Results 1 to 20 of 20
Thread: Aluminum truck bed tank build
    Oct 2003
    Oregon wine country.
    I'm building a truck tank so I can extend my range to about 1500 miles between fillups for my 2017 Colorado Diesel. I will upload photos as I go and hopefully be fully installed by Sunday.
    I started off with 1/8" aluminum plate sheared and formed to the back of my bed. I had to jog it so it would fit a little closer. The overall measurements are 48" x 16" x 12" which will get me close to 40 gallons.
    I trimmed the 2 baffle plates for fuel and air flow.
    More to come...
    Sent from my Pixel 6 Pro using Tapatalk
    Common sense in an uncommon degree is what the world calls wisdom.
  2. Likes John T, Freebirdwelds liked this post
  3. #2
    Oct 2003
    Re: Aluminum truck bed tank build
    Baffles are ugly welded in.. my tungsten magnet is strong today.
  4. Likes Freebirdwelds, BluCllrPlt, whtbaron, Don52 liked this post
  5. #3
    Oct 2003
    I have to notch out for the aftermarket tie downs, but the tank needs to be pushed off center because of the filler location in the bed.
  6. #4
    Oct 2003
    I found some very dirty mystery aluminum plate for my 3/8" NPT fittings to screw into. The welding battle began when I started at the back of the 1.5" bung for the level sensor. The tungsten ball ejected because it was cranking out too many amps for the 3/32" green size. I turned up the dig and was a little more patient and it paid off. The plates were floating garbage in my weld as I worked around them. It doesn't really matter because all of the fuel system stuff will be covered in the end.
  7. Likes labparamour, whtbaron, BluCllrPlt liked this post
  8. #5
    Mar 2005
    Under a Rock
    Quote Originally Posted by Brainfarth View Post
    Meh,
    If that's ugly, I am runner up for best looking man of the year.
    At least you got good gas coverage Welding inside there.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  9. Likes welding1 liked this post
  10. #6
    Meh,
    Sounds like the voice of a guy who has one too many ..if you were the last man on earth comments taking it to heart.
  11. Likes motolife313 liked this post
  12. #7
    Mar 2005
    Under a Rock
    I am on my first green drink of the night.
    But I digress.
    Let's not derail the man's thread.
    Hypertherm PM 45
    HTP 221
  13. Likes whtbaron liked this post
  14. #8
    May 2011
    Nice baffles
    Hope it all comes out the way you want it to.
  15. #9
    Oct 2003
    With the aid of a drill press, I was able to tap 3/8" NPT holes halfway straight. Cleaned the inside out and capped the ends.
    Before welding, I flattened most of the tacks so it wouldn't look so bad when I rolled over them with weld. I found a piece of tube to rest my arm on so I was steadier. But that limited my run amount to about 6".
  16. Likes Lis2323, 455dan liked this post
  17. #10
    Welds look awesome.
    Personally I think I would have tapped the 3/8 NPT before welding.
    They could have been placed over the corresponding holes on the tank and then welded.
  18. Likes 12V71, rhunt liked this post
  19. #11
    Oct 2003
    I have to tap into the trucks vent tube and it turns out that its a steel 5/8" tube. I'll splice a section out and clamp my home made double t. I couldn't find any solder in the whole shop so I did it the old fashioned way. Grab some household wiring, split the braid so it's slightly smaller in diameter, kick welder to DC and TIG the center. I started to use filler on the brass fitting connection but in the end, it fused good enough. Then I polished the turd.
    I had to check the tank for leaks but I won't be getting the filler cap until next week. So I duck taped the hole closed then taped a plate over the top of it. Pumped it up until it lifted off the table then used some soapy water. No leaks.
  20. #12
    You put a drain plug in that thing?
  21. Likes rhunt, whtbaron liked this post
  22. #13
    Oct 2003
    No drain plug.. easy enough to pump it out if I ever should need to.
    I spliced a section of the return line out, but I had to use my handy multipurpose 12v impact with a diy 3/4" adapter. I could not see how to take the whole filler assembly out without lifting the bed so I did it in place. I will put some stickum rubber between the lower return and the fill tube along with a ziptie to secure everything a little better.
    Learn from my mistake and aim for the other side of the bed bracket.
    I also had to swage out the 1/2" hose to fit over the 5/8" return line.
  23. #14
    Jan 2022
    Sugarland, GA
    Looks nice
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14 Saw
  24. #15
    Aug 2021
    with the price of fuel being crazy daft. the uk is hitting around $11 a gallon for petrol, diesel is a couple bucks more compared to you guys. have you any plans to disguise the tank in someway?
    build a fake snapon bed toolbox round it or something?
    sure the trip to the snapon guy is cheaper than fuel just now
  25. Likes Lis2323 liked this post
  26. #16
    Aug 2021
    sorry that wasn't very clear, diesel here is $13 a gallon, not 2 dollars more than your paying
  27. #17
    Mar 2005
    Under a Rock
    Quote Originally Posted by ghost_walker View Post
    What was the price for diesel normally before all this increase?
    Hypertherm PM 45
    HTP 221
  28. #18
    Aug 2021
    little over half for both. petrol about 6.50 and diesel was about 7
  29. #19
    Oct 2003
    I finished the tank this week, just before going camping. I took some tools along and finished the wiring at the campground. I put 10 gallons in the tank and it pumped about 5 gallons into the truck tank.
    Success!
    Although, there are 2 leaks where the hose is a little larger than the fittings so I'll need to add a few more clamps. Also, I need to change the fuse location to an ignition-on point and add a 12v relay.
    Oh, I found that gas cap on Ebay for $32.99
    I welded the extra plates to the end so a lock will prevent the latch from letting go of the lid.
  30. #20
    Oct 2003
    The cab side mounts were done with drywall anchor and stainless screw and washer. I had to punch out a 1/2" hole to fit it though but it didnt work as I had intended and eventually had to hold it in place from behind with a stick while I drove the screw in.
    The bottom bolts (1 broke in the middle(will replace later)) are right on the edge of a reinforcement channel, so I got really lucky on their placement.
    Name:  036296504250 (Small).jpg
Page generated in 1,660,088,750.50078 seconds with 13 queries
