Results 1 to 6 of 6
Thread: I have a voltage question.
    Brethren, Mi
    I am right at the panel, I never thought to run drop test but was curious why I needed to turn the machine up a little. So I check, standing 247 with 122 on one leg and 124 on the other. Seems its a pinch higher actually than the last time I checked. I got some big fat wire from the tranny, no load considering the feed. How much are legs typically out of balance? I could understand if there was some significant lopsided load and have seen that.
    I went to a park, they had events, was a small place and all of a sudden they had vendors and by some mere fate had a 60 from a long wire and 49A on one leg and 1 on the other. Right now I cant recall what the voltage was but we move a plug or a breaker maybe and got the beer trailer on another leg and it spruced right up.
    Outside of Raleigh, NC
    Re: I have a voltage question.
    All of the ones that I've measured have been within 0 - 2 volts at the feed with no load. Depends on if other houses are hooked into the same transformer.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Brethren, Mi
    I am 2 with no load and only service on the tranny.
    Your power company will hold the voltage +- 10% approximately.
    Mount Tabor VT
    Center tap is halfway between ends of the secondary coil. Sometimes it isn't exactly center. No load imbalance of 1 or two volts doesn't concern me. Loaded imbalance of more difference than 1 or 2 volts probably indicated a bad connection in a line from the transformer, most likely the center tap, or neutral. Keep an eye on it, damage is costly.
    Mount Tabor VT
    If it is the neutral conductor failing, test voltage two ends of the phase under load. They should be near 240, maybe 230 if long, or heavy load. Then check each line to neutral. I do not want to see more than the same 1 or two volt difference.
Page generated in 1,713,243,393.13209 seconds with 18 queries
