Results 1 to 15 of 15
Thread: Old lathe chucks, is the threaded part changeable?
    Sep 2020
    VT
    I have a 3 jaw and a 4 jaw. The 3 jaw fits my lathe spindle, but the other one doesn't. Looking at the back of them, I wonder if the threaded portion can be changed?
    Also, what is this little thing for (that I'm pointing at with the screwdriver)? If I slide it one way, all the jaws move together, but the other way seems to allow them to move independently.
    Glen
    Red-D-Arc EX300 (Miller XMT304)
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Re: Old lathe chucks, is the threaded part changeable?
    Yes I use wight lifter weights.
    Quote Originally Posted by ArcTan View Post
    Morton, Washington
    Yes. What lathe do you have? Do you know what spindle thread is? If your lucky you could bore out the old back plate thread and cut new threads. In some cases you can find pre-made banks that only need to be turned to size fitted to the chuck.
    Sep 2020
    VT
    It's a very old Worcester lathe. I can't find any markings on it other than this
    Best I can tell the spindle is 1-5/8" with 8 threads per inch.
    I'm thinking maybe I ought to find a different four jaw independent because this one has lousy jaws. Looks like they've been welded.
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Mount Tabor VT
    Gee, I don't have a three jaw, but wish I did. Four jaw takes a surprising amount of time to center the work.
    Sep 2020
    VT
    That's why I want one of each
    I have a rectangular block that I need to turn, and can't use the 3 jaw for it
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Jun 2008
    New Plymouth ID
    Ebay carrys a lot of backing plates. im not sure what that screw is for unless that chuck is an adjust tru or something olong thta line i have 3 and 4 jaw chucks for my lathe but its easier to just use the 4 jaw for everything than change out 90 lbs chucks
    Morton, Washington
    There are some photos of a 12" on vintagemachinery.org. This one uses a 1-3/4x10. 1-5/8x8 is also a common size.
    http://vintagemachinery.org/photoind....aspx?id=12117
    Oct 2016
    If you want to make back plates to mount chucks on your lathe, it really helps to take a stub of steel and make a threaded spindle that matches your lathe spindle, this way when you are cutting the internal threads on your backplate you can check the fit as you go, without taking everything apart to check fit.
    You dont want a tight fight on the threads, or you will have a hard time taking the chucks off. The threads just pull the chuck on, it registers on the shoulder after the threads, so make that as close as identical to your lathe spindle as you can on your test stub.
    Sep 2020
    VT
    Mine is more similar to this one, if not nearly identical (except for condition):
    http://vintagemachinery.org/photoind....aspx?id=18271
    Turns out mine does have 1-5/8"x8 as best as I can tell.
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Sep 2020
    VT
    Quote Originally Posted by Poleframer View Post
    Good info, but I think I need a lot more experience before trying anything that precise!
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    Sep 2020
    VT
    Turns out I didn't really need a four jaw chuck after all for the project at hand
    Repairing wallowed out holes in these trunnion mount blocks
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
    I feel much better about the job I did welding the bore horizontally on my backhoe pivot.
  14. Likes ArcTan liked this post
  15. #14
    Sep 2020
    VT
    Yeah, my welding was pretty ugly on this. Good news is most of it got removed on the lathe.
    What process and filler did you use? Have you gotten your drill press setup to bore it out yet?
    Glen
    Hobart Champion 16
    Hobart Hefty CC/CV
    Hobart Handler 140
    Lotos LTP5000D
  16. #15
    I figured most of your weld would be removed. I used 7018. Started with 3/32" and then went to 1/8" cause I ran out of 3/32". Once I had a decent shelf it went pretty good. The 1/8" was so much faster. I'm positive the machine I used made a huge difference, it's a 1961 SA200 Cad. Red Face. Never had to worry about the arc snuffing out or the rod sticking, etc. I ground the weld some with a plug wheel and there were a couple spots I thought might be low so preheated it again and added a little more weld. I need to enlarge the hole about 3/16" before I try the boring head in the drill press and it's pretty slow going with the plug wheel. Weld looks sound with no slag inclusions or other flaws. I need to grind some more before I move the drill press into position. I don't want to try and take too much off with the boring bar in case it dulls quick, can only take very light cuts or breaks. I'll post some pics. of my progress in the near future. I think the electronic level I bought for another reason will work great to set up the drill press. If you put in % grade it reads by .1 increments. I put it on the counter and it showed the counter was off by .4 of a degree. That should be plenty close for what I'm doing.
    https://www.empirelevel.com/torpedo-level_em105.php
Page generated in 1,660,155,839.25031 seconds with 13 queries
