Results 1 to 21 of 21
Thread: Newbe Needs Help with Fuel Problem on Lincoln Advantage 400 Perkins Engine
    Apr 2022
    Angry Newbe Needs Help with Fuel Problem on Lincoln Advantage 400 Perkins Engine
    Machine starts and runs for a second then goes to low idle then shuts down. IT will restart and do the same thing.
    I've changed Both filters and tried again with the same results.
    Any Ideas?
    THanks
    Dale
    May 2021
    Landrum, SC
    Re: Newbe Needs Help with Fuel Problem on Lincoln Advantage 400 Perkins Engine
    Year Born, Hours on it.
    Will it stay idled up if you have something AC~ plugged in and powered up when you start it?
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
    Apr 2022
    2011 with 4400 hrs
    I tried that and it will not stay running.
    Brethren, Mi
    What inj pump they use? First thing,,, right off, run,,,, buy a service manual for it.
    When had fuel problems with fuel I would a buy a new fuel line to can of fuel. This way I know where problem is, most time in old equipment it was the fuel line from tank to the pump or carburetor. Sometimes it was a rust in tank too.
    Quote Originally Posted by dnkendrick View Post
    Any Ideas?
    THanks
    Dale
    Dec 2008
    Sounds like the low oil shutdown circuit is kicking in!
    Stupid question but have you checked the oil level and added if low?
    Could be bad too
    But all the low oil shutdown circuit that I have seen had led that tells you.
    Quote Originally Posted by rexcormack View Post
    Mar 2015
    Change the oil and filter the filter might have a bypass and it might be not working just a guess
    Aug 2019
    northeastern PA.
    from what I remember, the perkins diesel has a little lever on the lift pump to prime the fuel filter. Can you work that lever and feel resistance? Then will the engine start and keep running or does it still go to low idle and quit? You have a fuel supply line breaking down internally and stopping the fuel from flowing to the lift pump OR the lift pump is bad.
    Jun 2017
    AJO, ARIZONA
    Could be sucking air on the suction side of the pump.
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    JEFF
    I had test tank about 1/2 gal that could vise grip above the carburetor and line to the carb. I got a low cost forklift.
    Then new if was a fuel problem or something else.
    The one problem was most hard to find was old forklift. It had new carburetor, new coil and all new lines .
    But the problem was the distributor hard a worn bearing. Replaced the bearing and ran great 👍.
    Aug 2019
    northeastern PA.
    Dave, it's a perkins diesel...no carb and no electrical distributor.
    I just pointing out in gasoline engines problems I have had.
    Most problems I had with diesel was a fuel line or tank problem
    But point was to a clean tank and line to isolated the problem.
    Quote Originally Posted by BillE.Dee View Post
    Aug 2019
    northeastern PA.
    OK Dave. Just thought that you went off on a walkabout. But yeah, it does sound like a hose problem or junk in the tank
    Some of perkins diesel engines use distributor and one pump, this can make harder to find the problem.
    I like Cat engines as they use a injector pump for each piston.
    But do most common problems first the fuel lines and tank.
    After that I just have the injector pump rebuilt.
    Saves time and money.
    If Cat they are easier to rebuild in the feild.
    Shine a flashlight after dark into the tank (Don't use a torch).... could be an in tank filter or I've seen little balls of solder roll around in there and block off the fuel leaving. Engine quits and it rolls away. Starts back up and it got drawn into the inlet again.
    Aug 2019
    northeastern PA.
    might be anything blocking the flow of fuel from inside the tank. But I'd start with the cheap stuff first.
    I guess a arc from welder, match or a lighter is out too.
    I thought looking in the tank was the cheap stuff...
  20. Likes Lis2323 liked this post
  21. #20
    Aug 2019
    northeastern PA.
    could always stuff a skinny kid inside with a snorkel to have a look around.
  22. Likes whtbaron liked this post
  23. #21
    Mar 2021
    Near Roanoke, VA
    I was the "skinny kid" when I was in the US NAVY,, in 1972,,
    When there was a leak in a fresh water tank, they "stuffed" me in the port of the tank,, to find the leak,, and weld it.
    Those tanks were somehow coated with zinc inside (galvanized??) The tanks were over 2,000 gallons, and only a couple feet wide.
    It got to the point that I knew the next day I would be "flu sick",, but, the tank had to be welded,,
    Those tanks were several feet above and below the waterline, inside the hull,,
    probably a little extra torpedo protection??
  24. Likes whtbaron liked this post
Page generated in 1,713,298,880.27633 seconds with 19 queries
