Results 1 to 25 of 27
Thread: Arc blow
    Nov 2004
    Missouri
    Arc blow
    Tried everything but couldn't eliminate it. Maybe cant eliminate it in such close corners, don't know. Material is mild steel 2" X 3/8" about 18" on each side. Using 5/32 7018.
    Trailblazer 302
    Hobart Stickmate AC/DC
    Lincoln SP 135 T
    Smith torch
    Spoolmatic 30A
    Re: Arc blow
    I thought I heard the cure for arc blow was AC welding. You tried that and it didn't help?
    ---Meltedmetal
    Jun 2008
    Central California
    Re: Arc blow
    I agree with the AC comment. Also, in what order were the parts welded? All inner sections placed and tacked before main welds were made (thus in tight quarters)? If so, might it have been better to mark the outside where the inner ends would go and starting near the two outside corners, fully weld each one in turn so only the last center piece had less room?
    What do these have to support, just people, lawn equipment wheels, automobiles/trucks, or nothing? Where are they designed to go; triangular is not common.
    Nov 2004
    Missouri
    Re: Arc blow
    The triangle shape was welded up first and then the bars were set in from the outsides and progress toward center alternating from one side to the other. Tried AC a little but I have trouble with 7018 on AC and didn't have any AC7018.
    By the way it's a grate for the firebox in a Amish wood heater for a greenhouse so I got lucky as it didn't have to look pretty.
    Trailblazer 302
    Lincoln SP 135 T
    Smith torch
    Spoolmatic 30A
    Big Lake/Monticello MN
    Re: Arc blow
    AC and 7014 will cure your problem nicely
    Syncro 350
  6. Likes whtbaron liked this post
  7. #6
    Nov 2004
    Missouri
    Re: Arc blow
    Never even thought about that. I'll get some and put in the truck for occasions like this.
    Thanks.
    Trailblazer 302
    Lincoln SP 135 T
    Smith torch
    Spoolmatic 30A
  8. #7
    Mar 2015
    Re: Arc blow
    Smaller rod use 1/8 inch or 3/32
  9. #8
    Re: Arc blow
    Quote Originally Posted by shortarc View Post
    Thanks.
    As a bonus, they weld quite nicely
    Syncro 350
  10. #9
    Brethren, Mi
    Re: Arc blow
    This isnt truly arc blow everyone seems to think is common,,,, I never get it, this is a rod angle problem. Turn the machine up, shove the rod in it.
  11. #10
    Nov 2004
    Missouri
    Re: Arc blow
    Tried every angle from dragging the rod to pushing it with no help. if I turn the amperage up it will just blow a crater and large BB's everywhere.
    Trailblazer 302
    Lincoln SP 135 T
    Smith torch
    Spoolmatic 30A
  12. #11
    Re: Arc blow
    You can run really big rods at high amps with AC and 7014 or 7024
    (7024 being flat and horizontal only of course)
    Syncro 350
  13. #12
    Re: Arc blow
    I've experienced it many times, especially on items that are already magnetized.
    Some drill pipe made a DC arc go sideways.
    (it would hold up a hammer)
    AC fixed the problem and I welded happy.
    Syncro 350
  14. Likes 455dan liked this post
  15. #13
    Re: Arc blow
    I did not know that on DC.
    Most of My stick welders was AC and never had problem.
  16. #14
    May 2007
    Re: Arc blow
    there is something about the area on the inside of flange of i-beam, about 1/4 - 1/3 of the way from the web, too the outer edge of flange, that sometimes i gives arc blow. so its not uncommon to get arc blow in that short stretch, while welding in a stiffener. switching to ac, ususually isnt an option
  17. #15
    Jun 2008
    Central California
    Re: Arc blow
    Sometimes changing the position of the ground cable (or adding a short jumper so the current comes over different paths) can reduce the "arc blow". On DC, the arc is magnetized so reacts to the magnetic field set up by the current beyond the arc. Currents coming different ways can set up competing fields that oppose (neutralize) each other.
  18. Likes 123weld, shortarc liked this post
  19. #16
    May 2007
    Re: Arc blow
    Quote Originally Posted by Oldiron2 View Post
    yes, im understanding on that, and reversing directions. but the area is like the bermuda triangle, sometimes
  20. Likes shortarc liked this post
  21. #17
    Re: Arc blow
    Sometimes, no matter what you try to do..........arc blow will defeat you.
Size:  245.9 KB The arc simply went where it wanted.
    Changed over to AC, and 7018AC for these particular welds...................
Size:  182.1 KB Although the AC variety is prone to surface porosity, it can be successfully run at fairly high amps, with the rod literally shoved into the metal. I like looking at my old welds before my eyesight went completely South. (still no response from the eye doc appointment request)
  22. Likes shortarc liked this post
  23. #18
    Jun 2008
    Central California
    Re: Arc blow
    I wonder what would happen if a degaussing coil were put just behind that metal while welding with DC?
  24. #19
    May 2010
    Ct.
    Re: Arc blow
    By “degaussing coil” do you mean the device for demagnetizing
    the CRT in an old television?
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  25. #20
    Re: Arc blow
    I have burn a lot with E7018 rod
    I have never had arc blow but is was mostly with AC .
    Very interesting photo.
  26. #21
    Brethren, Mi
    Re: Arc blow
    I was gonna comment about eyesight,,, then figured if arc blow makes it sound better,,, well...
  27. #22
    Re: Arc blow
    It could be never had problem is most time my first pass was E6011 then the rest was E7018.
    If had a large gap I use E6013 first past and then E7018.
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  28. #23
    Re: Arc blow
    So, hero?.............you've never seen arc blow shove a puddle off line?
  29. #24
    Re: Arc blow
    Not sure why you don't "believe" in arc blow - but here's a very old video on the subject.
    Enjoy
    Syncro 350
  30. Likes dhem liked this post
  31. #25
    Re: Arc blow
    I hear you Sam, I've personally seen it go nearly completely sideways.
    Syncro 350
Page generated in 1,713,257,761.93769 seconds with 20 queries
