Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: Ck Worldwide - Glycol coolant torch performance & Good technical support
    Mar 2005
    Under a Rock
    Re: Ck Worldwide - Glycol coolant torch performance & Good technical support
    It’s simply a discussion
    which is what normally happens on a forum.
    I don’t think anyone is particularly hot and bothered about it besides you.
    Maybe you need an iced coffee or something to “ cool” yourself off.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Oct 2016
    I would use tap water, but since it freezes hard in winter around here, went with this stuff
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It is clear fluid- no color at all. maybe there is something special about it?
    It did not freeze when temps went below 0F
    Cost more than regular antifreeze but not as pricy as Millers fluid.
    I would have tried Dex cool but read a pretty heated thread on another board that advised against it.
    HTP Pro Pulse 220 MTS (Anniversary Edition)
    1962 Idealarc TIG 300 300
    1974 Idealarc TIG 300 300
    1988 HF Power MIG 150
    2015 Lotos Ltpdc2000d plasma/Stick/TIG
    Victor 100 torch, 200- 210 Oxy/Acet gauges
    Mar 2022
    Massachusetts
    TAP Water ran thru the torch (Chlorine, Minerals, and all) then dumped into the drain. Worked Fine... [...] Sometimes you guys like to make Very simple stuff much more complicated than they should be. I don't know Why!
    Pretty simple. If you run tap water through a torch and dump it in the drain, you don't have stagnant water to grow microbes, and it's probably warm enough that your torch isn't going to freeze. A cooler sitting the winter in a freezing garage has different needs.
    Mar 2022
    Massachusetts
    Quote Originally Posted by 455dan View Post
    Yeah, I bought a few gallons of this a few days ago.
  5. #30
    Nov 2013
    OMG?? Hot & Bothered???
    Who ME???
    DuDe, I didn't want to get anybody defensive or anything, why did You?
    Look, if it's coming down to "which should I be using, Distilled or Deionized?" ya gotta admit, it all sounds pretty silly ~ doesn't it? Is it just Me?
  6. Likes John T liked this post
  7. #31
    Mar 2022
    Massachusetts
    Who ME???
    Looks accurate.
  8. #32
    Jun 2008
    Central California
    Very little is that simple, and some people who have seen problems can tell you in detail why so. Besides the growth of microorganisms leading to clogged passages, or mineral-bearing waters allowing them to deposit on surfaces, reducing heat transfer, one can have intergranular corrosion of torch and cooler parts. I know of instances where just running tap water through the torch can increase radiation of interference that is picked up by nearby radios and sometimes, other electronics, leading to outside complaints.
  9. #33
    Nov 2013
    Quote Originally Posted by Oldiron2 View Post
    OK but, let me again give you MY anecdotical experience, I have decade old DexCool in my cooler and have No microorganisms (VW Beetle paper fuel filter would have gotten clogged if I did), no Corrosion, No Minerals (distilled water) and was certainly Not advocating for the use of Tap Water (at least in a CK torch where I believe the passages in the head are much smaller than there were in those days when we did). Seems pretty Simple from where I'm standing but, maybe I've just been Lucky!
    I'll admit though, never had a single thought towards Radio Interference
  10. Likes John T liked this post
Page generated in 1,713,312,041.48781 seconds with 19 queries
