I'm going to build a simple project that will use (2) lengths of tubing 18" long each on a horizontal plane (Total extension 36", but rarely extended past 30"). It will be mounted to a vertical 2" square 16ga tube approx. 30" tall. Something along the lines of this:
I want the cantilever portion to be the best combination of strength and light weight. The maximum weight at the end of the structure will be no more than 15lbs (most likely 7lbs).
I'm looking at 2" square tube, or 1-7/8" round tube - 16ga each, as the possibilities. In your opinion, which of these three options would be the stiffest bet:
*The round tube
*The square tube with the flats parallel to the ground
*The square tube with the flats at 45deg to the ground (diamond orientation?)
The end of the tubes will be welded to vertical pieces of 1-1/4" solid steel shafting, which will be held with pillow blocks top and bottom of each shaft.
*The round tube
