Results 1 to 15 of 15
Thread: They said it wouldn’t work. But here we are…
    Oct 2013
    Long Island, NY
    After 3 years I finally milled something on my drill press.
    For $145 XY I did not have higher expectations than what I got, but it worked.
    I think i took incredibly small cuts, maybe a heavy 1/32” at a time with the cheapest 3/8” end mill on Amazon.
    I also used a 4 flute, instead of 2 flute for aluminum.
    But, I got the job I needed to done even if it took 2 hours to do all 4.
    By no means is this practical but it got the job done.
Size:  105.1 KBName:  FE95A0F2-9D5C-4AEE-AF24-22BA968BE26E.jpg
Size:  185.4 KBName:  B38BE8C3-AFBB-4EF7-8D0D-67457EF6E74D.jpg
Size:  104.1 KBName:  BDDFFF51-352E-436A-AA41-CCB5BD5731A6.jpg
    www.FirehouseFabricators.com
    Zach
    Millermatic 255
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
    Jun 2008
    Re: They said it wouldn’t work. But here we are…
    Glad it worked out for you.
    Question, did you ever consider using a table saw instead or did you want to see if the drill press would do it?.........Mike
  3. Likes arcflash liked this post
    Oct 2013
    Long Island, NY
    Quote Originally Posted by mrmikey View Post
    I considered a table saw and my sliding miter saw. Half was I wanted to see if I could do it, the other half was using those tools on aluminum without a proper work holding solution can sometimes be a bit dangerous.
    Zach
    Millermatic 255
    Lincoln SW200
    Mar 2021
    Near Roanoke, VA
    I have made LOTS of parts like that,,, using my metal cutting bandsaw, even out of steel.
    If it is a straight cut, the bandsaw can surprise you.
    In your case, the bandsaw could take out 90% of the material in minutes, then drill/mill the remainder,, best of both worlds,,,
  6. Likes LtBadd, Roert42 liked this post
  7. #5
    Jun 2008
    Central California
    If you don't have or trust a bandsaw, even a hacksaw can remove much if the material, allowing the milling to just clean the surfaces and give precise dimensions. I did lots of work entirely by hand, long before I had any machinery.
  8. #6
    May 2021
    Landrum, SC
    Nice, sometimes you do what you gotta do and sometimes you do cause you gotta see.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Lincoln AC/DC 225
    ¼ Ton of Torches OFC-A/OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Lincoln Tomahawk 1000
    Ingersoll Rand T-30-14hp-25cfm
    Instagram: #Freebird Welds
  9. Likes Shootr, 455dan liked this post
  10. #7
    Quote Originally Posted by Freebirdwelds View Post
    *as long as no long term traumatization to goats occur
  11. Likes whtbaron, SweetMK, 455dan, Freebirdwelds liked this post
  12. #8
    May 2007
    nice u made it work, but what is it (whats it do) ? they got endmills w/ radius corners too if u want
  13. #9
    That a drill press? Or a drill/mill? Does not look like an average drill press.
    After the first 1/32” pass, I would have thought it works. Then hogged off some metal with other tools. Probably would take 2 plus hours finding the best tool, but the second one would take 15 min.
  14. #10
    Drill press......................... Good for bragin' rights, but it's just aluminum.
  15. #11
    Jan 2005
    Correct, but your mill is a bit closer to a drill press than a old school real Milling machine,,,
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
  16. #12
    Oct 2013
    Long Island, NY
    It’s an antenna mount for a FEMA USAR team I’m making a couple duplicates of. It’s going to have a 1/2” piece of plate bolt onto it.
    It’s just a geared head drill press. Same headstock platform all these Chinese machines use as their foundation but it doesn’t have the proper table etc to really be a mill. The R8 spindle just makes it possible I guess.
    Zach
    Millermatic 255
    Lincoln SW200
  17. Likes whtbaron, 455dan liked this post
  18. #13
    city of Four Flags
    How are you retaining the cutter in respect to side loads?
  19. #14
    Oct 2016
    I resemble that remark as well. So far I do not regret buying the HF 1/2 mill that is
    670 lb with "Rong Fu" heritage.
    Glad the Op made it work
    ps. Darn it Guys I still don't have a band saw of any type, -now I will have to go get that new Bauer HF unit.
    HTP Pro Pulse 220 MTS (Anniversary Edition)
    1962 Idealarc TIG 300 300
    1974 Idealarc TIG 300 300
    1988 HF Power MIG 150
    2015 Lotos Ltpdc2000d plasma/Stick/TIG
    Victor 100 torch, 200- 210 Oxy/Acet gauges
  20. #15
    Jan 2022
    Sugarland, GA
    Looks like it works well to me. You make do with what you have.
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14” Saw
Page generated in 1,713,301,598.77886 seconds with 20 queries
