has capacitors in it.
    This all got started because we have a pretty severe ice storm forecast for Wed. I figured I oughta get the thing going for backup power. And, I'm also gonna use it for the crane build (I can't sit around and worry about the health sht all the time, it's time to get up and do something).
    Man, I tell ya................I hadn't figured on this crap
    Re: When the Cat's Away........
    Anyways..................this is where it's at for the moment......... I've got it striped down as far as I want to for now. Some of the crap was removable by hand, but the rest has to be Hoovered I'm thinkin'.
    I'm worried about that crap shorting something if I don't find it all, and get it out. And I'm worried about the damn thing catching on fire if the hidden crap dries out when the welder gets hot. This is a real f'n disaster.
    Jan 2005
    Reminds me of a certain Clausing lathe..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  5. Likes farmersammm liked this post
  6. #5
    Jan 2005
    I am sure Roy would send a lighting bolt to start the fire, just to show you he still cares..
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  7. #6
    Just thinking out loud, so to speak, but those things are designed to sit in the back of the truck while you're doing speed down the highway through a downpour. They don't get transported around in enclosed trailers, after all.
    Thus.... I would think everything in there is safe to touch or it would have been shorted out the very first time it got rained on. Water gets everywhere given enough time, and if there was any way something could short or whatnot... it would have happened already.
    Personally, I'd put it up on blocks and hose the snot out of it with as much pressure as you can get. Then when it dries, have a good look-see everywhere, with a flashlight, and then hit it again with the hose.
    Three or four good washings, each one getting a little more of the junk out of all the nooks and crannies, should do you right.
    But what do I know? I could be entirely wrong about their water resistance.
  8. #7
    Brethren, Mi
    I wouldnt water it, would vac and air blow.
  9. Likes whtbaron liked this post
  10. #8
    Check under flywheel if you have a stator and magnets before starting. Had a mower that shattered magnets because of debris. They like my muffler too.
  11. #9
    This is why I have a nicely rocked, sterilized yard with no vegetation within 200 yards. I could just imagine the uproar of something like that happening to customer equipment. Having 3-4 stray cats eating rodents helps too.
    Oh yeah, back to the problem, I would repeatedly soak it with a garden hose to loosen the dried stuff then use a hose nozzle to wash it out. A bit of detergent will help loosen the stuff. No high pressure washing. Blow with air and allow it to air dry. Done quite a few Big gensets that way.
  12. Likes _Weldman_ liked this post
  13. #10
    Mar 2005
    Under a Rock
    What a shame to neglect a good piece of equipment like that.
    Ya know, half the problems you seem to encounter in life could probably be avoided if you learned how to take care of things properly (lawn mowers/weed wackers/chainsaws etc etc)...... Geeze Louise
    No excuse for that IMO
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  14. Likes _Weldman_, Munkul, 12V71, Rondo liked this post
  15. #11
    Without my problems, you'd have nothing to talk about. You do nothing,, contribute nothing....................a carbuncle on the butt of society.
    It's a shame to be you.
  16. Likes shortfuse liked this post
  17. #12
    Yup, I keep my stuff full of "Tomcat" bait chunks and the smaller stuff inside where the shop cats control the mice. Learned my lesson years back when the rodents ate a $3600 transmission control harness on the D6M dozer I had. Only took a 4 day weekend for that damage. (cottontail rabbits). Killed 2 of them with a ball pein hammer when I opened the battery box door, kind of a "deer in the headlights" thing when the sunlight hit them in the face.
  18. Likes _Weldman_ liked this post
  19. #13
    The usual crowd piles in...............Geez doooooods get a life. Go have sex with yer wimmmen.
  20. Likes _Weldman_ liked this post
  21. #14
    Mar 2005
    Under a Rock
    Seems I hit a nerve...
    Thats OK, I still love you Sammm
    Hypertherm PM 45
    HTP 221
  22. Likes _Weldman_ liked this post
    Dislikes 32Jim disliked this post
  23. #15
    Warfarin doesn't kill dogs, the new stuff will. I like my pup. So..........................what kin I tell ya? We live with the problem. Sux, but we do. K'kins would go into depression if Peanut was poisoned. I would too. We're good people, and we try to live a good life.
  24. Likes Shootr liked this post
  25. #16
    Don't like ya, never did(shrug)
  26. Likes _Weldman_ liked this post
  27. #17
    And you turn Crybaby every time you ask for advice...
  28. Likes _Weldman_ liked this post
  29. #18
    May 2021
    Everything fell into the cracks and crevices by gravity cause the mice don't move the **** in there they just drop it, so flip it upside down and suck or blow it out and it will be cleaned by gravity too.
  30. Likes 12V71 liked this post
  31. #19
    Mar 2005
    Under a Rock
    You think I don't know that??
    I can read you like a book... Unfortunately you are trapped in my lair of wit and semi humorous sarcasm.
    Hypertherm PM 45
    HTP 221
  32. Likes 12V71, Bud1 liked this post
  33. #20
    Southern California
    I would drain it of fluids (You're probably going to want to change them anyway)
    rotate it sideways or even upside down if I could, use air and a stiff brush
    and then a hose with a decent nozzle if there was anything left.
    Driving it around and getting it bumped around a bit (back of a truck or towed) before diving in also would help loosen some stuff, and get all the bigger live residents evicted
  34. Likes _Weldman_ liked this post
  35. #21
    May 2021
    Forgot to mention, rat/mice feces can cause pink eye and lung infections, so wear some goggles and a respirator.
  36. Likes 12V71, whtbaron liked this post
  37. #22
    Geez guy, you ever get tired of the same wheez??????????????? Advice is what it's worth, and I generally do well not heeding yours(shrug).
    I do a post, and it's a story. It's a journey. You're watching the solution as it happens. I really don't want your input. Ya haven't gotten it by now? I do sht on my own, always have, and it always works out. You're not in the loop man...........
  38. Likes Shootr liked this post
  39. #23
    Quote Originally Posted by _Weldman_ View Post
    Was the first thing I thought about. Digging around in the nest,, and moving the sht................... There's some nasty stuff in that rat stuff. I hear ya, and I think you're on point.
    Washed hands immediately after handling all that crap.
  40. #24
    Soda springs,Id
    Old gennie repairman showed me a trick yrs for a gennie that got damp. Take all the brushes out of their holders, start it and run for a few hours and let the cooling fan dry everything.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  41. Likes farmersammm liked this post
  42. #25
    Apr 2011
    minnesota
    My initial thoughts are too tip it upside down. Drain all the fluids shake all the loose crap out of it. Hopefully they didn’t get in anything important. Mouse and rat urine is so corrosive.
    Millermatic 252
    millermatic 175
    miller 300 Thunderbolt
    lincoln ranger 250
    smith torches
    lots of bfh's
  43. Likes farmersammm liked this post
Page generated in 1,713,307,297.52998 seconds with 20 queries
