Results 1 to 2 of 2
Thread: Lincwelder 225 running issues
    Jun 2022
    Hey I’m new here and am in need of some knowledge on my lincwelder 225. Started having problems with it staying running. I thought there must be a filter under the housing between the sediment bowl and gas tank. But after further disassembly that’s not the case. I by passed everything and just hooked up a fuel line to a gas can. It ran perfect. So I bet bypassed the sediment bowl and again it wont run steady. Misses,pops, and cuts out when any load is applied. Please lend me your knowledge
    May 2008
    Orange, TX
    Re: Lincwelder 225 running issues
    Could be looking at a bad fuel pump as in dried out/cracked diaphragm.
    Check for gas in the crankcase that would be a definite indication of a bad fuel pump diaphragm.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,713,305,698.43317 seconds with 18 queries
