Results 1 to 20 of 20
Thread: Chicago Electric 170 relay mod
    Jun 2018
    Has anyone done the relay mod on a HF 170 if so do you have a step by step on it.
    2. was it worth it.
    Thanks in Advance.
    Re: Chicago Electric 170 relay mod
    Quote Originally Posted by poolbizz View Post
    2. was it worth it.
    Thanks in Advance.
    The best photos Name:  20171130_083410 (1).jpg
Size:  80.3 KBName:  Relay1921.jpg
Size:  95.6 KBName:  20171130_091913 (1).jpg
    If look close you see the brown wire.
    The black on black does not take good photo.
    2. was it worth it.
    Thanks in Advance.
    Jun 2018
    where do they connectName:  1 2.jpeg
    Jun 2018
    If look close you the two brown wired.
    They use for contact part of the relay.
    One of the brown wires is connected to the switch (left side)
    The ( right side) brown wire is connected to transformer
    The two red wire are used for coil of the relay.
    Only one is clear in view it is connected to old relay to the coil of the new relay. Used to power the new relay.
    The wire you can not see in photos goes to coil the ground. I used a 120 volt coil on the relay.
    Also if look closely my ¼" connectors are different from the Chicago 170 used.
    Jun 2018
    Dave take a look Name:  elaay 2.jpeg
    The switch is has both legs switch on and off. I only used the leg going to the old relay for power to contact of the new relay.
    The connections in blue line at top is a Chicago connection.
    The bottom blue line is connection from new relay to transformer.
    Jun 2018
    Thanks Dave its not clear to me , so I'm going to pass on this. thx anyway
    I tried
    If same city it take a few minutes and you up running.
    Jun 2018
    So after a few private messages I upgrade the relay talking with Dave, Thanks Again ... if your ever in South Florida PM me I'll buy you a drink or ???? .... Name:  relay1.jpg
    I tried
    Jan 2009
    Sonoma County, Northern California
    ... I upgrade the relay ...
    Could you post a clear description of your design, and how you built it?
    Jun 2018
    California, CN3 on the board goes to the ON/OFF switch add a wire to the left side of new relay. I used this look at pic
    CN4 on the board goes to S3 , remove from board and connect to right side of new relay.
    Add a wire from relay on board COM port to left side of new relay
    Then from relay on board add a wire from N.O. to right side of new relay.
    That's it... Name:  cn4.jpg
Size:  115.8 KBName:  relaydone.jpg
Size:  103.2 KBName:  IMG_0789.jpg
Size:  116.9 KBName:  term.jpg
Size:  33.8 KBName:  IMG_0788.jpg
  15. Likes California liked this post
  16. #15
    Looks great 👍
    Thank you
  17. #16
    Jun 2018
    Here's a picture of CN3 to switch add a wireName:  cn3 add wire.jpg
    I got the relay from Ebay 26.49 from Zoro search Dayton 5X851 Open Power Relay,4 Pin,240Vac,Spst-No
  18. Likes California liked this post
  19. #17
    Looks great .
    I am posting the schematic of 170 most can read the schematic but if take it someone with a electronic background and repair the board with parts from RadioShack.
    I put copy inside my welder if I ever need for repair.
    Name:  Chicago170 Schematic board.jpg
    HF 170 welder
    HF 4x6 band saw
    South Bend 9N
    Mill
    B&D mag drill
    Victor torch
  20. Likes California liked this post
  21. #18
    Jun 2018
    Great idea …
  22. #19
    Jan 2009
    Poolbiz, nice work. Thanks!
  23. #20
    FYI: The 180 drum switch uses a two position switch and a Three position. Built in to a 6 position rotor type Switch for voltage adjustment.
    I do not have a schematic for 180 but most parts are the same
  24. Likes California liked this post
Page generated in 1,713,271,390.74498 seconds with 22 queries
