Results 26 to 50 of 61
Thread: Root pass on copper backing
    Oct 2019
    Australia
    Re: Root pass on copper backing
    Buuurp!
    I guess no photo.
    Quote Originally Posted by thruwall View Post
    Ya I figured as much just a bunch of drunk mr know it alls.that really know nothing, se ya
    Oct 2019
    Australia
    Instead of being a braggin smart a. Why don't you post up a pic of what you're doing so we can understand.
    We can't all be super geniuses like you.
    Jun 2017
    AJO, ARIZONA
    Wow, that was a pretty harsh judgement for people you don't really know.
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    LET'S GO BRANDON!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
  5. Likes 12V71 liked this post
  6. #30
    Jun 2008
    Central California
    I got a 4x3 open root pass I need to copper in with 1/16 dualshield mild steel wire any ideas
    I don't know or care what certifications you have or how good a welder you are (per other thread), and although you sometimes seem capable of writing intelligibly, this sentence looks like either a second-grader (from my era, anyway) wrote it, or it was a quote on a police report about a drunk-driving arrest. Are you trying to prove some point, or does some medical problem give you frequent dizzy spells?
    If this was a serious question, please write so I (and other interested readers) can understand it.
  7. Likes CAVEMANN, 12V71 liked this post
  8. #31
    May 2021
    Landrum, SC
    So I take it your getting off the pot?
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Magnum PRO 250LX GT Spool Gun
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Everlast 62i Plasma Cutter
    Ingersoll Rand T-30 14hp
    Instagram: #Freebird Welds
  9. Likes 12V71, CAVEMANN liked this post
  10. #32
    I agree
    Quote Originally Posted by Woznme View Post
  11. Likes CAVEMANN liked this post
  12. #33
    Apr 2022
    I agree
    JUST GOT BACK FROM THE STORE BOUGHT SO,E MOTHERS DAYS GIFTS FOR woznme, smithdoor, psacustomcreations, villageblacksmith,and freebirdwelds I GUESS BETWEEN ALL OF YOU SINCE THEY HAD A SPECIAL ON A 6-ROLL PACK MAYBE BETWEEN THE FIVE 5 OF YOU YOU COULD FIGURE IT OUT. I WILL NOT MAKE IT ANY MORE DIFFICULT AT THE BOTTOM OF THE OPEN CAVITY NOT ADDING THAT IT OPENS UP ON TOP OF A DIVIDING WALL, DIVIDING TWO PASSAGES WITH 1/2 INCH RADIUS THAT MUST BE COPPERED IN ALSO? HERES YOUR FIRST CLUE-EMPLOYER WOULD NOT LET YOU DO IT OR ATTEMPT TO DO IT WITH 1/16 DUAL SHIELD WIRE. 5/32 SMAW ON 1/4 INCH THICK PIECE OF COPPER WELDED TO A 3/8 IN STEEL ROD AMD 1 HELPER IS ALL YOU GET. YOU DONT NEED NO DAM PICTURE NO PHOTO, 4X3 OPEN ROOT BOTTOMLESS CAVITY 4" DEEP!
  13. #34
    Oct 2019
    Australia
    For me? you shouldn't have. I mean really, I don't like flowers, you should have saved them for your mama. Although she doesn't deserve them either because she couldn't see you taught English very well.
  14. Likes 12V71, CAVEMANN liked this post
  15. #35
    May 2022
    New York
    I never knew why exactly but we used to use copper backers on full penetration moment connections and beam splices where the backer had the be removed as in bridge code then we were told we couldn't use copper anymore and for a while we use ceramic chiclets which cams on foil with adhesive. The ceramic work great except i alway clamped something under because sometime the glue got to hot and the weld could suddenly fall out on you. Then we couldn't use the ceramic any more and had to use compatible steel backing bars which had to be gouged off after. I assumed the copper got prohibited because it might alloy somehow with the root pass, it was a shame because that stuff worked well - this was all flux core no gas. i got really sick of carbon arcing backing bars with crap access and then having to fill tiny digs with stick where use couldn't see it let alone get a grinder to it - so all tedious die grinding and little fill until the inspector gets tired.
    Would ceramic work in this situation? The dual shield wire can weld over it's own slag somewhat because the flux does not gasify to create a shield. I too would like to see a picture and a weld procedure.
  16. #36
    I do disagree with Woznme on school or books. The rest time we are same page. It education is need in this field.
  17. #37
    Wow. Just like the crazyazz girlfriend that keeps coming back….
  18. #38
    May 2022
    New York
    Here's the real thing the original poster did not describe the field conditions with enough specificity. Presumably there is print maybe not because it's a defect but in such a case most of the time there would be a request for information (RFI) submitted so an engineer could specify a weld procedure in consultation with welding contractor with full knowledge of the field conditions which here appear to include limited or no access to the back side of the weld. The stubborn refusal to provide information after you ask a question is a little strange. Weld procedure = fill up the hole with weld metal flush to the back of the hole that's one giant stress riser in what may be a crack prone section "cast mild steel" 3-Ps preheat post-heat & Pray.
  19. #39
    Fredericksburg, VA
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Miller Spectrum 625 Plasma
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  20. Likes Lis2323, 12V71, Freebirdwelds, CAVEMANN liked this post
  21. #40
    Fredericksburg, VA
    It is about time for another one of these characters to join. It's been a while.
    Millermatic 252 MIG
  22. Likes Lis2323, 12V71 liked this post
  23. #41
    Apr 2022
    How do you weld copper and steel together. Might be a skill I need.
    Ancient Chinese Secret!
  24. #42
    I think (RFI) he talking is Radio France Internationale or Radio Frequency Interference.
    CG stands for crazyazz girlfriend or center of gravity.
  25. Likes Munkul, Eelspike liked this post
  26. #43
    Maybe this book will help you find the answer.
    https://www.amazon.ca/How-Win-Friend...45153110&psc=1
  27. Likes Freebirdwelds, 12V71, CAVEMANN, whtbaron liked this post
  28. #44
    Judging from the OPs form of sentence structure hopefully it's available in audio form.
  29. Likes CAVEMANN liked this post
  30. #45
    There is no three abbreviations.
    Just a real wordy boring book too.
  31. #46
    Beer and good Brisket works too.
  32. Likes Lis2323, CAVEMANN, whtbaron liked this post
  33. #47
    Doughnuts work too.
    Next you pull over just box of Doughnuts 🍩 and coffee ☕.
    Unless you are good looking girl 👧 then just show will do.
  34. Likes Freebirdwelds, CAVEMANN liked this post
  35. #48
    Jun 2017
    AJO, ARIZONA
    I think the OP has discovered that he's a "WELDER MY A$$!" He had to ask about the open weld with a copper backer, but in the other thread or on the other site said he was an expert, expert is defined as "EX" is a has been, and a "SPURT" is a drip under pressure, The drip has dropped!
    NRA LIFE MEMBER
    LET'S GO BRANDON!
  36. #49
    Jun 2017
    AJO, ARIZONA
    You guys ever think we need laughy face emojis and memes available with the like/dislike "buttons" for this kind of stuff? That way we could just laugh at them without having to create a reply.
    NRA LIFE MEMBER
    LET'S GO BRANDON!
  37. Likes 12V71 liked this post
  38. #50
    May 2021
    Landrum, SC
    Doughnuts work too.
    Next you pull over just box of Doughnuts  and coffee ☕.
    Unless you are good looking girl  then just show will do.
    Even better if a good looking girl brings you doughnuts......or a sandwich. lol
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
Page generated in 1,656,519,257.78100 seconds with 12 queries
