Results 1 to 25 of 25
Thread: 7018 uphill problem
    May 2022
    7018 uphill problem
    I am a student in a community college welding program. I am having problem welding 7018 uphill, the weld drips. I am using a1/8 rod at 120amps on a Miller XMT 350 cc/cv. My welds are fine up to about a 65 degree up angle but when I hit 90 degrees the weld pool drips metal. My travel speed is moderate with no undercut and I use a side to side motion with a slight pause at each side ( not doing a wide weave) and a 15 degree rod up angle in my stinger.
    Any suggestions you can offer to correct this problem will be greatly appreciated.
    Thank you very much.
    Dec 2020
    Virginia, USA
    Re: 7018 uphill problem
    Quote Originally Posted by fogbank View Post
    Watch this.
  3. Likes NotaVegetarian liked this post
    Jun 2011
    Texas
    Be aware that with 7018, much of the "dripping" is actually slag, sometimes copious amounts of it. Are you brushing it off after you weld? Use an angle grinder with a twisted wire brush. The bead under it can be DRAMATICALLY different. I also strongly recommend making a pad, using 7018 vertical up. Do 4 or 5 layers.
    -Ruark
    "Become one with the puddle, grasshopper" - Welding Instructor
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
    May 2022
    Thank you for the suggestion, however it is metal dripping not slag. Slag collects in the bottom of the puddle when going uphill and doesn't drip for me. I always clean my welds with a wire wheel. Appreciate your suggestion.
    Laredo + Midland/Odessa
    Keep the arc length very short. If needed, drop the amps down to around 95-105. If that doesn't still work, the it could simply be too much heat for the test piece.
    Outside of Raleigh, NC
    Watch this.
    That's a good video and worth watching.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
  8. Likes 52 Ford liked this post
  9. #7
    I like how he pointed out the undercut likely caused by the offgassing of the millscale that he did not grind off the plate
  10. Likes 52 Ford, scsmith42 liked this post
  11. #8
    Brethren, Mi
    It might be outgassing I guess but the edghes simply dont flow and wet as well against dirty steel. You can see little undercut nicks along this especially with weave that are caused/aided anyway by scale making it more work.
  12. #9
    Brethren, Mi
    Might be worth noting as in the pic that while the plate is vert the puddle really isnt. I dont watch Jody much but he is probably as good as it gets and a couple I saw running overhead plates it was obvious this is a guy been there and dun it.
  13. #10
    Dec 2020
    Virginia, USA
    Jodie at Welding Tips and Tricks always has some good info in his videos.
    Always seems to have some interesting stuff to learnt you
  14. Likes precivilization liked this post
  15. #11
    Jan 2022
    Sugarland, GA
    Have been watching these videos. I’m laid up at the moment with this back.
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14” Saw
  16. Likes 52 Ford liked this post
  17. #12
    Dec 2020
    Virginia, USA
    Quote Originally Posted by NotaVegetarian View Post
    I literally just sat down to give my lower back a break. Splitting logs into rails for a split rail fence. 12lb sledge, a maul, and wedges.
  18. #13
    Anchorage Alaska
    Mr. F. Bank
    Do you have some photos of your dripping?
    Asking for a friend.
    A 1000 words........
  19. #14
    May 2007
    yea, 120 amps a lil much for that. we had a water trough at school, where we cooled/dipped work piece in every couple+ beads/passes.
    try dropping down 10 amps, and increase/steepen ur rod angle at this 90 degree/problem area - and adjust from there if need be
  20. #15
    Cumbria, UK
    Watch the arc force (dig?) knob on the XMT, it will just keep pushing amps into the rod if you have it turned up too far, so no good for uphill.
    Here's you trying to keep a short arc length, and here's the machine trying to boost the amps and you end up with a hot runny mess.
    I'd turn arc force down to say 25-30% and amps to 110, maybe 105, for 1/8". It's been a while since I used an XMT for stick, more recently using a lunchbox welder at 105 amps for uphill and it loved it.
    IIRC the XMT with a bit of dig on it will burn a 7018 as hard as you can push it into the joint... was almost impossible to snuff the arc out or short circuit it.
  21. #16
    Jan 2022
    Sugarland, GA
    with my back like it is right now I can’t pick up the tools, can’t hardly walk to the bathroom
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  22. #17
    May 2022
    I solved my drip problem. I was pushing the the rod too far into the puddle (short arc to the extreme) and the 3/8" plate could not handle the heat thus the metal dripped out. Now I focus on my arc length and make certain I establish a good puddle before I start moving up the plate. All is good now.
    Thank you all for your suggestions, they are greatly appreciated.
    PS: My settings are 109 amps, 25% arc force (Dig) and approximately15% uphill tilt on my rod.
  23. Likes 52 Ford, NotaVegetarian, Drgas liked this post
  24. #18
    Dec 2020
    Virginia, USA
    Good to hear you got it figured out.
    I still recommend watching the Welding Tips and Tricks channel on YouTube. There's a lot to be learned there.
  25. #19
    May 2022
    Thank you for your recommendation.
  26. Likes 52 Ford liked this post
  27. #20
    May 2022
    Watch this.
    I had the same problem, and even my master couldn't say what was wrong. I'm happy to become a part of this community. As a student, I have many challenges during my studying, and such forums and websites help me to keep studying without burnout. Thank you for sharing it!
  28. Likes NotaVegetarian, 52 Ford liked this post
  29. #21
    Dec 2020
    Virginia, USA
    Quote Originally Posted by solvepassel View Post
    You have a master?
    Does she wear lots of black leather and carry a whip?
    If so, that HARDLY qualifies her to give advice on welding.
    Sent from my SM-G781U using Tapatalk
  30. Likes N2 Welding liked this post
  31. #22
    Mar 2012
    Australia
    Hold a tight arc, keep it consistent and don't be afraid to keep moving forward.
  32. Likes Lis2323 liked this post
  33. #23
    Brethren, Mi
    Old rod thru heavy scale.
  34. #24
    North Port Florida
    You could ask a question on how to weld and get a thousand replies, but since your in school and probably getting good info. You just need to burn a truck load of rods and you'll get it! Just practice Man and it will come!
    We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
  35. #25
    May 2022
    I had the same problem, and even my master couldn't say what was wrong. I'm happy to become a part of this community. As a student, I have many challenges during my studying, and such forums and websites as https://essayservicescanner.com/edusson-review/ help me to keep studying without burnout. Thank you for sharing it!
    You have a master?
    I wrote it not in this sense
    [/COLOR]
Page generated in 1,713,289,097.05564 seconds with 22 queries
