Results 1 to 12 of 12
Thread: Help-0, thermistor isn't shorted. XMT 304
    Sep 2020
    VT
    I'm getting an occasional help-0 error (and no "thunk") when I switch this thing on. The service book says it's the thermistor RT2. I've checked the thermistor for proper resistance, and swapped it for a different one and still occasionally have the same issue. Usually I can turn if off and back on once or twice and then it'll turn on and work normally until the next time I try to use it. Any ideas or further troubleshooting I should do for the thermistor?
    Glen
    Red-D-Arc EX300 (Miller XMT304)
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Sep 2020
    VT
    Re: Help-0, thermistor isn't shorted. XMT 304
    Looking again today I noticed some of the lugs are partially pulled out of the board.
    L1-1 and L1-2. Gonna fix these and see if it makes a difference
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Sep 2020
    VT
    Fixed those lugs, still gave help 0 message at first power on, but then was fine the next couple times. Haven't had another chance to try it since
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Brethren, Mi
    Once it fires up,,, leave it on,, ha
    Sep 2020
    VT
    That's an idea, could leave the leads connected to discourage unwanted visitors to my shop too
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    May 2008
    Orange, TX
    What's the discoloration at the lead terminal circled in red?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Sep 2020
    VT
    Dust and grime
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    May 2008
    Orange, TX
    OK. I thought it looked like a bad crimp that has been arcing.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Sep 2020
    VT
    New clue: I noticed that whenever it decides to give the Help-0 code, it doesn't make the normal "thunk" noise. So I took the cover off and wiggled the connectors that go to the contactors. Tried again and one contactor "thunked" but the other didn't, and still had Help-0. So I took off all the connectors on the top circuit board and made sure they had a tight electrical connection. Tried it a few times since then and 100% working so far. Now for some serious testing!
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Jul 2022
    Hi, I repair boards for a living and most of them miller. This is a common code and it is usually, but not always, caused by a fault with the UI board (User interface). This board is the front panel board. I'm also in VT, small world.
    Sep 2020
    VT
    That's cool! I've always been intrigued by electronics repair. I was going to go to college for electrical engineering but it would've cost so much.
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Jul 2022
    Quote Originally Posted by ArcTan View Post
    I'm self taught, studied college text books since I was in HS and I would breadboard most of the example circuits in the books.
Page generated in 1,713,274,185.40316 seconds with 19 queries
