Fuel tank build. 2 gallons
thats 2 gallons of water. Picked a rod up with wood oil on it that I contaminated touch of the inside with. Got about 3 hours Into it. Any opinions are welcome.
Re: Fuel tank build. 2 gallons
Originally Posted by
motolife313
Perhaps if you cleaned your father's garage there would be less of a chance of contamination.
What a pigpen.
Tank looks good so far.
Even though your post is a bit confusing.
Title says "fuel" tank and then you say 2 gallons of water.
Hypertherm PM 45
1961 Lincoln Idealarc 250
HTP 221
What’s the best way that you have found to get to the inside corners? Do you start at the corner and work out? I always seem to dip my rod into the tungsten when close to the corners and have to resort to the spool gun which then looks like crap. No constructive criticism from me, looks good moto
Miller 350 Dynasty
Miller Trailblazer
Miller 625 Plasma Died and needs a new circuit board so its an expensive boat anchor now
Lincoln Power MIG
Victor oxy/acetylene
Hyperthem 85
Start on either side. Had to go left handed a couple times.
Sounds good John… you’re ok man
Gasoline will leak where water won't.
Pressure testing with just a couple PSI and checking seams with soapy water would be much better IMO.
MM200 w/Spoolmatic 1
Syncrowave 180SD
Bobcat 225G Plus - LP/NG
MUTT Suitcase Wirefeeder
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Save Second Base!
Post Thanks / Like - 6 Likes, 0 Dislikes
I was just seeing what it will hold. I’ll definitely pressure test it
Added some c-4 cartridges to make sure there’s no pain when it blowsjk there handles
Post Thanks / Like - 3 Likes, 0 Dislikes
motolife313
1 gal = 231 cubic inches
Syncrowave 180SD
WC-1S/Spoolmatic 1
HF-251D-1
PakMaster 100XL
Star Jet 21-110
Save Second Base!
duaneb55
Seems a lot easier to just pour in 2 gallons of water and see if it fits.
Hypertherm PM 45
HTP 221
motolife313
jk there handles
...they're....
You've been issued a $5 ticket from the word police.
Syncro 350
MinnesotaDave
...they're....
*thems is*
You could have made it much easier by just welding the outside. With inside corner to inside corner fit you could get the proper size of fillet weld on the outside for full strength. No need to weld the inside. Thousands of tanks are never welded on the inside. A lot of them you'd never have access anyway. Aluminum truck tanks are a perfect example. Way overkill and a waste of filler metal and argon if inside and outside are both welded. How do weld the inside of the top???
Welder Dave
Large access port and child labor. Teach yer kids to weld. They can get into smaller places.
Good practice to weld the inside and the top is the least likely to leak. It was pretty good welding it up
Nothing should leak if it's properly welded.
MinnesotaDave
Oh my god...you've made a bomb!
Are you crazy?
Before you finish it - think about the poor bus full of nuns bringing puppies to the orphans that you'll kill with that thing.
Looks ok
Inside corners are tricky - looks like good practice for it.
....bomb...flaming death....oh the humanity....
Would that be the head nun or somebody who stoops lower?
whtbaron
good question for the smartest, most well known sister ... everyone has heard of Nun the Wiser, right ?
I was thinking if the nun with the most seniority was the Mother Superior, someone looking for a less experienced nun might be looking for the Mother Inferior.
Those hand grips are pure genius.
"thats 2 gallons of water. Picked a rod up with wood oil on it that I contaminated touch of the inside with. Got about 3 hours Into it. Any opinions are welcome."
You have must if spend time talk with Smithdoor......style his rubbd of.
The tank looks good also.
That's a cool little project Moto! Kudo's to you for the innovative handles too.
Personally, as I aged arthritis in my hands would make it easier to carry it with a round bar handle on top, versus having to keep squeezing with my fingers into the internal handles.
But your way looks much cooler!
Miller Trailblazer Pro 350D
Miller Suitcase MIG
Miller Spectrum 2050
Lincoln 210MP
scsmith42
I was thinking the same - my hands are too far gone for that handle. Cool though
Syncro 350
