Results 1 to 7 of 7
Thread: Digital torpedo level
    Thought I would post the level I bought last year. I purchased it for checking the % slope on the 1/4 mile dirt oval track I'm building. It's magnetic so I can stick in the skid steer, grader or any implement to check the slope. I think it will work great for lining up my drill press to try and bore the hole for my backhoe pivot I built up with weld. It's accurate to .1 of a percentage of slope or 1/10th of a degree. I put it on the kitchen counter and it read .4 of a % off. Should be plenty accurate for what I need. It's fairly heavy built but they say not to drop it as it isn't rated for that kind of shock. It was about $70 cad. if I recall. Most digital levels are well over $100 and some over $200.
    https://www.empirelevel.com/torpedo-level_em105.php
  2. Likes 52 Ford, Louie1961, John T, albrightree liked this post
  3. #2
    May 2007
    Re: Digital torpedo level
    how'd the dirt track turn out?
    Mar 2005
    Under a Rock
    That's pretty nice.
    In a pinch, I've used the iPhone level.
    And it turns out to be pretty accurate
    Enough for my needs anyway.
    The problem with the iPhone is you have to compensate for the buttons on the side of the phone. Usually a coin does the trick.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
  5. Likes 52 Ford liked this post
  6. #4
    Dec 2020
    Virginia, USA
    That's pretty nice.
    Yeah, it helps to use an phone case with flush buttons or button cutouts.
    You can get little digital angle finders for like $20 or $30 that work like the app.
    Klein sells one. They also sell a fancier model that actually measures level. https://www.kleintools.com/catalog/l...easuring-tools
  7. #5
    Good so far but haven't finished it. I need to fix the hoe so I can dig and load more clay to bank the corners the full width. Then I want to use the Cat to handle the foam filled tires/wheels I have to mount on the grader. A couple guys tried the track out at the end of April and corner 1/2 was really good. The track is 65ft. wide and I need to add about 15ft. more clay to the corners to get the banking the full width.
  8. Likes whtbaron liked this post
  9. #6
    I looked at those little square levels but they don't read % slope. I also think a longer level will be a little more accurate than just a 3 or 4" long one. I like that the one I bought has the groove to fit on pipe and the display and buttons are completely built in so they don't get in the way of anything. It can be used like a standard torpedo level on flat or round surfaces. Too bad the magnets are only on the flat side though.
  10. Likes 52 Ford liked this post
  11. #7
    Husky digital level from Home Depot is good and durable and cheaper. I have one of those Klein don’t use it much. However, over the last year I have reverted back to using a laser level, finder and grade stick. It gives more points for CAD imput.
Page generated in 1,660,284,494.94507 seconds with 12 queries
