Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Thread: Transformer welder for a dump load?
    Apr 2022
    Re: Transformer welder for a dump load?
    Quote Originally Posted by rexcormack View Post
    I think the OP is looking for a problem that does not exist.
    I just read the official Honda manual on this engine and nowhere in it does it say anything about
    a break in procedure or break in hours.
    https://cdn.powerequipment.honda.com...X37Z6L6010.pdf
    Uh-oh, LOOKOUT
    Looks like we got us an INSTRUCTION MANUAL READER here!
    CT
    Are using "motor" as the same term as "engine"? Diesel engines are usually "broken in" under varying loads, the worst thing you can do is run an engine under zero load trying to get the rings seated especially at an idle. When I turn a rebuilt truck engine out of the shop the driver is instructed to drive normally varying the speeds slightly and avoiding extra heavy pulls at first, hold a gear or two lower on long hills for the first 1500 miles to seat things in.
    We are talking about a Honda gas generator engine. The op is looking to stress the motor as a break in method. Completely different scenario.
    Apr 2022
    With 6 hours of runtime on that 22hp motor, one of two scenarios has most likely already happened.
    Either:
    a) the motor is already broken in, or
    b) the cylinder walls have glazed and the rings will NEVER properly seat.
    If it doesn't burn oil, then the rings have seated and the motor is broken in.
    If it DOES burn oil. then the cylinder glazed and/or the rings got jammed up with carbon before the rings seated.
    I think the OP is probably making a tempest in a teacup out of this.
  4. Likes 12V71, Louie1961 liked this post
  5. #29
    Mar 2005
    Under a Rock
    Every hot rod car (or motorcycle) engine Ive ever built I ran it normal/varying speeds/rpm …
    Then after about 100 miles ….. anything goes “ Break it in like you’re gonna run it”
    Hammer down.
    Some people think too much
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  6. Likes 12V71, CAVEMANN liked this post
  7. #30
    Mar 2005
    Under a Rock
    Hey 12v71
    I got me a present today from Brown.
    Hypertherm PM 45
    HTP 221
  8. Likes CAVEMANN, whtbaron liked this post
  9. #31
    Apr 2022
    Now all ya gotta do now, John, is weld some black iron fittings onto that!
  10. Likes John T liked this post
  11. #32
    Mar 2005
    Under a Rock
    Quote Originally Posted by StandarDyne View Post
    HaH!!!
    I heard that.
    Hypertherm PM 45
    HTP 221
  12. #33
    Hey 12v71
    That's PURDY. For the 7.3L?
  13. Likes CAVEMANN liked this post
  14. #34
    Mar 2005
    Under a Rock
    Yes.
    Had to yank it for oil pan/ exhaust manifolds
    Decided to do some upgrades along the way.
    Hypertherm PM 45
    HTP 221
  15. #35
    Brethren, Mi
    Glad its u and not me,,, ha If you really bored I could find you a couple fixes.
  16. #36
    Brethren, Mi
    Uh-oh, LOOKOUT
    I really like that.
  17. #37
    Mount Tabor VT
    Generac Home Standby machines are supplied with a proprietary break in oil you leave in for an extended period. No mention is made of any out of the ordinary break in procedure other than that.
  18. #38
    Soda springs,Id
    It appears the OP is looking for a nonexistent problem.
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  19. Likes John T, Louie1961 liked this post
  20. #39
    Mar 2005
    Under a Rock
    Generac Home Standby machines are supplied with a proprietary break in oil.
    Is that the same thing as snake oil?
    Hypertherm PM 45
    HTP 221
  21. Likes 12V71 liked this post
  22. #40
    Brethren, Mi
    Its almost scary how much we think alike.
  23. Likes John T liked this post
  24. #41
    Mount Tabor VT
    I doubt it is more than fossil based oil, they just don't want the crankcase filled with anything weird before a fighting chance at break in.
    "The thrill of victory, the agony of defeat, the constant variety of stupid"
  25. #42
    Feb 2012
    I believe that stepping on throttle seats the rings on the top and letting off throttle seats the bottom but I may be overthinking but then we are talking about a new engine or newly rebuilt. On the other hand Ive heard to throttle it like you stole it when breaking in but thats not what I do.
  26. Likes 12V71 liked this post
  27. #43
    Feb 2012
    Most likely a non detergent oil. Ive heard that recommended before for first oil when breaking in.
  28. Likes 12V71, whtbaron liked this post
  29. #44
    I think the break-in oils may be a bit higher in zinc content to protect slipper type cam followers. Could be wrong though.
  30. Likes Insaneride liked this post
  31. #45
    Jun 2017
    AJO, ARIZONA
    Yep, that's what I've always heard, also for flat lifter cams, BUT you have to be careful with these oils in engines that sport silver bearings as the zinc will plate to the silver.
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    LET'S GO BRANDON!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
  32. Likes Insaneride liked this post
  33. #46
    Brethren, Mi
    If it came with something called break in oil out it would go, new off the shelf oil goes in.
  34. #47
    Apr 2022
    Back in the olden days, I think they used to put a special "break-in" oil in automobile engines, but I guess they don't anymore, so that no one will try to get 50k miles out of it.
  35. #48
    Jul 2020
    They also tell you not to drink the battery fluid in the manual instead of how to time the distributor.
    Of course modern vehicle engines are electronically controlled so there is no distributor, but you get the point I'm sure.
Page generated in 1,656,108,093.17908 seconds with 12 queries
