Champion 10000 won't shutoff
6.2K views 16 replies 11 participants last post by  whtbaron
Welder works as it should. Kohler ch20 engine starts, runs , idles up and down but wont shut off with ignition switch. When switched to off position it goes to high idle!
#4 ·
Is high idle integrated into the off switch?
Sounds like you have a multiposition rotary switch or toggle switch. Pop the switch out open it up, douse it in CircuitSafe, LectraMotive, or some other electronics cleaner that has a cool name (the cool name is important). Isopropyl alcohol would work, too. The idea being to wash away any contamination and to displace any water that may have made it into the switch.
Could be as simple as that.
#10 ·
What he said. The Kohler version cuts off fuel in the carb to shut the unit down rather than grounding out the ignition as is the case with the Onan and Robin models.
#13 ·
Kohler will go to high idle as part of the shutdown routine. It's perfectly normal.
However............if it goes to high idle, and doesn't shut down..........it's the fuel shutoff solenoid.
I've gone over this here before, and folks always try to say it's not right........until they see a properly working unit go to high idle as it shuts down. It's the way they're made, or the way the board is programmed.
#17 ·
The tractors seem to need a little puff every 3 yrs or so.... any more than that is usually an indication of a leak.
