Results 1 to 4 of 4
Thread: '73 SA Fowler Mainliner
    May 2022
    Montana
    Question '73 SA Fowler Mainliner
    Does anybody have experience with these machines? Im having some trouble. Machine runs at about 125 in first through third gear no matter what the fine adjustment is set at. Fourth through seventh work just fine, maybe a little cold but fine for the most part. Arc Force seems to be working properly. Outlet works. Machine revs and idles as it should short of a little vibration under load (bearing?). Machine is new to me. I do not have maint. logs from PO. I have done no other trouble shooting. I would call Hybriweld but the numbers are disconnected, and the websites are down. I dont want to arbitrarily start replacing brushes or shunts. Any help would be greatly appreciated.
    May 2022
    Montana
    Re: '73 SA Fowler Mainliner
    Whoever had the machine apart last put the god damn knob on the switch 180 deg out. Havent tested it but...
    May 2008
    Orange, TX
    Interesting. Please keep us posted.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    May 2022
    Montana
    That was it, the knob was pointed the wrong way. I didn't do it, but I should've caught it sooner.
Page generated in 1,713,263,888.24323 seconds with 18 queries
