Results 1 to 25 of 48
Thread: Mobile Tube Bender Stand
    Jan 2022
    Sugarland, GA
    It’s way past time to make this, but I’m getting started on it. Often thought about adding a air/hydraulic ram. With my back it’s past time to add it. It’s too hot to work long at a time, well it is for me. Have the basic layout of the base, now I’m going to cool off a bit and then notch some tubes an maybe tack them. Here’s a pic of the base layout. Using 1 3/4” tube.
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14” Saw
  2. Likes Lis2323 liked this post
  3. #2
    Jan 2022
    Sugarland, GA
    Re: Mobile Tube Bender Stand
    Thunder storm rolled in maybe it will cool off. Notched one tube and I’m done for a bit it’s too hot ��
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
    May 2021
    Landrum, SC
    I feel yuh about the heat. It hit 102º yesterday and will hit 105º today. Luckily I finished early yesterday and today.
    I like this idea looking forward to seeing it completed.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
  5. Likes NotaVegetarian liked this post
  6. #4
    Jan 2022
    Sugarland, GA
    The so called thunderstorm never even sprinkled. Went back in the shop for a bit all I did in the heat was notched the base cross bars. Too hot to do much. Like eating an elephant one bite at a time.
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  7. #5
    Coping tubing is just about the hardest thing on the Planet for me. You're looking like it's coming along pretty good.
  8. Likes Lis2323 liked this post
  9. #6
    Looking good
    I avoid tubing projects like the plague. Not good at coping and not good at welding makes for a lot of aggravation. Square tube and butt joints for me. lol
  10. #7
    Jan 2022
    Sugarland, GA
    Looking good
    Thought about square tube, and started a layout with some 2”. However it’s a round tube bender so let’s make it from round tube stock, the two legs of the base have 30 degree bends to give it a stable base. The center pole will have two supports with 30 degree bends. The bender is Woodward Fab manual I’m upgrading to air hydraulic and placing it in a vertical position. This will allow it to be mobile. Thinking of painting it in New Holland blue, well that’s whats on hand.
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  11. Likes Lis2323 liked this post
  12. #8
    Jan 2022
    Sugarland, GA
    It’s 111 outside 15 minutes of work in the hot shop 45 in the AC maybe more.
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  13. #9
    May 2021
    Landrum, SC
    107º outside. I'm staying inside.
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  14. Likes NotaVegetarian liked this post
  15. #10
    I use electrical EMT tubing bender.
    Works great no electric required just pull the leaver.
    Quote Originally Posted by NotaVegetarian View Post
  16. #11
    Jan 2022
    Sugarland, GA
    Have EMT bender, mine won’t bend steel tubing
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  17. #12
    I built a really nice small diameter carbon, and stainless, tube bender some years back. It's amazing the amount of force required to make bends in even small diameter tubing. Mine is what they call a draw bender. The most accurate, least deforming, type of design. Great for hydraulic tubing up to 1" diameter.
    I used the Swagelok bench top bender as the basic design. Took a ton of effort to make, and get the angles right. If you have a mill, and lathe, the sky's the limit if you care to spend the time doing it.
  18. Likes NotaVegetarian liked this post
  19. #13
    Very hush hush proprietay designName:  mutley.gif
    About all y'all ever gonna see of it
    Name:  tube bending6.JPG
Size:  130.1 KB if I showed it to ya, I'd have to kill ya.
    But, you can see the work product.........
    Name:  tube bending1.JPG
    Name:  tube bending3.JPG
  20. #14
    Name:  tube bending19.JPG
    The longest duration EGR repair job in the history of the Earth........................NAY!!!!!!!!!!!!!!!!!! !!!!! THE UNIVERSE!!
  21. Likes Lis2323, LtBadd liked this post
  22. #15
    It will bend water pipe the next size down.
    A 3/4" emt bender will bend 1/2" IPS water pipe.
    A 1" emt bender will bend 3/4" IPS water pipe.
  23. #16
    A lot depends on the tubing itself. Some tubing is made to be bent............it's annealed. Hard tubing won't bend with any degree of success.
  24. #17
    That when bring out the rosebud 🔥.
    It will bend
  25. #18
    Jan 2022
    Sugarland, GA
    Nice work, the smallest steel tube I use is 1” the bender states it will bend up to 2”, I’ve have dies sets for up to 1 3/4”. Those carbide cutters for the notcher are nice.
    tell y’all what bender I have. It’s the Woodward Fab model WFB2. It works pretty well. Wasn’t too tough to use a few years back. It bothers my back now to pull that handle. That’s why I’m adding the air hydraulic ram. It should make it easier on me, maybe interest my grandkids in making some projects.
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  26. #19
    Jan 2022
    Sugarland, GA
    It’s slow going for me in this heat, and it’s only 104 today. 15 minutes in the shop back in house for about an hour. This is all I’ve accomplished
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  27. #20
    Jan 2022
    Sugarland, GA
    Thank goodness for grandkids. The youngest came over, hollered across the shop Pappaw what you doing? Told him playing with some tubing, said you wanna help? Was just notching the first tube for a gusset, was on the top end of it. Had already done the bottom. He says Pappaw you sure you cut that right? Sure enough I cut it backwards. Handed him the protractor, tape, and the other piece of tube. He laid the tube out, measured and marked. Cut it about perfect. Man I love my grandkids.
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  28. #21
    May 2021
    Landrum, SC
    Good Times!
    Lincoln 330MPX
    Lincoln AC/DC 225
    CAC-A
  29. #22
    Looks great 👍
  30. Likes NotaVegetarian liked this post
  31. #23
    Jan 2022
    Sugarland, GA
    I can stand for about 15 minutes and my back needs to rest. Think I’m about ready throw in the towel and have the surgery.
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
  32. #24
    Walked back from the pasture today, and my hip gave out at around 1/4 mi. or less. Had to stop before I could walk the rest of the way to the house. Old age ain't for sissies.
  33. Likes NotaVegetarian, Lis2323 liked this post
  34. #25
    Jan 2022
    Sugarland, GA
    No sir it’s not. Born in 49 grew up in the best time to be a kid, awesome cars, music. Stayed outside till dark. Had the best food home made fresh everyday. Fresh crawfish, oysters, fish we caught daily. Sorry the meds are kicking in and I’m rambling
    Retired Old Guy
    Hobart 210
    Evolution 14” Saw
Page generated in 1,713,293,757.92458 seconds with 22 queries
