Page 2 of 6 FirstFirst 1234 ... LastLast
Results 26 to 50 of 145
Thread: Better ground clamp?
    Re: Better ground clamp?
    Looks great.
    It well work for a long time .
    The copper jaws will wear out but just buy new one..
    FYI my cable ends I solder in it last far longer than crimping and for replacement just de-solder.
    Quote Originally Posted by NotaVegetarian View Post
    Hope this was the problem. Checked the cable at the ground clamp. You could see where it had arced between the nut and the cable end it was loose too. A little dissembling an cleaning reassemble test run works like it should.
    Attachment 1738137
    Southern California
    I always keep a nice adjustable wrench set (6" and 10") with my welder for gas connections.
    -Make sure it's a decent set, the softer metals will thank you and you'll curse yourself if you ever round one off. I've had good luck with crescent brand adjustable these days, but of course they still are not as nice as vintage made in USA.
    I also use it to check my ground cable connections about every week if I'm using the machine all the time, or whenever I use it if it goes a long period of time without use.
    The heat cycling, dissimilar metals, and usually lower tension (double nut setups are usually excluded) all lead to the connection inevitably loosening over time.
  3. Likes NotaVegetarian, 52 Ford liked this post
  4. #28
    So what your saying is he really needs a new impact wrench and socket set to keep the nut tight...
    Dec 2020
    Virginia, USA
    Just weld the nut on the ground clamp.
    Sent from my SM-G781U using Tapatalk
  6. #30
    Mar 2005
    Under a Rock
    I use these buggers on the mig/plasma/stick
    They are very convenient
    On the tig machine I use the stock clamp since magnets don’t stick to aluminum …. Usually.
    PS,
    Lillian says hello
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  7. Likes Freebirdwelds, whtbaron, 52 Ford liked this post
  8. #31
    Jan 2022
    Sugarland, GA
    Well
    got it all cleaned and reassembled slid some shrink wrap the handle to help support the cable
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14” Saw
  9. Likes wb4rt, Louie1961, Lis2323, whtbaron, John T, 52 Ford liked this post
  10. #32
    Mar 2005
    Under a Rock
    Well
    Looks good.
    Hypertherm PM 45
    HTP 221
  11. #33
    PS,
    Lillian says hello
    Gotta say John... that's a nice pair of clamps...
  12. Likes NotaVegetarian liked this post
  13. #34
    Jan 2022
    Sugarland, GA
    PS,
    Lillian says hello
    Have to admit that will get an arc started
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  14. Likes whtbaron liked this post
  15. #35
    Mar 2005
    Under a Rock
    That was 43 years ago.
    Who knows what she looks like today
    Hypertherm PM 45
    HTP 221
  16. Likes 52 Ford liked this post
  17. #36
    Jun 2017
    AJO, ARIZONA
    I like the copper contacts on that clamp.
    After I filed/sanded the nuts and the lug to clean them up and remove any burrs from arcing, I think I might coat them with some grease (or better yet, copper-based anti-seize) before cranking the nuts down good. This might delay you having to disassemble and clean them up the next time.
    The braided copper inside the clamp came apart and frayed badly on mine & I wasn't close to any place that sold ground clamps, I had an old set of booster cables that were junk so I robbed three trands of the fine copper wire in themand braided them together and bolted it on both sides & it worked really well, I think the wires wer #6 or 8, cheapie cables. The clamp seems to stay cooler too.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
  18. Likes whtbaron liked this post
  19. #37
    We all get older... that's why our eyesight "adjusts" naturally....
  20. Likes N2 Welding liked this post
  21. #38
    Dec 2020
    Virginia, USA
    Careful with cheap jumper cables. I almost bought a set of #4 cables a few months ago. Nice clamps. Really nice insulation... BUT it turns out they had copper plated ALUMINUM wire. Copper has about 60% of the conductivity of copper (according to a quick Google search)
    So they'd conduct like something around an 8 gauge copper cable.
    I was just buying the jumper cables for the wire - I was going to make an extension for the ground on my MIG and my plasma cutter.
  22. #39
    Yep, most of the cheaper ones are copper coated aluminum now. I'm still buying them to store in the vehicles, because they'll still get you out of bind better than the nice copper ones hanging in the shed 50 miles away.
  23. Likes Meltedmetal, 52 Ford, 12V71 liked this post
  24. #40
    I know the topic is ground clamps but this is what I do with jumper cables to keep them from tangling ....
  25. Likes whtbaron, 52 Ford, NotaVegetarian liked this post
  26. #41
    Brethren, Mi
    Should be a good lesson here,,,, guy can speculate, can type pages, can spend money, can spend others money or he can tighten a loose nut.
  27. Likes 52 Ford, Munkul liked this post
  28. #42
    Brethren, Mi
    That is a gread cable idea.
  29. #43
    May 2021
    Landrum, SC
    After I saw where this thread was turning I had to start a jumper cable thread. lol
    https://weldingweb.com/vbb/threads/7...04#post8856904
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
  30. Likes whtbaron liked this post
  31. #44
    Quote Originally Posted by Freebirdwelds View Post
    I'll have to see what I can do to sidetrack your jumper cable thread. lol
  32. #45
    Nov 2012
    North Port Florida
    The magnetic ones look cool, but I weld aluminum from time to time. cant load a picture but I just crimp a 1/2" copper lug to the cable and bolt it to Vise grip.
    We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
  33. #46
    Dec 2020
    Virginia, USA
    Quote Originally Posted by welding1 View Post
    If it's thin aluminum, you can stick a piece off steel on one side of the aluminum and the magnet on the other.
    Having quick couplers on your leads so you can swap out your ground clamp is nice. Run a magnet when you're sticking steel and a clamp when you're dealing with aluminum or nonmagnetic stainless.
  34. Likes whtbaron, Freebirdwelds liked this post
  35. #47
    Like this ....
  36. Likes Freebirdwelds, 52 Ford liked this post
  37. #48
    Will the next thread be about winches or receivers?
    Feb 2012
    About jumper cables, welders and trains; there was a weldor here that said someone in Montana I think, needed his train jump started with a welder. The dude had a big engine drive MILLER but didn't want to chance frying a rectumfier on his machine. Don't blame him.
    However SA200's were used to jump start other SA's. There's videos in the archives. I think an SA could jumpstart a train if the batteries weren't shot out.
  39. Likes whtbaron, 12V71 liked this post
  40. #50
    Sep 2016
    Detroit, Michigan
    I've used many of the work clamps from Harbor Freight and never had an issue. I have seen one or two that the jaws didn't line up well so I always check that when I pull them off the rack.
    Go ahead guys...get all upset now over proper terminology.
    http://mivise.com
    Hobart Champion Elite
    Everlast PowerTig 210EXT
Page generated in 1,713,277,089.58404 seconds with 20 queries
