Results 1 to 25 of 35
Thread: What to do about metal shavings from chop saw, etc.
    Jun 2022
    Hi everyone, just got myself a nice chop saw with a tungsten-tipped blade. I knew it would yield coarser shavings than other options, but had an aha/uh-oh moment when I saw them sprayed all over the table & floor in my garage. Most went into the little reservoir they have for them but, as is inevitable, plenty got scattered around. Looks like thereís a port for a vacuum but I canít imagine itís a good idea to attach my shop vac to it. Thereís a lot less sparking than with a abrasive disc but there are still sparks. Trying to minimize sweeping and vacuuming after use.
    I was thinking of getting some magnets and sticking them in a few strategic places,though Iím not sure how effective that would be. Iíve also considered some kind of foil shroud. . .
    Anybody have other ideas?
    Re: What to do about metal shavings from chop saw, etc.
    Build a saw saw station over a barrel. I use a a rolling/ sweeping magnet and a shop vacuum with a dust collector connected to sweep the floor. Nothing gets to the shop vac.
    Mar 2005
    Under a Rock
    This is one of the best little gadgets I ever picked up from Harbor freight.
    It's a rolling magnet/stick
    I use it all the time.
    Just wheel it around and it's amazing what you will pick up.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    It was not in shop, it outside with all things messy.
    I use road base for floor and ran tractor over floor once or twice a year.
    Quote Originally Posted by ZLT View Post
  6. #5
    Jun 2011
    Eastern Washington
    You could pick up one of the cyclone tops, put it on a metal container and run the vacuum thru that. The hot heavy chips fall into the cyclone container and don't go into the vacuum. Still have to be careful with the hoses though.
  7. #6
    May 2021
    Landrum, SC
    This is a fabricators biggest mystery. Tool Junkie has a great suggestion. Perforated or expanded Sheetmetal top works over a containment box.
    Lincoln 330MPX
    Lincoln Power Mig 256
    Lincoln LN-25X Wire Feeder
    Magnum PRO 250LX GT Spool Gun
    Lincoln AC/DC 225
    ľ Ton of Torches OFC-A OFG-A
    Air Carbon Arc Gouging
    CAC-A
    Everlast 62i Plasma Cutter
    Ingersoll Rand T-30 14hp
    Instagram: #Freebird Welds
  8. #7
    Jun 2008
    Central California
    Hi everyone, just got myself a nice chop saw with a tungsten-tipped blade. I knew it would yield coarser shavings than other options, but had an aha/uh-oh moment when I saw them sprayed all over the table & floor in my garage. ...Trying to minimize sweeping and vacuuming after use. ...
    As always, good pictures showing the saw and where it's mounted, plus one or two of the surrounding shop, would provide useful information.
  9. #8
    Quote Originally Posted by Tool Junkie View Post
    That is what I use. However. I don’t collect chip directly from the saw. Home Depot has a top that fits a 5 gallon bucket. Great for whole shop need.
    If you are pulling directly off the saw then put sand or water in the bucket.
  10. #9
    Brethren, Mi
    I dealt with this. I changed the dross chute after the original scheme.
  11. Likes Freebirdwelds, whtbaron, N2 Welding liked this post
  12. #10
    Jan 2022
    Sugarland, GA
    Also have large back splash behind the saw use the shop vac on the shavings. When the starts getting dull it does throw some sparks.
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14Ē Saw
  13. #11
    That is plus side of gravel/road base floor the steel just goes by.
    Concrete floors need to cleaned.
    If not the ball from welding will be like walking on ice.
    Quote Originally Posted by NotaVegetarian View Post
  14. #12
    Ct
    How about a broom?
  15. #13
    Brethren, Mi
    These saws make such a mess its constant,,, be different if a guy cut something once a week but every hour or so is a different matter and the stuff is about like walking on marbles.
  16. #14
    Oct 2012
    Michigan
    I too have that style magnet. A trick I use with it is to wrap cellophane around it before I "sweep" the area. makes removing the chips so much easier.
    Tim
    metalcraft by moose
    Southeast Michigan
    https://www.facebook.com/Metalcraftbymoose
    Stupid Hurts!!
  17. Likes NotaVegetarian, whtbaron liked this post
  18. #15
    Quote Originally Posted by moose View Post
    I do that with my welding magnets... store them in baggies so all the filings from around the welding bench fall off when I pull them out of the bag.
    Cut 50 Plasma
  19. Likes Roert42 liked this post
  20. #16
    Mar 2005
    Under a Rock
    I usually just use the nozzle attachment to my shop vac which is actually not a shop vac it's a standup.
    Yeah, I vacuum my garage floor.
    I said it.
    Hypertherm PM 45
    HTP 221
  21. Likes whtbaron, 12V71, Oscar liked this post
  22. #17
    Sounds great .
    I my shop I used a iron rake or tractor.
    How about a broom?
  23. #18
    Apr 2014
    MN/WI
    I do as much as I can outside, but live in rural area. City folks prolly can't do that.
    In winter, i will make an enclosure out of tarps to catch whatever flies off the grinder / drill press / band saw / etc.
    My best advice is DO NOT GO INTO THE HOUSE WITH THE SAME SHOES YOU WORE IN THE SHOP. Unless you are looking for a fight.
    Lincoln Idealarc TIG-300
  24. Likes whtbaron liked this post
  25. #19
    There is no fight I take my shoes off at the door or I will be cleaning the floors.
    Quote Originally Posted by bead-boy View Post
  26. #20
    Brooms are for invisible dust, otherwise I end up moving the broom and dust pan half the length of the shop trying to get of the line. It is always an adventure…. One more time
  27. Likes Weldalittle liked this post
  28. #21
    Sechelt, BC
    When I rolled down the thread I saw those gorgeous dogs and I was worried that there might have been some nefarious use of them but I see my fears were ungrounded. Lovely dogs…
  29. #22
    Those are John's... they've been on this site enough to progress beyond "solderer" on their own... and yes, they are very nice dogs...
    Cut 50 Plasma
    I said it.
    I do too. shove the big stuff in a pile, shovel it up and vacuum the poof dust. A lot faster and a lot less wear on my shoulders. I'm looking for a rolling vac that has a 36" pickup. That would really be fast. Kinda like a huge Kirby.
  31. #24
  32. Likes BD1 liked this post
  33. #25
    Jun 2022
    Thanks everyone! This has given me some great ideas.
    ZLT
Page generated in 1,664,597,690.46171 seconds with 13 queries
