Originally Posted by
Sberry
That is ignition ballast resistor. Ok, as I recall the oil pressure switch was in series with the coil wire from ign. The ballast resistor just before the coil, one wire from a start terminal on ign switchgoes to coil and the ign/run wire goes thru the resistor. They could have T the start wire with 1 terminal on the ballast too and share the wire to the coil. The idea here, engine not running and making oil pressure no start. The resistor is placed so its bypassed at start and then feeds the coil which reduces voltage thru the points during run. Gives it a little boost at start then reduces to extend point life.
