Results 1 to 25 of 27
Thread: Stel P80 - 70A plasma cutter - 400V / 3-ph
    Laredo + Midland/Odessa
    Don't ask me a bunch of questions! (Ruark, circa April 2022 )
    Look ma'! Twins! Shares the same exact case with the S300 stick welder/CAG.
    Next up is a CNC machine torch for it.
  2. Likes whtbaron, 52 Ford liked this post
  3. #2
    Re: Stel P80 - 70A plasma cutter - 400V / 3-ph
    Sweet...matching cases makes it easier to build a cart anyway...
  4. Likes 52 Ford liked this post
  5. #3
    Nice look machine.
    It looks like everything you use is on 400 volts. Odd voltage for America, Canada or Mexico.
  6. #4
    Yep, I already finished my MIG cart, I just need to get the videos edited and put it together. I plan to build another cart for my Invertig 221 w/ water cooler, S300 w/ water cooler, Microcut 875sc plasma, Inverarc 200TLP stick welder. I'm not sure if I'm gonna put the P80 on the cart though, since I plan to use it for a CNC plasma table. Or I might just put it all on the new cart.
  7. #5
    Nice look machine.
    It is odd because this machine is not meant for the western continents. It's predominantly meant for the European markets.
  8. #6
    It is odd to see 50hz 220v for a toaster or hair dryer. Try children sticking a paper clip in that plug.
    Back around the 1920's LA had 50hz and switch to 60hz. I new someone that had a job of change out the pulley on record players.
    I read somewhere some countries are going to 110volt 50hz for homes for add safety.
    American like 60 hz for electronics and little cheaper on generators.
  9. #7
    Ok... whole lotta question #1... does it use standard consumables or will they all have to be special ordered from Stel?
    Consumables are pretty standard. It uses the same torch as their now-discontinued 55A plasma cutter MicroCut 875sc, a Tecmo TH-70. The only difference is the cutting tips. The 70A tips are different, likely the orifice is just a smidge larger.
  11. Likes whtbaron liked this post
  12. #9
    So with a max. cut of 30 mm, that's just over an inch. That should keep you busy for a while...
    Yeap, right around 1+3/16" for a quality cut, with a severance of ~1+5/8" should keep me busy
  14. Likes whtbaron liked this post
  15. #11
    Jan 2005
    You need to post the quality cut at 1+3/16 Industry standards are 10 ipm at that thickness. I would think 1/2 that speed for that old torch design would be good pace..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  16. Likes whtbaron liked this post
  17. #12
    Dec 2020
    Virginia, USA
    Half of Japan is 50Hz and the other half is 60Hz
    The story I heard is that when Japan was first starting to get electricity in the country one of the large cities bought their equipment from Westinghouse (or maybe GE) in the USA, while another city bought their equipment from a German manufacturer.
    Edit: Northern Japan is 50Hz and southern Japan is 60Hz
  18. #13
    Dec 2020
    Virginia, USA
    1-3/16" clean cut is NICE.
    You can probably sever more than 1-5/8" depending on the shape of the part.
    I've cut 1-1/2" thick round bar with my 50A plasma that's advertised at 3/4" severance
  19. #14
    what make /model?
  20. #15
    Dec 2020
    Virginia, USA
    what make /model?
    I can't tell you that. It's a secret.
  21. #16
    Dec 2020
    Virginia, USA
    It's an Amico CUT-50HF. It's one of the cheaper models off of Amazon.
    I did it when I first got the plasma cutter, just to see what it'd do. Mightve been 1-1/4", but I'm pretty sure it was 1-1/2".
    Edit: I'll see if I can do it again.
    The display on the plasma cutter actually goes to 51 amps, so maybe that's the difference.
  22. #17
    lol
    Here’s the first trial cut I did with the used ($$500usd) plasma cutter I bought…..
    I can’t tell you the make. It’s a secret.
  23. Likes 52 Ford liked this post
  24. #18
    Dec 2020
    Virginia, USA
    lol
    By the way, just so I don't get accused of being a liar, I just came outside to the shop, grabbed some rusty 1-1/2" bar, clamped it over the burn barrel, and made some cuts. My big compressor is loud, so I'm using a little oil less one. Well, made the first severance cut (ugly). Decided to make a second prettier one to take a picture of. Well I done gone and either locked up the little compressor or maybe just overheated the contactor. (All good, I have other compressors). AND when the pressure dropped, I think I burned up my plasma electrode!
    Can't have nice things.... LOL
    Edit: popped one leg of a 50A 240 circuit. I forgot to tie the breakers together. OOPS. Compressor runs fine now. I checked the breaker AFTER taking the compressor all apart.... of course.
  25. #19
    I dont have steel that thick, but you could very well be right.
  26. #20
    Dec 2020
    Virginia, USA
    Well, going off the pictures of your shop, it's either a Miller or a Fronius. You bought it used for $500, so I'm going Miller.
  27. #21
    Jan 2005
    Really my O/A torch is best over 1 inch in general.. Less issues, and it will be true of any air plasma. The 70 amp plasma cutters are a nice sweet spot for most CNC cutting.I liked my 120 amp single phase machines, but ended up with my 3 phase cutmaster 60i for it's $400 new price.. I went used for a old school Pakmaster 50 (35 amps), and was able to zero out the cost by selling on of the Sl-60 torches with it.(paid $150) I had a 40 amp SL-40 atc torch, and it was problematic on the 60i, and all the other machines I have used it on.. Found out by adapting it to the Pakmaster it's a fantastic combo, and has zero issues with that machine.. I can still run my SL-60 torch extensions, and torch on it, but The 20-35 amp nozzles are super low CFM, and put it in pancake capability..Although I have a 35c, and 15c built in compressor models The old school unit is a surprisingly good precision gouge unit with the SL-60 gouging nozzles. I know, because the had the Hypertherm 45XP, and Cutmaster 60i with dedicated modes, and parts.
    I am all for the old USA machines if you can adapt a bit better torch..
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  28. Likes whtbaron liked this post
  29. #22
    It doesn't seem to matter if we're looking at the $200 versions or the $4k versions... they all put your fingers right beside the blast of molten metal.
    Need a plasma torch configured like an oxy-fuel torch. WAAY better control for longer freehand cuts too.
  31. Likes whtbaron liked this post
  32. #24
    At least move the button further back so you can keep your hand away from the work.
  33. Likes Lis2323 liked this post
  34. #25
    Jan 2005
    Use the trigger lock function if it has one.
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
Page generated in 1,713,302,883.38181 seconds with 20 queries
