Results 1 to 8 of 8
Thread: Aluminum fuel tank for metal boat
    Jun 2022
    Good afternoon all,
    I want to build a 5 gallon aluminum fuel tank for my welded mud boat and have been doing some research online... This may be a dumb question but what are the bungs used for that I see in the pictures?
    I know I need to weld on the fuel cap and some sort of vent and pickup, Can someone explain what all those extra bungs and attachments are that I see on all the tanks? Why do some/most tanks have two small bungs at the bottom?
    Also, should I use a baffle? I assume it cant hurt so I planned on adding one
    Does anybody have a picture of the inside of a small marine fuel tank to wrap my head around it?
    Any tips for a first time fuel tank builder would be appreciated, I will be using 1/8" 5052 and just making a simple rectangular box
    Thanks for any advice!!
    North Port Florida
    Re: Aluminum fuel tank for metal boat
    You dont need a baffle in a small tank. Boyd Welding.com is good source for all the bungs and parts to make these tanks. They might have a stock tank already made. If you have never built one, you might be better off buying one.
    We've done so much, for so long, with so little. Were now qualified to do anything with nothing !
    My plastic 25 liter tank doesn't have any baffles and it's about the same size. It's not enough fuel to cause any serious weight transfer so I don't see the need. I assume you've watched the You tube vids on the processes involved?
    Cut 50 Plasma
    Dec 2020
    Virginia, USA
    Quote Originally Posted by welding1 View Post
    ehhhh... I dunno. Gotta start somewhere. Better with a 5 gallon boat tank than a 100 gallon transfer tank for their truck.
    Dec 2020
    Virginia, USA
    Quote Originally Posted by Kenny Youmans View Post
    Good afternoon all,
    Just curious, what type of motor are you going to run? Something like a long tail with a V twin?
    Apr 2010
    Kenai, Alaska
    Kenny,
    http://www.glen-l.com/phpBB2/viewtop...28367&start=75 here is a link to a set of posts I did sometime ago during a discussion on welded aluminum tanks. Maybe this could help with some questions and even give you ideas about how to organize or plan your tank project?
    I used to build welded aluminum boats fairly regularly, and have lost track of the all the other equipment I've built for boats, including tanks. Generally, marine tanks aren't supposed to have fittings below the top surface, and you'll find much more regulatory info on https://newboatbuilders.com/ this site has extensive references for fuel systems - links to standards as well as DHS/CG reg.s.
    Cheers,
    Kevin Morin
    Kenai, AK
    PDX PNW
  9. #8
    Wondering that too.... 5 gal is a decent day with my 25hp Merc. If he's making any kind of serious horsepower, that's not a very big tank.
    Cut 50 Plasma
Page generated in 1,664,216,907.78609 seconds with 14 queries
