Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: What number shade do you use?
    May 2010
    Stuck in Gavin Newsomís world
    Re: What number shade do you use?
    I just wear sunglasses.
    Lincoln Power Mig 216
    Lincoln AC/DC-225/125
    Miller 625 X-Treme Plasma
    Forney 95FI-A 301
    HF 91110
    Victor Journeyman O/P
    Milwaukee
    Dayton
    Makita
    Baileigh
    NRA Life Member
    Mar 2005
    Under a Rock
    9 or 10 usually.
    5 for plasma cutting.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Aug 2022
    #9 Wens for most of what I do usually 1/8in 6010 and 7018, But honestly a #10 will work also but the lenses I use are a little darker then most. Honestly Iím not an expert but Iíve been told that the shade isnít important as far as eye safety any shade lens will block the UV. Just pick a shade that lets you see without being to bright. Now Iím sure if you tried to stick weld at 150 amps with a #5 shade and you were determined to keep going you would hurt your eyes! But if a lighter shade is comfortable for you by all means use it as some lenses seem to be darker then others at the same shade.
    What type of welding do you do?
    Quote Originally Posted by SuperArc View Post
  5. #30
    Dec 2020
    Virginia, USA
    Plastic welding.
  6. #31
    Dec 2020
    Virginia, USA
    Pro tip: the last part of a welding electrode number tells you what shade to use. So, like 6010, you use a shade 10. 6013, shade 13. 7018, obviously, you use a shade 18. No shade 18? Stack up two 9s.
    Little different with MIG wire. Double the last number. ER70S-6, shade 12. ER4043, shade 6.
    hope this helps.
  7. Likes psacustomcreations liked this post
Page generated in 1,664,119,928.27538 seconds with 12 queries
