Mobile Tube Bender Stand
It’s way past time to make this, but I’m getting started on it. Often thought about adding a air/hydraulic ram. With my back it’s past time to add it. It’s too hot to work long at a time, well it is for me. Have the basic layout of the base, now I’m going to cool off a bit and then notch some tubes an maybe tack them. Here’s a pic of the base layout. Using 1 3/4” tube.
Reason: Speellling
Retired Old Guy
Hobart 210
Lincoln AC/DC 225/125
Evolution 14” Saw
Re: Mobile Tube Bender Stand
Thunder storm rolled in maybe it will cool off. Notched one tube and I’m done for a bit it’s too hot
Retired Old Guy
Hobart 210
Evolution 14” Saw
I feel yuh about the heat. It hit 102º yesterday and will hit 105º today. Luckily I finished early yesterday and today.
I like this idea looking forward to seeing it completed.
Lincoln
330MPX
Lincoln Power Mig 256
Lincoln LN-25X Wire Feeder
Magnum PRO 250LX GT Spool Gun
Lincoln AC/DC 225
¼ Ton of Torches OFC-A OFG-A
Air Carbon Arc Gouging CAC-A
Everlast 62i Plasma Cutter
Ingersoll Rand T-30 14hp
Instagram:
#Freebird Welds
The so called thunderstorm never even sprinkled. Went back in the shop for a bit all I did in the heat was notched the base cross bars. Too hot to do much. Like eating an elephant one bite at a time.
Retired Old Guy
Hobart 210
Evolution 14” Saw
Coping tubing is just about the hardest thing on the Planet for me. You're looking like it's coming along pretty good.
Looking good
I avoid tubing projects like the plague. Not good at coping and not good at welding makes for a lot of aggravation. Square tube and butt joints for me. lol
Originally Posted by
Lis2323
Looking good
Thought about square tube, and started a layout with some 2”. However it’s a round tube bender so let’s make it from round tube stock, the two legs of the base have 30 degree bends to give it a stable base. The center pole will have two supports with 30 degree bends. The bender is Woodward Fab manual I’m upgrading to air hydraulic and placing it in a vertical position. This will allow it to be mobile. Thinking of painting it in New Holland blue, well that’s whats on hand.
Retired Old Guy
Hobart 210
Evolution 14” Saw
It’s 111 outside 15 minutes of work in the hot shop 45 in the AC maybe more.
Retired Old Guy
Hobart 210
Evolution 14” Saw
107º outside. I'm staying inside.
Lincoln
330MPX
Lincoln AC/DC 225
Instagram:
#Freebird Welds
I use electrical EMT tubing bender.
Works great no electric required just pull the leaver.
NotaVegetarian
smithdoor
Have EMT bender, mine won’t bend steel tubing
Retired Old Guy
Hobart 210
Evolution 14” Saw
I built a really nice small diameter carbon, and stainless, tube bender some years back. It's amazing the amount of force required to make bends in even small diameter tubing. Mine is what they call a draw bender. The most accurate, least deforming, type of design. Great for hydraulic tubing up to 1" diameter.
I used the Swagelok bench top bender as the basic design. Took a ton of effort to make, and get the angles right. If you have a mill, and lathe, the sky's the limit if you care to spend the time doing it.
Very hush hush proprietay design
About all y'all ever gonna see of it
if I showed it to ya, I'd have to kill ya.
But, you can see the work product.........
The longest duration EGR repair job in the history of the Earth........................NAY!!!!!!!!!!!!!!!!!! !!!!! THE UNIVERSE!!
It will bend water pipe the next size down.
A 3/4" emt bender will bend 1/2" IPS water pipe.
A 1" emt bender will bend 3/4" IPS water pipe.
NotaVegetarian
A lot depends on the tubing itself. Some tubing is made to be bent............it's annealed. Hard tubing won't bend with any degree of success.
That when bring out the rosebud 🔥.
It will bend
farmersammm
farmersammm
THE UNIVERSE!!
Nice work, the smallest steel tube I use is 1” the bender states it will bend up to 2”, I’ve have dies sets for up to 1 3/4”. Those carbide cutters for the notcher are nice.
tell y’all what bender I have. It’s the Woodward Fab model WFB2. It works pretty well. Wasn’t too tough to use a few years back. It bothers my back now to pull that handle. That’s why I’m adding the air hydraulic ram. It should make it easier on me, maybe interest my grandkids in making some projects.
Retired Old Guy
Hobart 210
Evolution 14” Saw
It’s slow going for me in this heat, and it’s only 104 today. 15 minutes in the shop back in house for about an hour. This is all I’ve accomplished
Retired Old Guy
Hobart 210
Evolution 14” Saw
Thank goodness for grandkids. The youngest came over, hollered across the shop Pappaw what you doing? Told him playing with some tubing, said you wanna help? Was just notching the first tube for a gusset, was on the top end of it. Had already done the bottom. He says Pappaw you sure you cut that right? Sure enough I cut it backwards. Handed him the protractor, tape, and the other piece of tube. He laid the tube out, measured and marked. Cut it about perfect. Man I love my grandkids.
Retired Old Guy
Hobart 210
Evolution 14” Saw
Post Thanks / Like - 6 Likes, 0 Dislikes
NotaVegetarian
Good Times!
Lincoln
330MPX
Lincoln AC/DC 225
Instagram:
#Freebird Welds
Looks great 👍
NotaVegetarian
I can stand for about 15 minutes and my back needs to rest. Think I’m about ready throw in the towel and have the surgery.
Retired Old Guy
Hobart 210
Evolution 14” Saw
Walked back from the pasture today, and my hip gave out at around 1/4 mi. or less. Had to stop before I could walk the rest of the way to the house. Old age ain't for sissies.
farmersammm
No sir it’s not. Born in 49 grew up in the best time to be a kid, awesome cars, music. Stayed outside till dark. Had the best food home made fresh everyday. Fresh crawfish, oysters, fish we caught daily. Sorry the meds are kicking in and I’m rambling
Retired Old Guy
Hobart 210
Evolution 14” Saw
Post Thanks / Like - 4 Likes, 0 Dislikes
