Re: Bit O' Scarfing
Originally Posted by
farmersammm
... I think some of the best torch work I've seen these days is that fella, IC Welds, on UTube. A real master at it. He's a rig welder, and does it day-in-day-out. A total artist.
He is more of an air arc guy but yes... he is a master at it! I also enjoy watching Curtis from Cutting Edge Engineering... Aussie channel dedicated to heavy earth moving machine repairs and anytime he needs to part cilinders and such... air arc comes out!
Your work looks good Samm... cannot be a total expert at EVERYTHING....
Mikel
Re: Bit O' Scarfing
And the rain delays continue
The water hazard
Re: Bit O' Scarfing
I can see where a tractor bucket load of gravel would be nice........
Re: Bit O' Scarfing
farmersammm
Got rained out here too... just after I spotted a launched bearing on the fertilizer spreader.
Cut 50 Plasma
Re: Bit O' Scarfing
The Anti Plasma Dood goes over to the Darkside.
In the ongoing disaster of converting an old ramp.....................I ran out of Acetylene over the weekend. No choice but to go to plasma.
Actually...........it sorta rocked
No preheat, no metal too hot to handle after cutting(within reason, don't stick your tongue on it) Lickity split fast for cuts I don't really need to be perfect. I've lost all pride of workmanship on this project.........it's been going that badly
Re: Bit O' Scarfing
Just got into another rebuild project on the fertilizer spreader and was thinking I could have used your scarfing tip to remove the last 50 butchered patchup jobs. Ended up using the plasma as well... even my cheapy Chinese one comes in very handy at times. Over 2 inches of rain last night and more today... making it hard to get a crop in the ground...
Cut 50 Plasma
Re: Bit O' Scarfing
farmersammm
Get your eyesight back and practice a bit with plaz, and you will hardly ever light an O/A torch. I have the Hypertherm 65 and use it for stuff up to 1/2" thick and gouging and washing old welds, etc. I use drag tips most of the time with straight edges and jigs to make it easy.
Re: Bit O' Scarfing
12V71
For years, I've used it for sheet metal.
This BTW, was the beginning of my problems
I figured it would be easier to split the old ramp in half,, and cut it down to desired width. I could have just cut the end off, and replaced the angle iron on the new width. Oh no!!!!!!!!!!!!!!!!!!!! I had to shoot myself in the foot. Splicing that diamondplate was a nightmare......................warped up like a BANANA
I tell K'kins that my mind doesn't work like it used to. She never agrees..............awful nice of her I guess.
Instead of using short welds to splice the sheet..............I DO A FULL LENGTH WELD ON THE SEAM.
First off.....................I've not done any work on this stuff in a dog's age. I forgot that you have to do SHORT welds. Stitch weld this stuff if it doesn't have to hold fluids.
Then
..............even with a slight gap, I can't really see the joint (remember I'm running flux core.....dragging which makes it a bit hard to follow a tiny joint). I got a section of weld that went off towards Arizona
The icing on the cake..........the damn welder is running even worse. Have to crank it up hot enough to do close to 1/4 material to keep it from arbitrarily breaking the arc...........then run like Hell.
Acts like you're letting go of the trigger. This is on top of the weird wire feed speed variations. THEN IT'S GOT A NEW SYMPTOM........................THE TIP IS STAYING SOMEWHAT HOT AFTER YOU RELEASE THE TRIGGER. It will throw a substantial spark when you put it down on the steel after you finish using it.
The repair kit on Ebay includes a new thermistor, transistor, and some sort of relay (possibly the contactor relay??) Dood that sells the stuff says this is the most common fault with the Hobarts. Might be worth the $26 to get the kit. Can't really afford a new welder after overpaying for that damn disc mower.
Originally, I balked at the cost of a Lincoln machine over 2 decades ago...........I bought the original Hobart instead(which died), and now have bought a second Hobart(which is dying). Chances are, the Lincoln would have been the better buy. I haven't saved a dime buying 2 Hobarts over the years
I have a copyright on "Moron"
Re: Bit O' Scarfing
This Job Is Jinxed
Less than a second........the blink of an eye.
In the process of heat shrinking this POS ramp to straighten it. Needed to hit a high spot with heat, and peen it with a hammer. Somehow............picking up the hammer, or positioning the torch for the heat........the flame passed over the hammer hand.
Ran in the house(scared witless I might add) and held it under the cold water tap for about 3-4 minutes. Took a look at it, and saw no blistering. Got some gauze, and slathered the unburned skin with Neosporin, then taped the gauze over the damn thing.
Bit o' pain, and that's about it so far. Figure that might just be the end of the work day. I tried to run the torch again, and just the heat reflecting back off the metal caused some bodacious pain.
Been a dogs age since there was a Bier Nacht(It's that damn Krone mower
) around here............this might just be the day for it. Besides.........doing any further work today just might allow some dirt to enter the bad area. Don't need any damn infections.
I figure if it shows any sign of change, might just hie off to the doc to see what to do with it.
Re: Bit O' Scarfing
I suppose the big takeaway is.................DON'T FORGET, OR SKIP, WEARING THOSE GLOVES WHEN WORKING WITH HEAT. Gloves on............wouldn't have been any burn. They don't do ya any good laying on the welding table.
Re: Bit O' Scarfing
farmersammm
This Job Is Jinxed
I did the same thing probably 35 years ago. Took a long time to heal. Every year the scar gets smaller but it's still there. Mine was on the left hand, started wrinkling and blistering almost immediately. Good excuse for beer night as alcohol is a good disinfectant, maybe not so much if taken internally.
Re: Bit O' Scarfing
Sorry to see that Sam. That is going to be a long slow healing process. Keep it as clean as you can.
Millermatic 252 MIG
Miller Dynasty 200DX TIG
Miller Spectrum 625 Plasma
Altas 12x36 Metal Lathe
Bridgeport Milling Machine
www.psacustomcreations.com
Re: Bit O' Scarfing
OUCH! Wasn't smart, but I bet it smarted!
Re: Bit O' Scarfing
Well it certainly took balls to post that picture.
Maybe it's time to step away from trying to do everything yourself.
It's not easy but there comes a time when you need to admit that you've lost a few steps And need to back away.
Especially with your health problems.
Burns are the worst kind of pain.
Hoping for a quick healing period for you.
Hypertherm PM 45
1961 Lincoln Idealarc 250
HTP 221
Re: Bit O' Scarfing
He just needs to get his eyes fixed and remember that ppe is not an option but an important step in completing hot work.
Then he'll be good to go
Re: Bit O' Scarfing
Looks painful 😕 😢 😬
farmersammm
This Job Is Jinxed
Re: Bit O' Scarfing
The real problems started this morning
I ain't ambidextrous
Ever try wipin' your rear end with your left hand??
Re: Bit O' Scarfing
Da—— that looks painfull, hope you get full healing and no infection. I have done surface burns but nothing that big. Your in for misery for a while. you have mentioned your sight, a friend of mine just had cataract surgery were they put new lenses on, went from pop bottle bottom glasses still not being able to legally drive, to reading glasses for close work. i have worn glasses since i was 15 and was a tad jealous. Id give up most of my concrete to see better.
Re: Bit O' Scarfing
farmersammm
This Job Is Jinxed
Ouch!!! I know that hurts...and it will for a week or 2...A torch literally blew up in my hands 30 years ago...for 3 continuos weeks i had tremendous pain...I never felt more pain than that in my life..never went away completely til 2 months later...I still got scars on my hands...not a lot of fun...I went back to work 15 days after it happened just so I could keep my mind off the pain...the areas between my fingers took longest to heal...I managed to keep my hands clean enough that neither one got infected and was still pretty productive. I just blocked out the pain in my mind and kept workin through it.
Be safe Sam and heal well.
Popeye
Re: Bit O' Scarfing
Ouch!!! I had a big spatter ball from flux-core hardfacing wire end up in my boot and caused a 3rd degree burn on my ankle. I went to the Medi-center and they put a cooling gel on it plus dressing and said I need to come back every day to get it re-applied for about a week and a half. They said the last thing you want is a scab on your ankle. It heeled fantastically. Cold or better yet ice water for several minutes (10-15 for a bad burn) is the only thing to put on a burn initially. You have to be really careful with what you put on a burn. One of the worst things is butter as some ill informed people have suggested in the past. You don't want an infection and you want your skin to breath. For burns on fingers or less serious burns, the freezing burn spray works good. Burns were covered in my apprenticeship. They said if the burn is over a large area, or hard to reach to soak in cold water, take the person into the shower and turn the cold water on.
Re: Bit O' Scarfing
Welder Dave
Dave, we're changing the gauze about 3 times a day to keep it from sticking to the wound. Each time, including when I first dressed the burn, it's packed in Neosporin.......I mean full tilt slathered on. And I run it under a good blast of water to keep it clean after bandages removed.
The actual pain started today. Bad when your hand is at your side, not very bad when the hand is elevated. More skin died during this period. The dead patch covers the entire back of the hand from knuckles to wrist. Won't try to peel it off.......I figure it's protecting whatever's left underneath it. The doc can handle that.
The bleeding started today. Nothing horrible.......mostly little beads of blood coming out of the skin that's left.
I suppose I got real lucky. The next layer of skin seems to be intact, and the pain tells me that the nerves are functioning.
Got a docs appointment on Monday. I don't see any need to go running off to an ER at this time. Just keep an eye on it for any really bad changes I guess.
I recall trying to move the torch off to the side while I was doing something with the hammer, and it didn't move..........or jerked somehow. I'm thinking I may either have been standing on the gas hose, or somehow pulled the gas hose with some part of my body. That damn heating torch has about an 18-20" gooseneck, plus the handle. Being in my left hand, which isn't coordinated well, probably didn't help I guess.
Re: Bit O' Scarfing
iamsteelworker
everyday....
but i'm left handed.lmao.
Sent from my sm-n950u using tapatalk
that's a good one!!!!!!!!!!!!!!!!!!!!!!
Re: Bit O' Scarfing
Sunday's Words For The Day
Fentanyl
Debridement
All that dead tissue covering the burn started worrying me Saturday night. It was getting very strange looking, and starting to smell.
We took off in the morning today for the only burn unit in the State, which is located in Tulsa, and checked into the ER.
They looked at it, decided it wasn't as bad as it could be, then hooked up an IV.
About 10cc of the Fentanyl, and it was ready for removing the necrotic tissue. They take a wad of wet gauze, and scrub it off...........pulling skin off that won't come free with the scrubbing. The skin underneath looked like raw hamburger.
I was pleasantly surprised by the pain killer. Didn't feel weird, and was ready to hit the road almost immediately. Felt nothing but a bit of pressure while they worked on it.
THE PAIN HIT ON THE WAY HOME
I mean pain like I've never felt. Stopped to buy some Tylenol, and kept on keepin' on.
I suppose it was the trauma involved with abrading that raw skin. WOW!!!!!!!!
Now, at this hour, believe it or not..............almost no pain at all. Amazing.
Good choice to go to the ER. I knew it was the hospital that has the burn unit. They're used to seeing burns.
Wrapped it up in guauze, with some sort of gel pad directly over the raw meat...........contains antibiotic.
Next stop, an appointment with the folks in the actual burn unit.
I figure had I just done the docs appointment tomorrow, they'd just have routed me to Tulsa anyway. Saved a day, and got the healing process started.
