Why is it so?
I was looking for information related to welding polarity on the Internet and found quite a lot of conflicting information. Not just a bit different – the complete opposite.
I was also distracted by some of the archaic terminology that some authors insist on using. DCSP (DC Straight Polarity) and DCRP (DC Reverse Polarity) for example, should, in my view, be dropped from the welding vocabulary. I realise many of you grew up with that terminology but now,
it has no meaning.
DCSP used to be the conventional polarity used in SMAW (also called ARC and STICK welding). The electrode is negative, and the work is positive (DCEN) because this gave better penetration. DCRP (DCEP) was used if less penetration was needed when, for example, welding thin sheets. Those days of bare electrodes are long gone and now flux covered electrodes like the 6010 give best penetration using DCRP (DCEP).
DCSP and DCRP no longer reflect the original use and do not give any hint to the actual polarity being used. They are misleading, confusing and many don’t know what they mean. For example, the AWS defines STRAIGHT POLARITY:
Is when the flow of electrons travels from the workpiece, which is the negative pole, to the electrode, the positive pole.
Even the AWS can’t come to grips with it. Its definition of reverse polarity is also wrong.
Then there is polarity and penetration.
Universal Technical Institute - Without reference to a specific process:
It’s important for a welder to know the meaning of polarity and understand how it affects the welding process. Typically, electrode-positive (reversed polarity) welding results in deeper penetration.
https://www.uti.edu/blog/welding/welding-polarity
That is not the typical case at all. In TIG welding, where the electrode is not consumed, DCEN is used and about 67% of the arc heat (and consequent penetration) is delivered to the work piece via a stream of electrons. If the polarity is reversed (DCEP), the electrode gets very hot and the work is bombarded by a stream of positive Ions causing cathodic etching (cleaning).
In GMAW, where the electrode is consumed, the use of DCEP heats the electrode and the melted electrode is transferred to the weld pool via the metallic arc along with its heat. This heat transfer tends to balance heat distribution and helps ensure that there is sufficient penetration.
There are many other variables affecting penetration including joint preparation, the use of flux, flux composition, transfer mode and shielding gas.
The statement “DCEP gives better penetration” is not true unless it is fully qualified with the process, parameters, shielding etc. In a different context, even using the same process, DCEN might give better penetration.
Some sort of on-line consensus would be good.
Jack
