Page 4 of 5 FirstFirst ... 2345 LastLast
Results 76 to 100 of 103
Thread: Shop Made Tools
  1. #76
    Oct 2019
    Australia
    Re: Shop Made Tools
    I don't think you can wrap your lanyard around the bars but you can use a large carabena that will. You can't just go welding a bit of round bar or other random steel for a fixing point, it's gotta be rated hardware. Also rust is not permitted. If you fab one up yourself it should be painted or hot dipped immediately and kept in clean condition thereafter, no storing out in the yard next to the tractor with the busted thingy.
    Nice cage by the way. Don't worry about the missus and the tree, it's the thought that counts
  2. Likes 52 Ford, farmersammm liked this post
  3. #77
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    Quote Originally Posted by Woznme View Post
    The big carabiners are called rebar hooks.
  4. #78
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    Here's a picture of one of my lanyards. The big hooks are rebar hooks
    They open up 3".
  5. Likes Woznme liked this post
  6. #79
    Re: Shop Made Tools
    Suitable for large bed posts....
    Cut 50 Plasma
  7. Likes 12V71, 52 Ford, Lis2323 liked this post
  8. #80
    Re: Shop Made Tools
    Get your mind out of the gutter young man!!
  9. Likes 52 Ford, whtbaron liked this post
  10. #81
    Re: Shop Made Tools
    why is that ?
  11. #82
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    why is that ?
    Cause they're designed to be hooked onto ladder rungs. Make sense?
  12. #83
    Re: Shop Made Tools
    I knew that…..
  13. #84
    Re: Shop Made Tools
    I don’t bother giving mine names …
  14. #85
    Re: Shop Made Tools
    Lifting eye for heavy vises…
  15. Likes whtbaron, C4Mac liked this post
  16. #86
    Re: Shop Made Tools
    Snipes..
  17. Likes 12V71, C4Mac liked this post
  18. #87
    Shop Made Tools
    Mini platform for sheet metal nibbler…
  19. Likes Munkul, albrightree liked this post
  20. #88
    Re: Shop Made Tools
    Snipes..
    I have eyes on the end of mine too, I did an inframe overhaul on a D10 Cat engine once and the only way to torque 4 of the main cap bolts (200LB FT then 120 degrees) was with a 3/4" ratchet and a come-along. Another one was a nut on a particular scraper model that had to tighten to 3600 LB FT, that one was tightened with Mr. Autocrane with a shackle in the eye of the shopbuilt (homemade) plate wrench I had. Used a 2,000 LB hydraulic scale to check torque. 1,000LBS of pull was the "Bingo" number with that wrench.
  21. Likes whtbaron, Lis2323, Munkul liked this post
  22. #89
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    I knew that…..
    You'd think the little hooks would be called rebar hooks and the big hooks would be... ladder rung hooks? Railing hooks?
    Or just call them big hooks and little hooks, but then you don't get to sound like a pro
    Like calling gears "the big one and the little one" instead of a bull and pinion.
  23. #90
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    If I was working on big stuff like that, where I was needing over 1,000ft-lb on a regular basis - I'd pick up one of these:https://shop.snapon.com/product/Manu...plier/MTMC5100
    25:1... so something like 200ft-lb in to get that 5,100 out. That isn't bad at all.
    Here's a picture from the Snap-off catalog. Sorry it's not flat. No table in front of the the porcelain throne (that's where I keep my tool catalogues.)
  24. #91
    Re: Shop Made Tools
    You have a price list? that will fill the throne bowl in a hurry. I have a couple of smaller multipliers, but if the crane works for the once a year thing, that's fine with me.
    Incidentally I was looking at a Snap on cordless Electric Multiplier today, but $5k for only 1,000 LB ft was stupid. So I bought a new A/C refrigerant recycler. The old Robinair was getting tired and it's that time of year.
  25. Likes 52 Ford liked this post
  26. #92
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    I can't think of what it's called right now, but you can get a hydraulic tool that's designed for torqueing bolts. You set the relief valve to open at the desired torque. I think you can get pneumatic ones, too (I think they use a clutch, though).
    It's basically a hydraulic motor on the back of a torque multiplier, though.
    Edit:typo
  27. #93
    Re: Shop Made Tools
    Edit:typo
    Yep, I used a couple different types, mostly the air type, set the regulator with a calibrated gauge and go til it stalls. Those were handy on mining trucks with 28 nuts per wheel.
  28. Likes 52 Ford liked this post
  29. #94
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    Ever heard of a torque shear bolt? I think they have a trade name... can't think of it right this second.
    The end of the bolt opposite the head has splines on it and that's used instead of a reaction arm. Once the nut is run onto the bolt tight enough, the spline end shears off. Used in construction.
    https://www.amazon.com/Makita-6922NB...59783388&psc=1
  30. #95
    May 2010
    ct.
    Re: Shop Made Tools
    I’ve seen bolts that worked like that used on fittings for
    ductile pipe. Only problem is if you have to readjust the
    position of the fitting, you’re back to torquing by feel or
    getting a torque wrench ( which never happens)
    Miller a/c-d/c Thunderbolt XL
    Millermatic 180
    Purox O/A
    Smith Littletorch O/A
    Hobart Champion Elite
  31. Likes 52 Ford liked this post
  32. #96
    Dec 2020
    Virginia, USA
    Re: Shop Made Tools
    Quote Originally Posted by jpump5 View Post
    Seems to me that they're used as a replacement to hot riveting on structural steel components. Like you see on old train trestles.
    Speaking of hot riveting... You've got a guy with a rivet forge, he heats the rivets up, grabs them with tongs and throws them to a guy with a metal bucket who has to catch them and pass them to the guys that are actually doing the riveting.
  33. #97
    Re: Shop Made Tools
    Cool. pics!
  34. Likes 52 Ford liked this post
  35. #98
    Jul 2018
    Cumbria, UK
    Re: Shop Made Tools
    Just a couple of mine... the jig tables and welding carts I've posted enough of already...
    Site work tote box
    Name:  2020-08-27 16.57.28.jpg
    material prep table from stainless offcuts (still need to make a 2nd one, it's incredibly handy)
    Name:  2021-01-30 19.35.17.jpg
    jib beam with hydraulic slew for the helehandler
    Name:  2021-09-06 13.43.53.jpg
  36. Likes whtbaron, albrightree, Lis2323, C4Mac, LtBadd liked this post
  37. #99
    NW New Jersey
    Re: Shop Made Tools
    Great idea ! I have a Bosch nibbler like that and I always struggle with small sheet metal parts . If I make one, I will need to make it easily removeable, because I often use the nibbler on the outside sheet metal on buildings.
    Regards
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  38. Likes 52 Ford liked this post
  39. #100
    NW New Jersey
    Re: Shop Made Tools
    [QUOTE=Munkul;8868738]Just a couple of mine... the jig tables and welding carts I've posted enough of already...
    What are the extra bits of tube on the bottom for ?
    Cheers
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
Page generated in 1,664,378,416.59602 seconds with 13 queries
