Results 1 to 5 of 5
Thread: Lincoln Weldenpower 225 Code 9010
    Nov 2021
    Post Lincoln Weldenpower 225 Code 9010
    The output of this welder when running is only 50 volts at the 110 AC outlets. I only get a small spark at the stinger. The DC power at the slip rings is 31 Volts. The output from the stater excitation winding is only about 18 Volts measured between leads 4 and 5 at the full wave rectifier diode. I would appreciate any help on what to look for from here.
    Nov 2021
    Re: Lincoln Weldenpower 225 Code 9010
    If anyone knows what the correct output is for the exciter winding and for the slip rings I would greatly appreciate that information.
    Dec 2014
    Wasilla, Alaska
    Lincoln customer service is very helpful, and duaneb55 and ccawc are helpful on this site.
    May 2008
    Orange, TX
    I don't have the specific values you're looking for but voltage across leads #4 and #5 is AC if you weren't already aware.
    With an almost doubled voltage thru the bridge rectifier makes me suspect it may possibly have one or more failed diodes and giving you false readings. Have you disconnected it and tested for such?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jun 2022
    I own a machine just like the one you have and had a problem that sounds much like yours. The problem was one of the positive diodes had failed. I replaced both positive diodes and the problem was solved. I’m just a welder and not a mechanic, but I hope this helps.
Page generated in 1,713,290,840.12505 seconds with 18 queries
