Page 3 of 7 FirstFirst 12345 ... LastLast
Results 51 to 75 of 163
Thread: Oxy-Mapp torch constantly loses puddle.
  1. #51
    Dec 2020
    Virginia, USA
    Re: Oxy-Mapp torch constantly loses puddle.
    Yes more oxygen is needed with gases other than acetylene. Many rave how expensive acetylene is but when you figure the oxygen is probably a wash, especially on lighter material. Other than on a mechanized setup cutting thick plate or heavy heating with a huge tip it's a huge pita .
    The stoichiometric ratio for oxy-acetylene is 2.5:1 - 2.5 parts oxygen to one part acetylene.
    Oxy-propane is something like 4.5:1 - 4.5 parts oxygen to one part propane... and it doesn't burn as hot.
    So 1.8X more oxygen is being used with propane.
    Now, if you have something like an oxygen generator for your torch (look it up), it'd probably make a lot of sense to run propane for general cutting and heating and maybe reserve the acetylene for gas welding.
  2. #52
    Oct 2013
    Long Island, NY
    Random question,
    Can you run a torch off a 20lb BBQ propane cylinder?
    www.FirehouseFabricators.com
    Zach
    Millermatic 255
    Lincoln SW200
    Hypertherm Powermax 45xp
    2x4 CNC Plasma Table.
  3. #53
    Oct 2013
    Long Island, NY
    Random question,
    Can you run a torch off a 20lb BBQ propane cylinder? Iím assuming yes.
    Iíd kinda like to buy myself one of these setups for home and I donít really want to keep an acetylene tank
    https://bakersgas.com/products/victo...hoCEMkQAvD_BwE
    Zach
    Millermatic 255
    Lincoln SW200
  4. #54
    Seen lots of guys use a 20lb lp cylinder.
  5. Likes BrooklynBravest liked this post
  6. #55
    The propane does it take longer to start a cut and more oxygen.
    The Mapp gas is faster to start.
    Acetylene is fastest and easy to use for welding.
    I have used all three.
    Today I use Acetylene and oxygen only it simpler just have one.
    When my company I use Mapp for cutting and Acetylene for welding.
  7. #56
    FYI Before I had multiple head cutting torch I used propane. I need the speed of starting the cut from Mapp gas.
  8. #57
    Oct 2013
    Long Island, NY
    The mapp on 80psi was the ticket.
    3/4” cut clean one pass no issue.
    Acetylene still starts the cut much faster.
    The tip is also still a bit ridiculous but it’s all we have currently.
    If i wanted a small setup for home, would you go with disposable mapp gas cans or 20lb propane? The mapp cans are fairly gross overpriced.
    Zach
    Millermatic 255
    Lincoln SW200
  9. #58
    Mapp gas has a cleaner cut over Acetylene and Propane.
    If you doing machining to cut it easier that acetylene or Propane.
    Acetylene adds carbon to cut
    Propane takes away carbon
    Mapp keeps about.
    With all this information I use Acetylene in retirement.
  10. #59
    Jun 2008
    Central California
    Is that the same setup you were trying to run using the small bottles shown earlier?
    From everything I've read, true MAPP gas is no longer commercially available. The expensive bottles sometimes referred to as MAPP on Ebay aren't true MAPP, all this having been mentioned earlier here, IIRC.
    What would you be cutting mainly? How thick? How much or often? Might your city have rules about propane tank storage, and do you have a safe and secure place to store a tank? Do you weld and if so, with electric gear (actually am asking if there's any chance you need an OA system for welding and brazing, so really need acetylene)?
  11. #60
    Oct 2013
    Long Island, NY
    Quote Originally Posted by Oldiron2 View Post
    It would be the same setup, which seems less practical than stealing the propane from my BBQ when I need it.
    I do not live in the city, I can store propane in my yard.
    I do not need to weld. I don’t really need to cut much, I’d just like the power to do it on hand. rosebud probably more often for bending something etc.0
    Zach
    Millermatic 255
    Lincoln SW200
  12. #61
    Mapp keeps about.
    Dave,
    It isn't Mapp that you may be familiar with. It is Map/Pro which is almost identical to propane. You can't buy Mapp gas anymore so not much sense in making it part of discussion.
    Same here for acetylene versus propane. At least 5-6 Oxy/Acetylene setups here but not one propane. One Air/acetylene though.
  13. #62
    For me Mapp gas is different from propane. Mapp gas is hotter than propane
    Acetylene is hotter than Mapp gas.
    When had shop I both Mapp gas and Acetylene. Most work was done with Mapp Gas.
    Today I only use one torch so it is Acetylene.
    Dave,
  14. #63
    Dave,
    Mapp no longer exists so it is of little use to discuss it as though it still a option.
    Map/pro which is the gas being discussed is only barely hotter than propane. The op is still referring to the gas as Mapp gas but it isn't it is Map/Pro.
  15. #64
    When buying 60 pounds at time not all gas supplies had Mapp gas.
    Where live I only had two places that sold Mapp Gass. Last county we had over 10 supplies of gases
    But you can still buy small bottles.
    Dave,
  16. #65
    Jun 2008
    Central California
    Dave,
    Daniel, from the inner quote Dave made in reply to yours, it appears the past, the present and the future all run together and no explaining can help him understand the situation.
  17. #66
    Oct 2013
    Long Island, NY
    I ordered myself the victor propane setup.
    Why the hell not
    Zach
    Millermatic 255
    Lincoln SW200
  18. Likes Lis2323, whtbaron, Louie1961, 52 Ford liked this post
  19. #67
    Victor is great 👍 brand.
    I think still have five Victor only use one in my hobby shop.
    I purchased all new .
    Why the hell not
  20. #68
    No you can't. They do not make the gas anymore. Map/Pro in yellow 1 pound canisters is NOT MAPP gas.
    It certainly does seem to be the case.
  21. #69
    I can only till you what ad said.
    Today I Acetylene since not do to must cutting.
  22. #70
    Why the hell not
    That one is propane only... for that kind of money could you not get the multi-fuel, or have they quit offering that? I had some minor issues with mine at first that were addressed on warranty, but I think you'll be happy with that setup.
    Cut 50 Plasma
    from wiki:
    MAPP gas is widely regarded as a safer and easier-to-use substitute for acetylene. In early 2008, true MAPP gas production ended in North America when production was discontinued at the only remaining plant in North America that still manufactured it
  24. Likes 52 Ford liked this post
  25. #72
    Oct 2013
    Long Island, NY
    You would only need to change the torch tip. The propane regulator i believe will screw into acetylene as well.
    Zach
    Millermatic 255
    Lincoln SW200
  26. Likes whtbaron, 52 Ford liked this post
  27. #73
    That is to bad 👎 😕 😐
    It was a good gas
    from wiki:
  28. #74
    Yes it same threads.
  29. #75
    I used all three gases.
    Propane for rose 🌹 buds
    Mapp gas for cutting.
    I used a lot of gas.
    Today the only gas I use is Acetylene cost more but works great 👍.
    If need a lot gas my plan is to use Propane just take it from BBQ or generator tank.
    from wiki:
Page generated in 1,664,610,294.79632 seconds with 13 queries
