Results 1 to 12 of 12
Thread: bed rail
    bed rail
    Hi all:
    I have plenty of bed rail to practice welding on, but, while running some 6011 on bed rail
    it come out looking like bird droppings. Could it be the bed rail material that caused the
    6011 beads to look nasty? Normally I can weld good with 6011 but not this time.
    TIA
    Hollis
    Jan 2022
    Sugarland, GA
    Re: bed rail
    Bed rails ain’t good to weld on, you never what you going to get, real old ones may be ok, newer may be pot metal
    Retired Old Guy
    Hobart 210
    Lincoln AC/DC 225/125
    Evolution 14” Saw
  3. Likes BD1 liked this post
    Re: bed rail
    Quote Originally Posted by NotaVegetarian View Post
    Ok. Yeah I am thinking it's the bed rail that is making me look bad and not my welding lol.
    Re: bed rail
    The last time welded bed rails I used E6013.
    Quote Originally Posted by Hollis View Post
    Hi all:
    TIA
    Hollis
  6. #5
    Wash DC metro
    Re: bed rail
    Remember to follow Jody's advice: enough amps so you don't snuff the arc when you hold a close arc, and... hold a close arc.
  7. Likes Lis2323 liked this post
  8. #6
    Brethren, Mi
    Re: bed rail
    The rail doesnt help a 6011,,,, or is it the other way around?
  9. #7
    Jun 2017
    AJO, ARIZONA
    Re: bed rail
    If your welds don't already look like bird poop, bedrail will fix them so they do!
    NRA LIFE MEMBER
    UNITWELD 175 AMP 3 IN1 DC
    MIDSTATES 300 AMP AC MACHINE
    LET'S GO BRANDON!
    "Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
  10. #8
    Sep 2008
    Re: bed rail
    Most of the bed rail you will find is really-rolled railroad rail, a lot of it coming from Jersey Shore Steel near me in central Pa. It does weld strange sometimes being higher carbon content.
  11. #9
    Re: bed rail
    Good to know.
    Rails are typically 1060 steel.
    1060 steel is harder to weld.
    Quote Originally Posted by oldmachinenut View Post
  12. #10
    Nov 2020
    Southeast Michigan
    Re: bed rail
    Most of the bed rail you will find is really-rolled railroad rail.
    That kind of make sense because it can be hard to cut & drill!
    I made a couple of brackets out of some old bed rail to mount a dust collector to my garage wall.
    It welded ok for me, but then I'm just a hobbyist still working on my welding skills. I believe I used 7018 since I had it on hand from another project.
    Cutting the bed rail was a bit of a challenge! My band saw at the time just had an old high-speed steel blade on it & it didn't cut it that well. I ended up just using an angle grinder with a cutoff wheel. I've since gotten a couple of Bi-MetalM-42 blades for the bandsaw & they cut the bed rail fine.
    It was also a PITA just to drill a couple pf holes in the bed rail.
    Name:  Bed Rail Mounting Bracket .jpg
    Doug
  13. #11
    NW New Jersey
    Re: bed rail
    Jersey Shore Steel, aren't they up by Williamsport PA ? Last time I was up that way they had just shut down the Tetley Tea plant (2003 ?) next door to the Shop-Vac Factory. Time flies by....
    Nice video, maybe a little dated. Sure explains why some angle is so tough. They also make sign posts, tree posts, as well as bed frames. Good to know they're reusing all the old rail that has been torn up.
    PS - Take a look at how they break it up @ 3:40 . Seems to break like glass across a 2 ft gap. wonder how many tons that took .
    Miller Synchrowave 180 sd
    Miller Econo Twin HF
    Lincoln 210 MP
    Dayton 225 ac/dc
    Victor torches
    Snap-On YA-212
    Lotos Cut60D
    Primeweld 225 ac/dc
    Primeweld mig180
    Miller AEAD-200
  14. #12
    Sep 2008
    Re: bed rail
    The main Jersey Shore steel plant is in Avis About 20 miles from Williamsport. I know a lot of guys that worked there nearly their whole lives and some of their sons also work there. It is locally regarded as a great place to work.
Page generated in 1,660,151,002.70981 seconds with 13 queries
