Results 1 to 25 of 27
Thread: I-beam wood stove
    May 2022
    Northern Indiana
    I-beam wood stove
    Last year I had an old wood stove faceplate laying around and decided to build my own heater for my shop. Afterwards I built 2 more using similar face plates from barrel woodstove kits and to my surprise they sold quite quickly. Now that I have a CNC machine I'm planning on designing my own door and air intake so I can cut out the costs of barrel stove kits in the future. My boss is giving me a killer deal on I-beam too (roughly $0.82 a pound) and I can build the grate from stuff we throw in the hoppers. I'm thinking I'm gonna make a pretty penny on the side this fall and winter...
Size:  125.3 KBName:  IMG_20211113_104906919.jpg
Size:  137.5 KBName:  IMG_20211102_090113123.jpg
Size:  144.7 KBName:  IMG_20211102_105007377.jpg
Size:  134.8 KBName:  IMG_20211102_103233952.jpg
    Millermatic 200®️
    Spoolmatic 1®️
    Craftsman™️ 180 amp AC arc welder
    PrimeWeld CT520D
    3x4 CNC table
    Razorweld 45
    Victor™️ OXY/acetylene torch
  2. Likes farmersammm, Don52, Mikel_24 liked this post
  3. #2
    Brethren, Mi
    Re: I-beam wood stove
    They kook nice but the expanded metal will be short lived.
    CT
    what makes it an I-beam stove?
    Miller Multimatic 255
  5. Likes whtbaron liked this post
  6. #4
    May 2021
    Landrum, SC
    Glad I wasn't the first to ask. But I am asking also. What makes it an I-beam stove?
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Magnum PRO 250LX GT Spool Gun
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Everlast 62i Plasma Cutter
    Ingersoll Rand T-30 14hp
    Instagram: #Freebird Welds
  7. #5
    May 2022
    Northern Indiana
    I use 4 pieces of 10# 12" I-beam, cut the lips off the top and bottom, then weld them into an octagon shape
    Millermatic 200®️
    Spoolmatic 1®️
    PrimeWeld CT520D
    3x4 CNC table
    Razorweld 45
  8. Likes NotaVegetarian, Lis2323, whtbaron liked this post
  9. #6
    Quote Originally Posted by Freebirdwelds View Post
    I was wondering also.
  10. #7
    May 2022
    Northern Indiana
    Oh I know the wood grates won't last, they always disintegrate after a few seasons. Mines lasted 2 so far and it's still holding up. And I can always make more
    Millermatic 200®️
    Spoolmatic 1®️
    PrimeWeld CT520D
    3x4 CNC table
    Razorweld 45
  11. #8
    Mar 2005
    Under a Rock
    The stoves look really nice
    Great job.
    But I agree, that bottom rack won’t cut it at all. It will end up twisting like a pretzel.
    Instead of the rack, I would probably use fire brick.
    They make thin fire brick for that purpose.
    I used them once in a pizza oven.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  12. #9
    May 2022
    Northern Indiana
    I've had many people ask about lining the stove with fire bricks, but I had to have a way for air to get under to help the fire breathe. So far the grate has only bowed a little, I anticipate it to last about 2 or 3 more years, then I'll grab more scrap outta the hopper and build another one.
    I will say this, these stoves are incredibly efficient. After the chimney gets hot you can dampen it down almost to where it's closed, takes a good amount of time to burn through wood and it's hard to see any smoke come out the chimney
    Millermatic 200®️
    Spoolmatic 1®️
    PrimeWeld CT520D
    3x4 CNC table
    Razorweld 45
  13. #10
    Apr 2014
    MN/WI
    Can you give a bit more info on using the soft copper pipe to heat water? How well does it work? Is the water pumped through floor or radiators? Pics also please or that setup.
    Edit: Now I notice a blurry image of a small radiator with a fan(s) in one picture. And another picture of the fired stove with no coil on the stack, but a much better view of the radiator.
    Any safety built in to the system in case power to fans go out?
    Lincoln Idealarc TIG-300
  14. #11
    May 2022
    Northern Indiana
    That was a little science experiment of mine. It's a thermal syphoning heat exchanger. As far as a safety goes there's a reservoir attached to the top that has a vent. If the fan isn't on the water boils and steams out, there's no pressure in the system
    Millermatic 200®️
    Spoolmatic 1®️
    PrimeWeld CT520D
    3x4 CNC table
    Razorweld 45
  15. #12
    Mar 2008
    Georgetown, Texas
    If you can find some grade 6 rebar to make the fire grate out of, it would be good. It makes a 20 year grate.
  16. Likes N2 Welding liked this post
  17. #13
    Apr 2016
    CA
    Heater firebox looks good, weld beads look like they could use some more practice.
  18. #14
    Pretty neatName:  tkqe4fh-smiley-two-thumbs-up175028_285604.gif
  19. #15
    Mar 2021
    Near Roanoke, VA
    I hate to be the "woodstove police",, but, you should check the laws regarding selling woodstoves.
    Many places even selling the used 1970's "PAPA BEAR" type stoves are totally outlawed. The stoves MUST be scrapped.
    Stoves must meet emissions etc,, tests.
    And one of those stoves can void a homeowner fire insurance policy.
    An individual that worked for my sister had a woodstove in a home he owned.
    The county gave him a few thousand dollars, and required that concrete was filled into his chimney.
    He bought some sort of heat pump with the money.
    There can be pretty stiff fines for selling a DIY wood stove,, that kinda eliminates the fun of building the stoves,,,
  20. Likes pinetree liked this post
  21. #16
    Mar 2005
    Under a Rock
    Yeah I was thinking the same thing when I first saw the pictures.
    But I think if you sell them on a small scale/on the down low or by word of mouth you should be OK.
    I certainly would not try to start some sort of business making them.
    Hypertherm PM 45
    HTP 221
  22. #17
    Mar 2005
    Under a Rock
    The pictures are not very clear
    Looks like maybe flux core?
    Anyway, I don’t see any problem with the Welds.
    Looks good.
    Hypertherm PM 45
    HTP 221
  23. #18
    Brethren, Mi
    Good that the grate lasts that long. They could be brick lined, not all stoves use grates.
  24. #19
    May 2022
    Northern Indiana
    It's all about how you market them that matters, when I sold them I put NOT FOR HOME USE! ONLY FOR SHOPS. Although I can't confirm that it's a bulletproof method (how the hell do people on Etsy get away with it?)
    And no it's not flux core, I stick welded the body together and I know my stick welding is subpar. In my defense though I did use 6011 rod, and it's hard to lay a great looking bead with those, but they work great for filling the seams. Been taking scrap plates home to practice my welds with 6011 and 6013, I still got a ways to go but I'm getting better
    Millermatic 200®️
    Spoolmatic 1®️
    PrimeWeld CT520D
    3x4 CNC table
    Razorweld 45
  25. Likes N2 Welding liked this post
  26. #20
    Mar 2005
    Under a Rock
    Why not cap it with 7018?
    If you want it to look purty.
    Hypertherm PM 45
    HTP 221
  27. #21
    Quote Originally Posted by Part-time View Post
    You are correct about how you market them.
    However “ Not for home use! Only for shops” insinuates the stoves ARE safe for shop use.
  28. #22
    Brethren, Mi
    Pictures are hard on the welding,,, really shows even minor flaws that will be nearly invisible with paint or rust after a little bit.
  29. #23
    May 2022
    Northern Indiana
    7018 rod is a little more pricey compared to 6011 and 6013. Plus I already have 50# of both and only about 6# of 7018 I'm probably gonna save for fixing tractor implements and such.
    Sucks that there's so much red tape for these things, honestly I feel like it's a well thought out design, no leaks and when you shut the air intake and close the dampener the fire goes out as it should. Maybe I'll just label it as a camp stove? Idk, Indiana isnt as strict on things as California would be I suppose
    Millermatic 200®️
    Spoolmatic 1®️
    PrimeWeld CT520D
    3x4 CNC table
    Razorweld 45
  30. Likes N2 Welding liked this post
  31. #24
    Apr 2016
    CA
    Personally I’d just whip it together with the millermatic 200 . It would be 100 times faster.
  32. Likes Part-time liked this post
  33. #25
    May 2021
    Landrum, SC
    Well they look good, work good. You'll get the rest sorted. Just keep plugging along.
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  34. Likes Part-time liked this post
Page generated in 1,656,110,067.52742 seconds with 13 queries
