Results 1 to 8 of 8
Thread: lincoln 305g problem
    Apr 2022
    i recently aquired a lincoln 305g welder which runs fine, generates 110 and 220 power but wont weld. i understand the control board is prone to failure on this machine and would appreciate any help on proving if this is the problem as replacement boards are very expensive. thanks
    Jul 2012
    Re: lincoln 305g problem
    Apr 2022
    [QUOTE=guajilloweld03;8861904]https://www.lincolnelectric.com/en-z...r-manuals.aspx
    Need to post your code #
    Apr 2022
    yeah, thats a problem also. i cant find code or serial #s on machine anywhere.
    Nov 2013
    MO
    Quote Originally Posted by striker View Post
    Nothing on the righthand side toward the front edge?
    Apr 2022
    finally found a sticker inside the machine with info. code#11794
    Jul 2012
    Check for any loose or bad conections, test the bridge rectifier and capacitor, call Lincoln tech support.
    Apr 2022
    will do, thanks!
Page generated in 1,656,521,477.73694 seconds with 11 queries
